super7guy Posted Wednesday at 04:04 PM Posted Wednesday at 04:04 PM I have a correction to make regarding the interpretation of the chassis tag. The correction is related to the "VC" proportion of the tag. I think that the "VC" stands for Vegantune Components. At the time, there was only the "VTA" engine. As shown later, Caterham also put a version of the "BD" range of motors, one of them being the 16V version. Again, there were street versions, BDR, (i.e. head and pistons, etc) that had the appearance of BD, but still a redline of 7200 rpm since the stock bottom end was not changed. Caterham was working with Vegantune (for the VTA replacement) and the Vegantune version of the BDA was in the works at the same time. There was also the race version with redline 9500 rpm using a steel crank and rods. I have all the components for that version (crank, rods, pistons, etc) and ancillaries including dry sump pump, dry sump pan, dry sump oil tank, sand-cast headers, motor mounts, etc). While the modified 2L Zetec was better suited to soloII, it can not compare to the thrill of a 9K motor with the power boost coming in at 5K and climbing at the way to redline. I have found more information on Vegantune on-line which I can share. Vegantune closed in 2012, so not able to find anyone that worked there, again also online. Wayne
EdWills Posted Wednesday at 09:12 PM Posted Wednesday at 09:12 PM On 1/14/2025 at 3:38 PM, IamScotticus said: Early 80s would be Escort axle. The Itals weren't used until the long cockpit, being an 83, its too early for those. But being 3.75, you probably got an Ital/Marina anyway. Hi Scott. According to Tony Weale in his book "Lotus Seven". the first Marina/Ital axle. (81 spec.) was fitted to chassis 4002 TC R M in 1980. The first Mk 1 RS1600 axle was fitted in 1977 to 3601 TC R S, and the first Mk. 2 RS 1600 axle also in 1977. Weale adds the info in the indices section on page 236. Author Chris Rees also confirms 1980 for the Marina/Ital but has different dates for the Escort series (1975 and 1978). First long cockpit Weale advises 1981, Rees advises 1982. The V.I.N/serial numbers on the cars correspond with both authors, but the dates are off. Cheers, W.
EdWills Posted Wednesday at 10:14 PM Posted Wednesday at 10:14 PM On 1/14/2025 at 10:05 AM, wdb said: My car is a '95 and still has the Ital axle, so that may have been what was in the car originally. OP does mention "Ford 9 inch", which if so does lend itself to the car having been given a HP upgrade. Agreed that pics would help. (If it really is a Ford 9 inch rear, I am dying to find out how those wheels were fitted...) Snap some pics of the transmission while you're under there! I realize that the "Ford 9 inch" diff/axle assembly is a strong and robust unit used in Mustangs and the like, but coincidentally the final batches of rear axles that Caterham sourced from the Ford Mk. 2 RS2000 Escort series of rear wheel drive cars had 9 inch diameter rear brakes as opposed to the 8 inch (by 1-1/2" wide) on the original Escort axles that Lotus used on the few 2-1/2s and all of the Series 3 cars (the Series 4 also had 9 inch rear drum brakes). The 4-1/4 pitch for the wheel studs stayed the same as previous, but the Caterham cars now had 9 inch front discs and 9 inch rear drums. 1
7Westfield Posted Thursday at 12:06 AM Posted Thursday at 12:06 AM "Ford 9 inch" is a reference to the ring gear diameter WAY too much iron for a 7 1
TN_Scooter Posted Thursday at 03:34 AM Posted Thursday at 03:34 AM Agree with 7Weatfield, the Ford 9" rear axle is very strong but very heavy, Not suitable for a 7. These are used by a lot of the NASCAR teams as they are almost indestructible. Average NASCAR racer is 3200 lbs, about three times the Caterham. Just my 2 cents.
