Happy Thanksgiving Weekend,
It has been a while since I updated my car photos, here is where I am at.
Glenn
Wow, nice se7en. I love your wiring. Makes my wiring look like a rat's nest. Are you bringing intake air in from the cockpit? If so isn't that going to be a bit noisy? Russ
Damn fine wiring job, Glenn! Great progress. I second the notion that she'll be a little noisy with the intake taking air from the cockpit. Not that it's a bad thing because I happened to like noise. :D
Hi Scott,
The wheels are Pacer 107p, I saw them used on #24. Plus the wife liked them. I drove Mark Scott's car with the intake located in the cabin in a similar fashion, and did not notice any noise issue. Time will tell.
Glad you to have most of the wiring behind me. One thing I should have done prior to powder coating was weld or braze a few chassis ground lugs on the car. Would have made things much simpler. Thanks for the thumbs up on the wiring, I really worked hard not to have a spaghetti bowl. If nothing else, I know were every wire goes if I have to trouble shoot.
Glenn
Dean,
Most likely will not be till spring. Weather is starting to turn here, so I will take my time. I plan to get it inspected and titled over the winter. I have enjoyed the build, but am at a point where I now want to drive it. If it drags on too long I may have a friend take it and finish it up for me. Every time I seem to get on a roll, life gets in the way.
The kids are anxious to be taken to school in it, and attend some local car shows.
Glenn
"Every time I seem to get on a roll, life gets in the way." - I definitely know how you feel.
Keep up the good work Glenn, your car is looking great!
  • 1 month later...
Here is my list to finish this thing in no particular order –
1. Select and Mount License plate holder.
2. Select and Mount Taillights.
3. Machine Third Brake Light Mount, and Install.
4. Add a Rear Grounding Point.
5. Finish Tail End Wiring.
6. Install Seat Harness Trim.
7. Fender Welting.
8. Tach Backlight Repair (second time and a PIA).
9. Shifter Boot.
10. Shifter Knob.
11. Thigh Support for Seating.
12. Crotch Belt Mounting both Sides.
13. Rear Fender Fill Blocks.
14. Exhaust rubber mounts, clamp rear tube.
15. Two Nuts on Driver side header.
16. Front light wiring completion.
17. Front light wire loom.
18. Front Ground Point.
19. Cooling Fan Relay.
20. O2 Sensor.
21. Front Grill Screen.
22. Lower Hood Pin swapped.
23. Hood Prop.
24. Tighten all Fuel Line Fittings.
25. Replace two lower Rad Rod Bolts with longer Bolts.
26. Seats.
27. Tonneau Cover (Like Jack Banker and Mark Scott).
28. Paint once titled.
29. Add Oil to Rear Differential.
30. Add Oil to Transmission
Fuel Pump is working wired it today. Was tempted to add fuel, but figured I needed to check lines first and add the other Oils.
Glenn
  • 1 month later...
Finally got the lights completed today. Got the side view mirrors on also, they turned out great.
Got it started this afternoon. Had a few silly things to rework, but once I sorted it out, it fired for the first time in two years.
GB
Nice car. A great use of lists.
I wish I could be that organized. I guess I am rebelling from my professional life which is well ogranized
GB
That is sweet....wish I had a supercharger on my car.
