slowdude Posted August 18, 2024 Author Posted August 18, 2024 Update, and for anyone else who goes through this with a rover k series. K series with stock flywheel. 20 degree ignition advance @ 180 degrees. K series with lightweight flywheel, 12 degree ignition advance @ 151 degrees. Timing dependent upon cams BUT this should help someone get into the right ballpark. Up and running, need to burp the coolant system and then go drive it.
yellowss7 Posted August 18, 2024 Posted August 18, 2024 Good job. I’m hoping to get my Rover K powered Caterham ready for the NJMP event. Hope to see you there. Tom 1
slowdude Posted August 18, 2024 Author Posted August 18, 2024 2 hours ago, yellowss7 said: Good job. I’m hoping to get my Rover K powered Caterham ready for the NJMP event. Hope to see you there. Tom Absolutely. Would love to compare notes etc, see exhausts. This engine sounds fantastic up high in the Rev range.
Outbound Posted August 21, 2024 Posted August 21, 2024 How does the revs feel with the lightened flywheel vs the original? 1
slowdude Posted August 25, 2024 Author Posted August 25, 2024 On 8/20/2024 at 11:15 PM, Outbound said: How does the revs feel with the lightened flywheel vs the original? Finally bled the coolant and adjusted the clutch. Took it out for a 35 mile loop. Car accelerates much quicker, feels like it is faster (even though it probably isn't). Engine braking is significantly more noticeable (think motorcycle levels of engine braking). Flywheel does require some finer tuning. Car is lugging less in wierd Rev ranges (40mph, 4th gear, 1300 rpm), because I don't think the map is pushing fuel/timing based on throttle sensor). Instead of lugging, it sounds almost like a misfire. It's stumbling. Acceleration fixes it. Since I'm only in that Rev range because I want to brake in the clutch nice and easy, I don't think it's a problem to worry about. If you're not on an unlocked ECU, I could see a new flywheel wreaking a bit of havoc with throttle load sites. I'd definitely do a flywheel upgrade. It's significantly noticeable but you'd need to do some real fine tuning.
slowdude Posted September 28, 2024 Author Posted September 28, 2024 (edited) Track day was eventful. Heater hose popped off and spewed everywhere. Thought it was on. Thankfully the car didnt overheat etc. As always @NSXguy is a saint and helped with this and also a clutch adjustment. Car was running great on the track for each session and engine pulled very, very hard. Riot in the high revs. Took the car to the office the week after; still getting the wierd misfire after 20 minutes or so of driving. I'm seeing im losing coolant (overflow tank being low etc). Oil is clear, coolant tank is clear, no smoke or smell of burning. So went down the rabbit hole of coolant leaks and issues via the MG rover forums here: LINKY Since I touched the intake manifold when doing the clutch, It looks like I may have not put enough sealant around the intake by cylinder 1. I pulled the plugs and checked cylinder 1 vs cylinder 3. I can see some faint red residuent (red coolant?) by cylinder 1. Cylinder 3 has normal carbon build up. I'll need to revisit the intake manifold gasket and will most likely need a second set of hands to help out as I screwed it up before. Will try and get a leakdown in sometime in the next few weeks just to double check but given performance on the track etc, it looks like its an inlet manifold leak. I know I didnt put enough liquid gasket around the inlet manifold, looking back I should have put some more in. Cylinder 1 looks like it is missing a chunk but its just the photo quality being bad. New plugs and AFR gauge should fix fueling etc. Des has also been on me to get the AFR set up for closed loop fueling; I went nuts and got an AEM programmable gauge, Will use it for water temp, AFR, etc. That required an OBD2 adapter for the ECU, which required additional power, so I went ahead and got creative. @CBuff is an electrical nerd, so bouncing ideas off of him led to getting a separate fuse box with built in relays. I then went one step further and got some apiele switches for fairly cheap, then a sheet of thin aluminum off amazon for $8. I went and widened the horn hole and put a grommet in to prevent chafing (heh). Snaked some wires to test, as I need to re-arrange for the horn etc. plan is to mount the switches on the bulkhead above the E brake and see how it works out. Hoping to get wiring done up this weekend. For anyone who is looking to wire an EU1/2 K Series harness to a wideband, I went through and did the following research based off of Andrew Revill's EU2 loom + the wideband manufacturer to get an idea of how to do my deutsch connectors. Posting the below as I couldnt really find this on the blatchat or various forums, so I hope its helpful. wideband car color purpose pin color purpose red 12v power with fuse to ignition 1 slate positive VE white heater ground 2 light green slate negative VE green signal into ECU pin 10 3 black ground brown simulated narrow band 4 brown blue MFRU relay to pin 10 black sensor ground (ecu pin 29) in theory wiring from wideband to car wideband car red power 12v ignition switch white black green brown blue brown slate black light green slate Edited September 28, 2024 by slowdude
