Been a member here for a while, but just yesterday I brought home my first Seven. I've put a few miles on it already. Fixed a few minor issues, have several more that I need to address, including adjusting ride height. Front is too low and the rear seems a little high. I've discovered that it's a good idea to remove and install the hood from the passenger side... especially when you're wearing shorts. 😜 The fresh burns on my left shin helped me learn that lesson!
I know you guys like photos, so here's a couple. Parked next to my daily/work truck, the top of the roll bar doesn't even make it up to the door handles and I think the whole car is shorter than just the cab.
Congratulations.  Enjoy.
" The fresh burns on my left shin helped me learn that lesson! "
Rest assured there are some mistakes one only makes once.
  • Haha 1
Ride height looks good to me for unloaded. A silica blanket wrapping the muffler under the guard with phenolic washers would help to reduce the guard temp.
The front is definitely too low for my location. The oil pan skid plate is only about 2" off the ground... and I live on a dirt road.
The muffler guard temp is not an issue- the problem came from putting my shin right on the header as I pulled the hood off immediately after driving. Just not paying attention to what I was doing. 😳
Slightly Taller tires and a dry sump will fix this. You can only do so much with suspension without screwing up geometry. I just live with scraping my muffler a bit.
Look up how the stance people go over bumps, youll have to do that after some time.
Yup, the sump hangs low. Be glad you have a sump guard! I destroyed two oil pans in a year. Bit the bullet and dry sumped it.
Edited by wdb
Do you have the stock oil pan or a Raceline (or otherwise lower-profile) sump? If it's the former, the Raceline sump could get you up to a whopping 3" of clearance, maybe...*
*this is actually a guess, I'm not sure how much more clearance the Raceline has. If it looks aluminum and is full of fins it's probably the Raceline sump though.
