Scott_ Posted October 1 Posted October 1 On September 5, 2026, I went to Cars & Coffee in Morrisville with no intention of buying another Caterham. I was a approached by a fellow after he saw me next to my '99 Caterham. He and I started talking about Sevens, and he mentioned that he had a Caterham R400 that he was selling. He had my attention. I had plans for my '99 but I came to learn that the car he had for sale checked all the boxes for me. He showed me photographs of the car and told me the history. It was a genuine Superlight R400 SV with the 210-horsepower 2.0-liter Duratec, Caterham six-speed gearbox, limited-slip differential, wide-track suspension, uprated brakes, carbon dashboard and front wings, cage, race seats, etc. He was the first owner and had built it at the end of 2012. He said he had all the maintenance and purchase records from new. The cage was built off the original track day roll bar by a race shop. After talking more and talking numbers we worked out a deal on the spot. Later that day I sent him a deposit subject to inspection on pickup. After that I listed my '99 for sale. Over the next few weeks I was able to sell my '99 while the seller of the 2012 sent me copies of some of the paperwork and answered my questions as we worked to arrange a pick up date at VIR. The car had led an unusual life. Although completed in December 2012, it had seen very little ordinary road use and was road legal for only about a year. Most of its life was spent in garages/storage at Virginia International Raceway. It came out for track days and an autocross or two. My father shares my interest in cars so he and I left early for VIR from Raleigh on 9/25 to inspect the car and (hopefully) complete the purchase. It was special to have him with me because when I was young he and I went on long trips to collect hot rods and other cars. The car was what I expected and wanted so we closed on the deal and my father and I were back in Raleigh by noon. With the car unloaded I was then off to the DMV for title work and temporary tag followed by an afternoon drive. 6
Scott_ Posted October 1 Author Posted October 1 (edited) One of the things I really like about this car is the paint. The order sheet says Lotus Anniversary Paint Scheme. It matches the Caterham F1 cars of the time. The number on the car is an homage to Group 44/Bob Tullius. I had originally planned to take the numbers off but for now plan to leave them on... I like them. Edited October 2 by Scott_ 6
theDreamer Posted October 2 Posted October 2 I love the image of your new to you 7 as seen in the rear view mirror. When I picked up my MV Agusta F3 in 2012 I had the same view every time I looked in the mirror. For nearly four hours I was staring at that gorgeous red upper fairing. I could not help myself from thinking about the opening line of the Richard Thompson song “1952 Vincent Black Lightning”: Oh, says Red Molly to James, That's a fine motorbike… So I called her Red Molly. (I do not know when we started anthropomorphising our possessions but all my guitars and our toys, (both motorcycles and cars) have names.) 1
Scott_ Posted October 4 Author Posted October 4 (edited) I purchased a set of RBTB's originally made for a 485 with the idea of using them when I installed the Haltech R3 which supports drive by wire. Now that I have the R400, I decided to see if I could convert them to cable actuation since I have a MBE 9M4 on order. It helped that I have a spare head, throttle cable and some other bits to work with off the car. The 485 uses a remote DBW actuator mounted on the side of the engine that uses a short throw to achieve the 90 degree rotation of the barrels. I had originally considered a bell crank arrangement to get the cable pull ratio right but the extra complexity of adding that below the manifold did not seem worth it after studying the throttle bodies and taking measurements. I have a tig welder and came up with a solution so I could use the stock throttle cable without alteration and avoid the need for a separate bell crank arrangement. Initial testing is fine but I need to make sure the return spring is strong enough. Edited October 5 by Scott_
