This looks promising... Due for release this December
http://www.racepak.com/IQ3Dash/
It's by RacePack, the MSD people...
It has built in GPS and 3 axis accelerometer as well.
$1395 for the unit. If you don't use their existing data acquisition stuff, you can buy sensor packs from them. No price on that yet.
It also says "EFI Version" is coming soon. If that interfaces with OBDii, I'll jump with joy.
http://www.racepak.com/IQ3Dash/images/iq3_package.jpg
WOW! worth reading the spec.
Awesome!
I have the Motogadget Classic. I use it strictly as a tach, speedometer, odometer, and for some warning lights, but it is configurable for water and oil temp, oil pressure, etc. The readout for those items (and a few others) appear in the LCD window. It also has a gear indicator for those of you with a sequential shifter (although I glance at it occasionally myself )
A few downsides:
- You can only monitor one external sensor reading at a time, which means you need to toggle through screens to see everything.
- The contrast on the LCD screen could be better. Consequently it is a little harder to read in some light conditions than the Spa Technique unit it replaced
- The speed and odometer readouts are the same size. It would be easier to quickly read the speed if that was the larger of the two.
http://www.motogadget.com/de/graphic/msc/msc_0009_300.jpg
Over all though, I am very happy with it. Probably not quite what you are looking for, but it might be of interest to others.
FWIW, I think Killboy (who's pretty serious about the gear in his EVO "company car") uses the AIM.
And I think Chet Galek might import that ETB unit. Chet does the Fisher Fury here in the states (out of NJ).
