All
i just finished an engine swap to a 2.3l and have a few good, very low miles (<1500 miles?), upgrade 2.0l Duratec engine parts looking for a new home / car
1)  r500 Kent DEC35 cams (263 hp)
2) a r400 lightened flywheel and the CSR260 / r500 clutch and pressure plate to go with these cams
3) a forged 2.0l duratec / Mazda crankshaft to go with the cams
4) Duratec 2.0l k1 conrods to go with the cams
5) r400 radiator and oil cooler
6) r400 original blue injectors
Let me know if anyone is interested.
thank you.
WE need a post on this build in the appropriate spot.  Must include a hp number so I can feel superior..... :classic_tongue:
why not! Will try to write something up.
Are you sure you don’t want to hold onto them
just in case you need spares to swap in…
Edited by wemtd
Brutal Paul...just brutal.
But I am pissing myself laughing  :classic_laugh:
I'm burning the boats behind me..  NO turning back my friend. onwards and up is the only way.
Yes we did.  Re posting the parts unsold to date.
the radiator and oil cooler are the older style with the oil cooler being separate and mounted in front of the water radiator and the fan in the back of the assembly.
I may have someone interested in the radiator and oil cooler and keep this forum updated on this specific part availability.
Parts sold to will be proud driver of an eventual R500 Duratec spec Caterham!
Track goers - beware!
Which track location/region goers need to beware?
6 hours ago, SK400 said:
Most probably east coast. :)
Excellent - Simon needs a new engine!
