How have you modded/upgraded your Se7en...
Al N.
Carbon fiber, copper, brass and tin...
http://www.usa7s.com/aspnetforum/upload/1594319502_seven by freya.JPG
:D
This is what I've changed so far:
Jenvey throttle bodies
K&N air filters
Emerald ECU
Raceline water rail
Esslinger UDP and cam pulleys
ARP rod bolts, cam bolts, and flywheel bolts
Oval Craft breather tank
Fuel Safe fuel cell plumbed with 3/8" stainless hard lines and AN6 braided lines
Walbro fuel pump with AN6 fittings
Canton Mecca fuel filter with Russel pre-filter
Swapped VDO ammeter for voltmeter and added VDO oil temp and vacuum gauges
Rewired Birkin harness and added additional fuse block and shift light
Woody Harris' reinforced lower control arms with upgraded ball joints
Woody Harris' rear trailing arm kit with heim joints and 175# rear springs
Oil pressure gauge line replaced with 1/4" stainless hard line and AN4 braided lines
Oil pressure warning light set to 20psi
BGH geartech sporting close gears in T9 tranny with Quaife cover
Odyssey battery, Magnecor spark plug wires
Geo alternator mounted on intake side with Pete C's bracket
Insulated driver and passenger footwells
Spa mirrors
Red powder coated cam cover off of e-bay for $35. My best deal yet and it matches the TB's! :)
That's all I can think of off the top of my head. What I might do in the future:
Upgraded cams and head
Lowered floors
Side exhaust
Quaiffe LSD
Lighter wheels, stickier tires
It's not just a car, it's a hobby!! :D
Bruce
Mine must be the only one on here that is Stock. That means I ordered it Right! :hurray:
2000 Superlight #123
Ferrari Yellow
1.8L K series motor 196 bhp
Dry sumped
Piper verniers
Jenvey DHTB with Carbon trumpets
4-2-1 side exhast
3.62 AP suretrack LSD
Caterham 6 speed
race starter
MB magniesum wheels
FIA Roll bar
oil temp/ water temp switch
Cabon Dash
Carbon stoneguard
Carbon side mirrors
280mm suede Momo with Quick release
Ali radiator
AP 4 pots with vented disc up front
Adjustable spring perches
Wide track front suspension
And was the first to order Clams with the wide track :cool:
I haven't found the need to change anything It's Perfect.:thumbs: Tom
On second thought I shouldn't have ordered the heater.
Nothing like the above posts until you consider my car started as a dead and ready for the junk yard MGB and now has been brought back to life as a Replica of a Lotus 7 or Locost 7 and by no means as low-cost as the book said it would be in the end but still a lot of fun and it dose not even look like an MGB or run like one. It runs better and the smile is much greater.
....On second thought I shouldn't have ordered the heater.
Dang, Tom...that was certainly a very high initial spec! Orange was already assembled, so I didn't have much choice in what I got.
Al, Once I decided I wanted a 7 I think I read everything ever written about them. After about five years of research, I was ready to order. At the time, the superlight SLR was the top spec. So I ordered it that way. Then while waiting for delivery the R500 spec came out. :crazy: I was crushed. There was a faster version. :ack:
But then I saw that the R500 engine required a "refresh" after around 3000 miles :crazy: :crazy: And after driving mine, I don't think I could handle another 40+ HP. I can't imagine the new Duratec engined 7's with 260-300 hp. I guess that power helps with the top end on the track. For autox it seems like overkill, at least to me.
I guess I did make one addition, THE SLICKS. Now that really transformed the handling. If you think a seven handles well on street tires. Try a set of slicks. Shame they don't make street legal slicks!
Tom
