Some EXP. aircraft have piano hinge style hinge latches. All you do is pull the hinge wire out each side of the hood and lift the hood off. This set up can follow a flat contour. On my RV-4 the hinge pin has a hand ground point to follow the radius.
I have the Protex 27-1162/SC with the 613/7 SS locking pins. I like the fact that they have a locking latch and can take a pin as back up. Shipping a new bonnet from England is expensive!
http://www.protex.com/images/product/large/27-1162%252FSC.gifhttp://www.protex.com/images/product/large/613%252F7+SS.gif
Gary, do you have a picture of these? or a link?
Slingsht, here are some photos. More can be found if you google: vans rv hinge.
http://www.vansaircraft.com/pdf/revisions/RV-12/29-02.pdf
http://www.dualrudder.com/rv7/category/finishing-kit/cowl/
http://forums.matronics.com/viewtopic.php?t=63166&sid=bef7c9f8e58fbefd8adbe3762992418a
You can find them for sale here:
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1255367369-486-624&action=search
http://www.aircraftspruce.com/catalog/appages/aileronhinge.php
Another option
http://www.aircraftspruce.com/catalog/hapages/camloc2700.php
http://www.aircraftspruce.com/menus/ha/fasteners.html
The cam locks should be installed every 3" if you go that way.
The piano hinge is not visible to the outside seam. You need to just pull the hinge pin that is made of stainless steel wire. Mine has a eye bent on the end that I unscrew an anchor screw to keep it from moving FWD to the prop. I then just pull it FWD with pliers. As you can see from the photos most use counter sunk rivets to fasten the piano hinge to the cowl. Some people pull the wires to the rear from inside the cabin.
enjoy
After LOG in Birmingham .. and seeing all the Cats with spring-loaded, stainless-steel, Terry Body latches in the front .. I bought a set off eBay for a reasonable price and installed in the front of the hood on my car. I still have the traditional tension latches in the back .. Of course I would have preferred the latches which can be secured with a cotter pin ..
UPDATE: I see the same "Terry Body Latches" on that Pegasus page ..
Rob
Edited by solder_guy
The ones that came on my car are much like what Jerry has on his Ultralite (3045).
On mine it has an adjustable screw head, not a latch; sticking up to fit into a slot mounted on the top half. The slot has a dimple for the latch screw head to fit down into. There is a small locking nut on the bottom of the screw; I think it is a 4MM nut. There is a little lock button that you need to raise prior to unlocking the latch. The latch is small and works very well.
I have no idea where to get them as there is no marking on them. I didn’t build the car.
Gary
Gary
I agree with Gary. Mine is the same design as his, it works very well, and is the stock latch that came on my Birkin. Maybe they are available from Dick Brink.