slowdude Posted April 20 Author Posted April 20 Long overdue update on this. Relay junctions weren't delivering power to accessories correctly and draining the battery. Pulled everything out and re wired a simple bus bar, with a simple power switch on/off for the power to this. Wideband is connected, and ECU configured to read it properly. Went to start the car and the battery is flat; starter wires are very brittle. Going to get a new battery (Banner Starting bull is 5 years old), and throw new power cables to starter. Hopefully this will fix it. I noticed the alternator ground bolt was loose. I am wondering if this may be the cause of the voltage issues with the misfire on the sensors. I've ordered a backup EU2 engine loom in preparation for the above fixes not fixing everything. The car is 28 years old and has had 10 prior owners. Just trying to bring it back bit by bit. 1
slowdude Posted April 30 Author Posted April 30 Update again, after much searching and discussion with UK group chat. One of the members pointed out my misfiring, loss of power etc could be driven by the master cutoff switch. For giggles, I bought a new one. See the below video, but the relays in the original switch are lose and wiggling. I have the vehicle on a tender and will hopefully get a start sometime this week. If this is the cause of the issue I have been chasing for over a year, I will come back and update this post with key search terms for someone else who may be struggling with this.
slowdude Posted May 10 Author Posted May 10 Slowly getting there. Replaced wires and connectors on the starter. Got new battery in, and had to extend some wiring to fit the new battery. Car primes and cranks. Next step is to check ecu for spark. Slowly getting there. 1
slowdude Posted May 13 Author Posted May 13 She runs! (On 3 cyl). Pulled plug. It's lean. Rest are fine. Pulled injector loom and checked continuity. 0.13-0.16 ohms, so they're good. Ordered a pin tool to test car loom. Pulled injector, will try and clean it.
CBuff Posted May 13 Posted May 13 Get it done. You are living up to your moniker far to accurately. Need a cohort on the streets to reduce my chances of being detained by the po po. 2
slowdude Posted May 13 Author Posted May 13 Slow dude, not slow car repair. New injector on order to replace the lean plug. If anyone wants to come huff gas fumes in my garage for a week, you're welcome.
slowdude Posted August 23 Author Posted August 23 (edited) mental note in case I wake up tomorrow and get completely distracted: 1. wideband inputs to pin 7 on the emerald ecu and requires smoothing review on the new controller. Done 2. then set to adaptive loop once engine is up to temp @ 66deg celcius Done 3. update base fueling to be back to -2.5% as it was too rich on idle Done 4. ???? 5. Profit 6. Check with emerald for calibration / afr pinout smoothing email sent to emerald Edited August 23 by slowdude
slowdude Posted September 5 Author Posted September 5 Much larger, and happier update. Went through all of my mental notes above. Did some pin testing, pin 7 is the narrowband and unsuitable for 0-5v input. I started fooling around with the ecu harness - I pulled the blank spot for pin 35 out, and pushed the wire into pin 35. Adjusted the software. Setup adaptive mapping.... and it works. Hope to get some driving in this weekend and further smooth out the fueling. 1
slowdude Posted September 8 Author Posted September 8 Additional log. took the car out today, ran fine, then the usual misfire developed. AFR was OK, so its not fueling. has to be a sensor which is failing when hot. Pulled the Crank Position SEnsor, resistance of old: 1.35/6 k ohms resistance of replacement: 1.41 k ohms. I'm wondering if the CPS being 15+ years old is starting to fail as the car heats up. resetting the ecu restarts the input from the sensor and allows me to start driving the car again. Adaptive mapping is working though, which is great.
yellowss7 Posted September 8 Posted September 8 Glad to see you are making good progress. Keep the faith and keep at it. Hopefully you will have a couple of months of good driving weather. 🤞 1
slowdude Posted September 9 Author Posted September 9 Yessir, needed to take full time away from it to come back. I cant tell if mentally the car is starting slightly faster. Thursday I will try and get out for a lunch drive and replicate the loop to see if the issue persists.
slowdude Posted September 11 Author Posted September 11 Well. Got out for my 25 mile loop today. Car did NOT misfire with the new crank position sensor in. I need to do some more loops close to home to see if it was truly the crank position sensor. Also dropped new BCPR7ES plugs in, so will try and do longer and longer drives. May have found the culprit. 1
