stevet Posted June 22, 2007 Posted June 22, 2007 Carbon fiber, copper, brass and tin... http://www.usa7s.com/aspnetforum/upload/1594319502_seven by freya.JPG
11Budlite Posted June 23, 2007 Posted June 23, 2007 This is what I've changed so far: Jenvey throttle bodies K&N air filters Emerald ECU Raceline water rail Esslinger UDP and cam pulleys ARP rod bolts, cam bolts, and flywheel bolts Oval Craft breather tank Fuel Safe fuel cell plumbed with 3/8" stainless hard lines and AN6 braided lines Walbro fuel pump with AN6 fittings Canton Mecca fuel filter with Russel pre-filter Swapped VDO ammeter for voltmeter and added VDO oil temp and vacuum gauges Rewired Birkin harness and added additional fuse block and shift light Woody Harris' reinforced lower control arms with upgraded ball joints Woody Harris' rear trailing arm kit with heim joints and 175# rear springs Oil pressure gauge line replaced with 1/4" stainless hard line and AN4 braided lines Oil pressure warning light set to 20psi BGH geartech sporting close gears in T9 tranny with Quaife cover Odyssey battery, Magnecor spark plug wires Geo alternator mounted on intake side with Pete C's bracket Insulated driver and passenger footwells Spa mirrors Red powder coated cam cover off of e-bay for $35. My best deal yet and it matches the TB's! That's all I can think of off the top of my head. What I might do in the future: Upgraded cams and head Lowered floors Side exhaust Quaiffe LSD Lighter wheels, stickier tires It's not just a car, it's a hobby!! Bruce
yellowss7 Posted June 24, 2007 Posted June 24, 2007 Mine must be the only one on here that is Stock. That means I ordered it Right! :hurray: 2000 Superlight #123 Ferrari Yellow 1.8L K series motor 196 bhp Dry sumped Piper verniers Jenvey DHTB with Carbon trumpets 4-2-1 side exhast 3.62 AP suretrack LSD Caterham 6 speed race starter MB magniesum wheels FIA Roll bar oil temp/ water temp switch Cabon Dash Carbon stoneguard Carbon side mirrors 280mm suede Momo with Quick release Ali radiator AP 4 pots with vented disc up front Adjustable spring perches Wide track front suspension And was the first to order Clams with the wide track I haven't found the need to change anything It's Perfect.:thumbs: Tom On second thought I shouldn't have ordered the heater.
MHKflyer52 Posted June 24, 2007 Posted June 24, 2007 Nothing like the above posts until you consider my car started as a dead and ready for the junk yard MGB and now has been brought back to life as a Replica of a Lotus 7 or Locost 7 and by no means as low-cost as the book said it would be in the end but still a lot of fun and it dose not even look like an MGB or run like one. It runs better and the smile is much greater.
Al N. Posted June 25, 2007 Author Posted June 25, 2007 Mine must be the only one on here that is Stock. That means I ordered it Right! :hurray: ....On second thought I shouldn't have ordered the heater. Dang, Tom...that was certainly a very high initial spec! Orange was already assembled, so I didn't have much choice in what I got.
yellowss7 Posted June 25, 2007 Posted June 25, 2007 Al, Once I decided I wanted a 7 I think I read everything ever written about them. After about five years of research, I was ready to order. At the time, the superlight SLR was the top spec. So I ordered it that way. Then while waiting for delivery the R500 spec came out. :crazy: I was crushed. There was a faster version. :ack: But then I saw that the R500 engine required a "refresh" after around 3000 miles :crazy: :crazy: And after driving mine, I don't think I could handle another 40+ HP. I can't imagine the new Duratec engined 7's with 260-300 hp. I guess that power helps with the top end on the track. For autox it seems like overkill, at least to me. I guess I did make one addition, THE SLICKS. Now that really transformed the handling. If you think a seven handles well on street tires. Try a set of slicks. Shame they don't make street legal slicks! Tom