Scott_ Posted October 18 Author Posted October 18 (edited) Finally finished the installation of the Caterham 485 throttle bodies and MBE 9M4 on the Superlight. I switched over to 440cc injectors which, after testing, appear to closely match the initial setup of the SBD basemap that came on the 9M4. I went ahead and replaced the coils and sparkplugs so I knew I was starting from a good known baseline on the ignition. I'm using an Innovate LC2 wideband o2 and had to adjust the voltage curve in Easimap. The SBD/MBE lambda target table appears very conservative and am just leaving it this way for now. I still need to balance the airflow in the throttle bodies and have ordered an air flow meter. Initial road testing and logging indicated the short term fuel trim was adding about 10% so i updated the main TPS fuel map accordingly and the trims are, in most places, now hovering around +- 2% of the target Lambda map. I did update the throttle site curve and still think I need to give that more attention. I did some fourth and fifth gear pulls on the road while logging and everything appears good. Throttle response is good. Cold and hot starts are fine and the coolant fuel enrichment trims seem to work well as is. Curiously the SBD basemap came set up for a Ford coolant sensor and when I switched it to work with my Bosch unit the map disabled the aux pinouts to the fan relay and fuel pump relay. It took me a while to figure out what was going on but I knew there was an issue with the fuel pump not priming. Initial thoughts were blown fuses but I traced it to the ECU and that was an easy fix. Edited October 18 by Scott_ 1
redursidae Posted October 27 Posted October 27 Oh this is so awesome, I don't know how I missed this until now. Congratulations on the new Caterham, and great choice on the throttle bodies. 1
Scott_ Posted October 28 Author Posted October 28 4 hours ago, redursidae said: Oh this is so awesome, I don't know how I missed this until now. Congratulations on the new Caterham, and great choice on the throttle bodies. Thanks. It's been fun tuning it over the last few weekends. I'll post another update on the process soon. Scott
Scott_ Posted yesterday at 06:26 PM Author Posted yesterday at 06:26 PM (edited) It's been a while since I last updated. I've road tuned the MBE 9M4 and am very happy with the rollerbarrels. I still have the Haltech R3, PD16, IC7 and 8 button Haltech keypad that I was on the fence about selling after I sold my prior Caterham and acquired the R400. I now have decided to go on and install the Haltech on the R400. Muliple reasons for this including what I think are the advantages of DBW, engine safety, VE tuning, flat shift, launch control, and so on. I actually have two sets of these 485 rollerbarrels so will sell one set with the MBE 9M4 and current tune once I get the Haltech DBW up and running. I had considered an adapter to mate the R3 to the stock engine harness but after reviewing the current setup vs what the Haltech needs, it's simpler and clearner just to create new engine harness. I've got the wires, sensor plugs, some new sensors, Raychem and a mil-spec firewall connector and have started that harness building process on the bench. Meanwhile, I 3D scanned the R400 dash and designed a mount for the IC7 and Haltech 8 button CAN keypad. I have a Racelogic lap timer that I will also make a mount for that will go to the right of the IC7..... between that and the IC7 mount it should cover up most of the gauge holes and switch holes on center and right side of the dash. I'll likely keep the stock speedo and tach for now. Edited 19 hours ago by Scott_ 2
redursidae Posted 5 hours ago Posted 5 hours ago Would love to hear about your experience with the harness build. Are you going to be using the PDM as well in this round of upgrades? The Haltech DBW is the most foolproof I’ve tuned with, calibrate, adjust Integral gain a bit, and done. Truly amazing. Nice job with the designs.
Scott_ Posted 2 hours ago Author Posted 2 hours ago (edited) Thanks, yes I plan to use the PD16 and replace the entre body wiring harness. I started the engine harness build and it has been slow. I designed and printed a mount for the R3 and PD16 for under the dash and have a 61pin connector that will have all the engine functions and another lower gauge wire connector that will carry all the PD16 body functions forward (lights, horn etc). I'm only cuttting holes for the connectors in the firewall heater blanking plate so I'm not cutting into the firewall. I'm about 2/3rds of the way through pinning the ECU side of the connector. I'm gong slowly and documnting as well as checking continuty back to the ECU connector as i go. I bought the universal Haltech R3 and PD16 harnesses so they are color coded and super easy to work with in the NSP software and on the bench. I am including wiring for sensors and funcions that I dont have but may put on later like electric water pump, brake and fuel pressure sensors, extra signal grounds, etc. My only real concern is building this harness and sealing it up and then decide I want to add something later. Scott 2 hours ago, redursidae said: Would love to hear about your experience with the harness build. Are you going to be using the PDM as well in this round of upgrades? The Haltech DBW is the most foolproof I’ve tuned with, calibrate, adjust Integral gain a bit, and done. Truly amazing. Nice job with the designs. Edited 2 hours ago by Scott_
