Well I guess sooner or later it had to happen..... When money is no object.
http://www.usa7s.com/aspnetforum/upload/11196014_1.jpg
http://www.rsperformance.co.uk/
RS Performance ‘Levante’ Technical Specification
Price £POA A Sh!@#t Load, I'm guessing
Chassis Caterham SV
Engine 2.4-litre, 40-valve RST-V8 supercharged
Max Power 500+ bhp @ 10,000rpm
Max Torque 300lbsft @ 8500rpm
Supercharge boost 0.8 bar = 11.6 psi
Gearbox 6-speed sequential with paddle shift option
Transmission LSD
0-60mph under 3 sec TBC
Top Speed 150mph (limited)
Wheelbase 2315mm
Overall length 3300mm
Overall width 1685mm
Height 1015mm
Ground clearance 120mm
Weight From 520kgs = 1150 lbs
Suspension Front is FreeStyle Rear is Dedion with Nitrons 3 way
adjustable shocks all round
Wheels Image Billet, Front 8 x 15 rear 10 x 15
Tyres Avon CR500 Front 195/45/15 – Rear 245/40/15
Brakes Hi Spec - Front 280mm vented. Rear 260mm.
Exhaust system BTB 2 x 4-2-1 rear exit
Dashboard Farringdon and SPA design
Driver aids Traction Control, Launch Control
2 day driver training course provided on delivery of vehicle
Additional features
Pectel SQ6 ECU,
Tracker system & Immobiliser, Fuel tank – ATL Fuel cell,
Auxiliary power plug,
Light weight hosing used on water & oil cooling systems,
Optional mapping with valet mode option
Brake bias adjust,
Carbon fibre interior including
Kevlar seats, Raychem wiring throughout, Engine and supercharger coolers,
8ltr dry sump tank,
Bespoke luggage.
http://www.usa7s.com/aspnetforum/upload/1213270766_2.jpg
http://www.usa7s.com/aspnetforum/upload/1040922293_3.jpg
http://www.usa7s.com/aspnetforum/upload/1252779531_6.jpg
http://www.usa7s.com/aspnetforum/upload/307954737_9.jpg
http://www.usa7s.com/aspnetforum/upload/690212055_12.jpg
I don't even know what to say... Maybe Jay Leno can afford one.
Cheers
7evin
"A Sh!@#t Load, I'm guessing" - I think it was originally priced at 115,000 sterling pounds which should work out to 213,540.43 USD at todays exchange rate. A simple home equity loan and I could have one sitting in my garage! I'd want to change out the headlights and mirrors, but everything else I think I could live with! :)
Bruce :7drive:
Does it look like they copied Brian's design for the scuttle shape? :D
Quite honestly, I wouldn't buy this car even if I had the money. It's a bit gaudy, IMO. I'd just go with a straight up r500 and do the RST or Hartley engine swap.
I wonder what I'd do if I plonked down all that wonga for one of those, pulled up to the gas pump, and had some punter ask "What kind of kit car is that?"
m
I have to agree with Al.....and would just buy two r500's one for the street and one for track use and then take a nice vacation with the money saved.
Many years ago I told several people that asked, it took me 2 years to build my Miura S. All thought I was a great builder.
I wonder what could be done to an XR7 for the balance of $168,790.43
I think you would have to equip it with aircraft radios so you could get clearance from launch control for lunar orbit ...
I think if I had that kind of money I would start with a clean sheet of paper and just go nuts..... Probably end up with what they have but abit sicker.... XR7 gone wild...
Cheers
7evin
I would be willing to race one for them..... Could not race it if it was mine.... I would be a total nervous wreck...
Cheers
7evin