EdWills Posted 15 hours ago Posted 15 hours ago (edited) I only mentioned the possibility that the "9 inch" referred to the size of the rear brakes, as I never considered that someone would attempt to fit a very wide rear end to a Lotus or Caterham Seven. On so many occasions (including by my better half), there is always someone to prove me wrong! The Ford 9 inch rear axle is apparently up there in quality, build and desirability. It was used from 1957 to 1986 on Ford passenger cars and trucks. Jegs.com notes that it is 57.25 inches to 68 inches wide (doesn't mention if this is from flange to flange?), and only a few axles in the range could be shortened (these were mostly early 1970s axles as many later axle shafts had tapered ends). 1973 and later had 5 on 5 bolt circle (which the car pictured at the beginning of this post doesn't have). I found the attached photo in the Chris Rees book "Caterham Sevens" showing how wrong I can be. Graham Arnold, who was Sales Manager of Lotus, also published a book on the Lotus range of cars. In a similar vein, he published a photo of a Lotus Elan sporting very wide rear wheel arches and wide rear track, noting on the caption for the photo - "Please Don't". Edited 15 hours ago by EdWills 1
MV8 Posted 4 hours ago Posted 4 hours ago To be fair, the english ford escort/cortina mk2 removable carrier axle (estimated 6.75 inch ring gear) looks very much like a domestic ford "9 inch". Many companies offer new housings and axles of most any width and bolt circle so one could be fitted and retain the original track width. The easy way to tell is the rear cover shape (different from a smooth domestic 8 inch) and the 9 and 8 have a two piece carrier with a five bolt flange on the pinion. The mk2 axle does not. A 6 to 7 inch ring gear axle is an efficient choice for a traction limited 1500 lb or less car, considering parasitic loss and unsprung weight versus strength/longevity. Locking diff, slicks, numerically high ratios above 4:1 and abusive drivers might need a ford domestic 7.5 80s integral carrier or 8 inch 70s axle.
speedwagon Posted 3 hours ago Posted 3 hours ago My Superformance has a cut down c Camero rear end. There are only two downsides that i notice. The near 5k paid for it, and the "posi" is ill suited on such a small car. Neither bother me, as a previous owner stood the cost, and a light tap of the foot-feed solves the sharp corners. But now it is embarrassing to own a car manufactured in eldoinio musk's parent country.
MV8 Posted 1 hour ago Posted 1 hour ago (edited) 1 hour ago, speedwagon said: But now it is embarrassing to own a car manufactured in eldoinio musk's parent country. We can't have that. I'll be right over to pickup my new car. Edited 1 hour ago by MV8
YourEconProf Posted 48 minutes ago Author Posted 48 minutes ago 3 hours ago, MV8 said: To be fair, the english ford escort/cortina mk2 removable carrier axle (estimated 6.75 inch ring gear) looks very much like a domestic ford "9 inch". Many companies offer new housings and axles of most any width and bolt circle so one could be fitted and retain the original track width. The easy way to tell is the rear cover shape (different from a smooth domestic 8 inch) and the 9 and 8 have a two piece carrier with a five bolt flange on the pinion. The mk2 axle does not. A 6 to 7 inch ring gear axle is an efficient choice for a traction limited 1500 lb or less car, considering parasitic loss and unsprung weight versus strength/longevity. Locking diff, slicks, numerically high ratios above 4:1 and abusive drivers might need a ford domestic 7.5 80s integral carrier or 8 inch 70s axle. Yes, this is what happened, my friend is used to working on domestic hot rods, and saw the visual similarities. It's actually a Torsen diff, though I'm not sure if that's been swapped into the Marina housing, or a different housing.
YourEconProf Posted 47 minutes ago Author Posted 47 minutes ago Just a reminder, there is a build thread with much more up to date info over the Build Threads subforum. Is it possible to lock this thread to force conversation over there?
JohnCh Posted 41 minutes ago Posted 41 minutes ago I don't like to lock threads unless it's a necessity. Everyone, please post any technical advice or feedback to the thread below. Failure to do so will result in public humiliation. 1
