I am doing some routine checks and found the car is missing a grease fitting on the rear U-joint.
My question is about finding the replacement part. The documentation I have on the 1995 Caterham indicates the rear axle is from a Morris Marina.
Does this apply to the U-joint also?
There aren't that many different U joints. If you go to a drive shaft shop, they will probably identify it for you.
If you just want to replace the zerk, it wouldn't be a surprise if it's just a 1/4-28 thread, very common size
Otherwise, they are listed by cup OD and width across the outside of the cups  it might be same as an MGB-
don't know about Morris, but Ford diffs came with several different flanges or yokes
