I recently picked up the newly available Beeline Moto II, which is the evolution of the Moto navigation device they released a few years ago.  Other than @Austin David's post this morning showing an original Moto on his dash, and an older mention by @SENC, I don't recall reading anything about Beeline here, so thought I'd share my initial impressions and raise awareness.
The Moto II pairs with your phone to supply simplified navigation on a 37mm screen.  This info includes direction and distance to the next turn, current speed limit ,and how far into your journey you've travelled. Additionally, small LEDs blink once when you're 200 meters from the upcoming turn, and twice when you're just 50 meters away.  You can toggle through other screens such as speedometer, journey progress, battery levels of both the Beeline and your phone, and a compass mode that always points towards your destination -- perfect for exploring an area without becoming hopelessly lost.  It packs a lot into a small space while allowing you to keep your phone in your pocket where it's less of a distraction.
Thus far, I'm really impressed.  Rerouting works great when there is a data signal, yet only GPS is required to follow a preplanned route saved to the Beeline app.  Just the thing when you're blatting off the grid.  Unlike a phone, it doesn't look out of place in a se7en, and because it is so light (just 42 grams for the plastic version) a robust mount isn't required.
In my case, I 3D printed a magnetic mount that leverages a fishing magnet on the back of the dash and a very thick, embedded steel washer in the base of the printed part.  It's very easy to mount/unmount and doesn't leave a visible trace when removed.  Thus far it's held up to g-forces, but I'll stress test it more this weekend.  If there is any creeping over the course of a drive, I'll add some friction material to the base and/or magnet face.  For those interested, more information is available here:  https://beeline.co/
Great review!  I still love my original Beeline.  The routing / app is great, better than others I've tried (like, a dozen different apps) especially for longer, mutli-point routes.  Anyone can use the app "free" without a device, if you'd like to try it.  The upside of the device is (as noted above) it's small and easy to mount, and it is designed to work well in direct sunlight.  My phone does NOT handle direct sunlight well, or even almost-direct like under the tonneau cover.
@JohnCh i'm curious what you think of battery life; or more specifically, if the Moto II retained the "way more than actually needed" battery.  My Moto claims "30 hours" ish, but that's ACTIVE hours.  I only actually charge it every month or so.  I worried that I would need to solve a wiring problem in my car, but that has not been a concern.
The battery is much bigger in the Moto II (600mAh vs. 400mAh) but the bigger screen and other features appear to require more juice.  They claim 14 hours of normal use and never less than 9 hours if the backlight is continually running at its highest setting vs. 20 hours and 10 hours for the Moto.  Interestingly where they state a backlight off time of 30 hours for the Moto, they don't provide an equivalent for the Moto II.  It's exceedingly rare for me to do over 8 hours of actual driving time on a tour, so I don't see battery life being an issue.  Besides, I have a USB charging port on the side of the glovebox and carry a charging cable for my phone that also works with the Moto II, so if battery life is ever a problem, I'll simply plug it in and continue on.  Or that's the plan.
  • 1 year later...
@JohnCh curious if there are any updates or changes you've made since this post.
I'm curious about getting a Moto II and would like to know if there are any similar mounting solutions to yours that are off the shelf. I don't have a 3D printer.
Mine (moto 1) is stuck on with VHB tape and the bracket.  I could print whatever if you cover shipping.  I like the bracket because it puts the gauge up above and to the right of the wheel, where it's closer to my line of sight.
The original mount worked fine, but I did a new version that placed it above the scuttle in my line of site. Details and photos are here: https://www.throttle-steer.com/the-blog/september-14th-2024
that looks great.
I like the original mount because it can fold down and under my tonneau cover, which I use a lot.  Grabbed a couple quick shots of the mount this morning while tuning ...
note that I usually just leave the device attached, I had it off this weekend to charge it and haven't moved it back.
Thanks for the help guys. I may still pursue this in the future, because it seems like a great thing to have at eye level for just navigation.
But I think I need to figure out how/where I'm going to mount my phone first. I've been looking at
and it's got a great suggestion, so I'm going to try that first.
fwiw I also have hte phone, VHB-taped to the right of my wheel, approximately not blocking the oil pressure, water gauge, and blinker switch.  I use a scosche magnet mount and the phone has not departed yet.
Yeah I may end up doing that but I was hoping to place the phone where that netting is in your picture.
@JohnCh, did you ever share STLs for the Beeline Mount v2 you did? I looked on your blog and I don't see any reference to them being shared anywhere.
In front of the shifter, I assume.  I looked at placement in that area and didn't love it -- had to be too far forward to clear the shifter, and was too tall (phone too wide) to sit well.  Have you figured something out?
I haven't. I'm just doing a magnetic home clipped to the top of the dash for now.
The solution I was contemplating was a few RAM mounts connected under the dash with the X style holder in front of the shifter in landscape... But that set up would have been close to $200 and I wasn't willing to spend that just to try it.
It would be ideal if it works cuz it shields my phone from the sun. My phone over heats quite a bit.
I'll let you know if I end up trying it. I would love to just get a Beeline but I'm not sure how I'll want to mount it. I don't have easy access to a 3D printer.
I don’t publish any of my designs publicly. I may eventually turn them into a hobby business, and I want to avoid undermining that by effectively assigning a $0 value to the IP and R&D time I’ve invested.
As for that specific design, I carefully sized the cavities to fit the magnets I had on hand, ensuring they wouldn’t rattle or interfere with the printer head. I’d need to spend time digging receipts to figure out exactly which magnets I used and whether they’re still available.
Fair enough! Thanks for letting us know!
  • 7 months later...
@williamwashere hah, I JUST responded to Josh's introduction email and I've found we've been chatting here a bit. I actually recently picked up a 3D printer as well... however, I came here to note that the universal mount (with rubber bands) that the Moto II comes with... works REALLY well on the center mirror stem for the aeroscreen mirror.PXL_20260623_002417180.thumb.jpg.e25473adac8a59ad633b82996bd56229.jpgPXL_20260623_002407957.thumb.jpg.ceb330fff5788ebdae9974cceea80de3.jpgPXL_20260623_002347642.thumb.jpg.26de09c743b813e6ddc2b7b9ead5ad62.jpg
quick plug for route7.austindavid.com which can more-easily make routes and export to Beeline ...
also that's genius.  I never even looked at that stem.  but I like mine close to the line-of-sight, just above my right hand.
That looks app-solutely fantastic! Thanks for sharing, I'll be using it for sure. Not too great driving roads where I am... there may be a few near @williamwashere...
I’m just North of Spring in the Tomball area, up US 249. Frontage Roads and Toll Roads as far as the eye can see.
I’m going to need to go North more into the Conroe/Plantersville area when I want to go out. Otherwise I’m going to take it to Downtown Houston for work!
You are a brave man @hahuang65 for driving in Houston with just the aeroscreen, one of my biggest worries for the car is if it’s even moderately comfortable and drivable in 105 degree heat, let alone getting smacked by 80mph stones on I45.
I really like the center mount idea there, especially how impermanent it is. I already picked up a Beeline and have a 3D model of the clip with a screw hole, but I just paid for my drivetrain this weekend so I’ve definitely put the cart before the horse in having it. lol
