Very Interesting engine CanAm Maverick X3 Turbo RR
fastg
There is a transmission and likely the only one to work well with enough reduction for the cranks tappered output torque capacity, though it is slipping in this example from power output modification (crank is actually slipping on both ends). The engine may be small enough for the canam cvt output to be centered with the engine offset in the engine bay, but if it uses a reverse box on the cvt output, it will be in the way of the driveshaft. There are much better choices for pulling through a traditional rpm range application. Efficiency/output can always be impressive if limited to a narrow rpm range. I wonder about the condition of the cvt with the engine modifications. A nice package for what it is, if the builder can stay within the design limits.
