I've had these in multiple Triumphs and MGs (and Miatas)  So a spare pair sitting around is no big deal.   I use to simply say I liked the built in headrest speakers.
Well while high up on a shelf in the larger toy room, I pulled out my measuring tape, wondering how wide the seats were, WITHOUT the hinges.   Well for the Rotus,
unbolt the hinges and the back fits!  Snuggly.  Will not move quite as easily as  the oem back does.
Now the seat bottom does fit too! REAL tight without removing the metal hinge,...you;ll need to play with the bottom  seat pan just like in a Spitfire.
so...    jfft       (yes. the Miata seat is very faded)
Edited by ptegler
spelling
  • Like 3
You can get leather covers for the Miata seatback :classic_cool:
MY Rotus anyway, is spot on 17" Miata seat base pan is 16.25" +/- .2"
I think Roti were made a little wider than Cat-Loti
Do you need to try CSR seats in yours?  I can swing by and let you try my squibs.
Would love the in person comparison, even if just side by side looking over both vehicles.
I'd restored this Rotus to as original condition as possible, being it was still mostly still all as built, and bringing it home back to MD.
But that mind set is now changing.    Seat wise, and considering what I've already spent, the Miata seats on the shelf were simply a super cheap alternative to full up Cat seats.
Hmm..... Wednesday, the wife is tied up so my day is free.  (Retired here so all day every day really)
@demoray   made my evening... nice chat
Stunned to find the CSR is nearly identical to the Rotus dimensions.  Wheelbases within 1"  dash cowl edge to seat back top (cabin fore aft) and even their rakes, are nearly identical.The Rotus nose is 1" further forward. But the CSR bonnet is nearly  9" shorter than the Rotus.  ( test fitted the CSR on the Rotus). Rotus is longer outback with it's full depth boot.  Both run inboard shock configurations.
We found the CSR is 17" wide across the seat base as well.  The CSR seats will fit a Rotus
...fun night.
Edited by ptegler
  • Like 6
Given Caterham didn't start making the SV chassis until 2000, I was surprised how close the two cars are in many of the base dimensions.
Also, I've got serious shop envy going on.
@demoray...  my buddy you met at the T.S. Street Survivors show says yes, there is a show Oct30. (Vet show still on 11/8)
I'll be there by 2:30 or so.   would be great to test compare some more stuff.
I'm wondering since the cockpits were so similar in size, would be interesting to see if the doors fit both vehicles.
I'm pretty sure the roof will not,... my longer rear boot compartment etc.
what a diff a little chrome makes
I'm traveling for work until Saturday, so I'll miss it.  Happy to meet up on Sunday?
missed this message myself...went leaf color bike riding on the 'Rails and Trails' rail line from Cumberland to Frostburg with the wife.
Stupid stuff on my part with the car going Friday.  ...never made that either.
Sunday could work.  Can shuffle a couple project time lines.  :-)
Well after cleaning up the Miata seats, realizing a couple of short feet (vs oem slides) would set the seat bases, so over all, no mods except hinge removal, I've decided to stay with the oem seat arrangement.   Yes I like the Miata seats, and the bases give better for/aft retention than the oem Rotus seat bases, but something inside me just wants to stay 'old' skool'.
So what do I do... wife agreed the interior was just a bit 'plain'.  So... matching the newer steering wheel (as close as possible) wood center console with some chrome, brightened up the interior nicely I think.
the console is simply a piece of thin 'big box store' laminate flooring. The 'chrome' is actually C channel aluminum, simple crimped ever so slightly and just wedged onto a custom width cut piece of the flooring. (~1/4" thk)   A light scotch bright scrubby, and several coats of hard clear coat (designed for car wheels) and it matches the sheen of the new steering wheel.  Perhaps missing just a tad shade of red for a perfect steering wheel match but close enough.  Still waiting for the new hand brake boot and trim ring.  The shifter and brake handle trim rings screws will be all that's needed to hold it in place.
The orig design was to leave a cut out for an IPhone in between the brake and shifter, with a simple piece of captive elastic band to retain it. But the way phone change size.... I said screw cutting a depression out.
I find it so weird that cell phone cameras do not appear to see colors correctly, based on light and material.  I have a blue Spitfire that no photo shows the color accurately regardless of light. The last wood steering wheel looked too light and red in pics, and here, the wheel looks too red, and the center console board too light.
yes... the various filters on the camera do not help. The screen simply never looks like the color in person.
live and learn
so...too far as usual?
jfft   ymmv
ptegler
Edited by ptegler
spelling
