Kitcat Posted April 11, 2011 Share Posted April 11, 2011 My Cat has sprung a heater hose leak that has grounded me. Its one of the two, short, angled hoses the enter the heater box. Since my car is 14 years old, maybe 10 years wld be a safe time to routinely replace these? I have patched it and it's semi-functional but I wont be taking any long trips til replacement hoses are found. Mike M. Link to comment Share on other sites More sharing options...
yellowss7 Posted April 11, 2011 Share Posted April 11, 2011 Mike, Caterham UK has them in stock, as I recently oreded them. Shipping is the downside. Maybe you can order them through Cat USA and hopefully save a bit on the shippping. Tom Link to comment Share on other sites More sharing options...
Boxologist Posted April 11, 2011 Share Posted April 11, 2011 if u have a good autoparts store, the ones w/ teh back storeroom that bigger than the rest of teh store, u can usually find something of the shape u need to be cut down to the length u need. Link to comment Share on other sites More sharing options...
supersportsp Posted April 11, 2011 Share Posted April 11, 2011 I just replaced both of my heater hoses last fall as they had become cracked. They aren't cheap, but Ben actually had some in stock in Denver. $70 was the damage for both I think. Link to comment Share on other sites More sharing options...
Sabbot Posted April 11, 2011 Share Posted April 11, 2011 just a heads up I'm in the pocess of ordering top and bottom radiator hoses from Caterham USA (Jon indicated that he has them in stock). My car is ~13 years old and I doubt that they have been replaced. I just noticed that the bottom hose had started to crack around the water pump mount. I figured a little bit of preventative maintenance was better than being stranded. Link to comment Share on other sites More sharing options...
Croc Posted April 12, 2011 Share Posted April 12, 2011 Mine lasted all of 5 years before being replaced in early 2009. Consider yourselves lucky to get over 10 years life out of them. Have you checked the fuel and cooling hoses? These are prime candidates for cracks, splitting and failing... I replaced all my hoses at the same time as they all seemed to be in the same worn condition. Link to comment Share on other sites More sharing options...
Kitcat Posted April 12, 2011 Author Share Posted April 12, 2011 Croc: All the mentioned hoses have been replaced- after they failed:). Only hoses left were the heater hoses, wh/have now failed. And the oil cooler hoses. I will quit tempting fate and replace them now as well. Mike M. Link to comment Share on other sites More sharing options...
