Incoming 420R, California
Nocturnal005
Introducing myself. My name is Norman and reside in the bay area, CA. I've had 15yr dream of building a Caterham and was actually building from plans when life put that on hold. Fast forward, I'm finally in a position to be able to revisit the dream and actually create some memories with my kids via the build.
I don't really plan to a build blog, just excited to share and will prob need some advice along the way. Here are some fun pics from 15 yrs bk. This is as far as I got before I called it quits. Was to be a boosted Hyabusa powered clone for autocross. I imported the panels and body work from Caterham and the frame was TIG welded from 1020 steel.
IMG_0075 IMG_0084 IMG_0105 IMG_0077
Here is the spec for the 420R kit I ordered in May 2024. It's currently in build, so not too long of a wait!
And here is what it looks like at the factory today! Sorry for the low res photos. This is what we got from Caterham. Initially, they sent the photos of someone else's car in yellow, so I'm pretty glad I at least got these. It sounds like the kit should land late Dec or early Jan. For now I'm contemplating what to do with the motor. Leave it all alone, install roller barrels, or R+R the 2.0 before I even install it to get somewhere midway between a 420R and a 620R. I explored the destroked 2.5 short block route but feel like I don't need quite that much and it feels like a much more intensive project. Open to suggestions!
Also exploring what options I should go ahead and upgrade now. At the time of ordering I wanted to keep the costs reasonable, but some of the nice items such as LED lights are looking attractive and don't look fun to install twice.
Before it arrives I've been reading every build log and writing down all the tips and tricks that I find.
Great spec!  A couple of comments:
Regarding the LED headlights, @Outbound is a lighting engineer and shared this post with the source of the Caterham headlights at a fraction of the price.  I believe he may be using these now, and if so, can comment effectiveness.
Delving into engine upgrades, it's a potential slippery slope with a lot of options. Fortunately, there are a number of people here with firsthand experience who will hopefully chime in.  I won't rehash what we've already shared via email, but for the rest of the group I will highlight that you are used to cars with much stronger acceleration than a 420R, so the usual comments about it likely having more power than you need, don't necessarily apply.  A big question you'll need to answer is how much work you want to do now vs. how open you are to doing an engine project in the future?  By all accounts, switching to factory roller barrels or aftermarket ITBs wakes up the engine and adds to the aural experience, and can be pretty straight forward.  Any meaningful cam upgrade in the 420 require tearing apart the engine to accommodate valve lift -- the 420 cams are close to the limit with stock pistons -- at which point the slippery slope has arrived.
In addition to SBD and Raceline in the UK, there are Esslinger and Hasselgren in the US.  I know there is also another Duratec builder in the Portland area but can't recall his name.
During the build, a couple of modifications to keep in mind: replace the scuttle rivets with rivnuts and bolts to make future under scuttle work much, much easier; and if you need to remove the honeycomb boot floor for any reason, cut it in half to make future removal/installation easy rather than an exercise in frustration.
Roller barrels are an easy and well sorted (although perhaps slightly overpriced) addition that is easy to do during initial build that will net you some additional power and a lot more sound. And the throttle response is greatly improved from what I've read (I build mine with the rollers so I have no basis for comparison).
Loynings has closed sadly.  Arnie retired.
