Everything posted by SK400
Standard duratec uses grade 6 NGK plugs I believe . Caterham recommends grade 7 for the r500 spec. I now use grade 8 and did the tuning using 8, cooler plugs. as for advance, unsure if Steve played with it honestly but could be wrong. We discussed it. I do know he focused on fuel across the range. proof in the pudding will be this summer. Will be inspecting the plugs on a regular basis.
Friends, Its has been a while since I've reported on progress on this topic. I took a day off on Friday, and my son and I spent a long morning at RM Motorsports (www.rmmotorsport.com) in Wixom, Michigan, for a Hub Dyno and fuel mapping session with Steve Boughton from SBD connected remotely. The goal was to identify potential lean conditions and adjust the fuel map to eliminate risk of auto ignition, burning the plugs and putting at risk the engine. It was a successful day. We had 3 computers going, one for the dyno, one for the fuel mapping connected to the ECU and Steve Boughton connected remotely controlling the Esimap 6 software, and one to connect with him via google meet in England. Overall Steve found the map to be a bit lean at mid range under load which might explain some of the challenges Simon and I had with some of the plugs. Steve did a great job smoothing the map and setting parameters to be slightly on the safe side. I've also installed a wide band O2 sensor that will adjust fuel plus or minus 4 percent in a closed loop system with the new MBE ECU. In terms of horsepower, the new R500 spec / blueprinted engine managed 235 hp at the wheels so 260 hp at the engine at 7950 rpm - 8000 rpm almost on the nose assuming a 10% transmission loss, 160 ish ft-lb torque at 6000 rpm, which is exactly what I thought we would get with the build specs (Kent Tec35 cams, Supertech pistons 12.5:1 compression ratio, fully ported head with 35% more flow than original head, custom oversized exhaust, 4-2-1 configuration, design from Dave Hershey engine). I've attached one of the HP graphs. Weighted the car at 1214 lbs, wet, with the Apollo wheels and Avon DOT tires ZZR A24 compound tires, or 1174 lbs with my Image Wheels and Avon full slick Kevlar tires. Happy to say that the car car bare the R500 name officially. I hope all of the above helped the car so that I can drive with confidence this summer, on roads and on the track, terrorizing pretty much anything road legal. Btw - the guys at RM were loading up their 53 foot long trailer with 8 cars to go to Sebring this week. Insane cars such as March 73S, Lola T70, Chevron B23S, formula 3 etc. Really impressive racing stuff. Clients are from all over the country. They have one of Ken Block's car at the shop too and a few Ligier Carbon Fiber F3 for sale. Awesome place. Highly recommended. Run1 Graph HP over RPM.pdf
Something seems off. What gearbox do you have if I may ask? Typically, peak horsepower for the r420 cams is at 7,100 rpm, so surprised the peak on the graph seems to be before 7,000. i did not dyno my car before adding roller barrels unfortunately but with the roller barrels, 6 speed gearbox, and the Caterham ECU, my car dynoed at 198 hp or roughly 200 hp at the wheels. The roller barrels made a difference but not more than 10 or 15 hp (felt it at top end). i ll try to find an old post on this forum where I had included a few dyno charts.
This is Star Trek stuff. How are you able to see all of this from the pictures Dave? From now on, you shall be known as Dr Plug. Yikes on the engine blow up Bball. Really nasty and very unfortunate mistake from the attendant. Sorry to see this. Makes our stomach turn. Carl - yes agree on the latest plug I’ve been using. They are the competition ones and these extend further into the chamber and have a longer ceramic nose. I plan to change back to B type NGK plugs that are shorter, with a protected ceramic nose, and perhaps go for an even colder plug, B9EFS. I’m also scheduling a road dyno tuning session and will have SBD connect remotely to fine tune the map, advance etc. Let’s see. I will keep the group posted. thanks all.
Thanks Dave Steve B from SBD is surprised and does not think this is the result of auto ignition. He states that he runs 13:1 on 98 RON / 93 octane with no real issues. On the other end, NGK had a closer look at Simons plugs and suggests that it is auto ignition or hot spots in the chamber. We will probably try a combination of mods e.g. grade 9 NGK plugs B9EFS that have a more protected ceramic than the grade 8 competition ones we are running and perhaps a bit of octane boost and yes, fuel mapping tuning. Perhaps one change at the time and see. I do agree Dave that WOT condition seems a bit lean but again Steve suggests that the spark plug “lean looking” color is quite normal when ones drives these race engines flat out.
Thanks Tom. I think I ll give the Sunoco GT 100 a try. Here are some of the pictures. Grade 8 spark plug cathode melted after track day (Simon’s). I had the same happened to me with grade 7 and street driving. And grade 8 spark plug after 15 minutes of use. The ceramic is sparkling white.
Thanks all for the thoughts and comments. As you said, I think it is a simple octane increase solve. I might be right at the limit of auto ignition for NA pump fuels so a little octane help wi go a long way. im looking at the Sunoco 260 GT fuel. Anyone has experience with this fuel? Any other equivalent fuels or brands to recommend? thank you
Thanks fastg. Good advice on oxygenated vs not. The car has soo much power already, no need for more honestly. (Yes.. I said it, Croc). Engine spec was designed with EU builder and we did discuss EU vs US gas pump risk, understanding that we might be at the limit. I guess we now know the answer to that question. Simon had the ECU tuned remotely with Steve from SDB (not dyno, but road tuning using car lambda, connected to Steve in the UK via WIFI .... pretty cool) which had a massive - massive - impact on power, torque and drivability from our stock Caterham R500 fuel map. Steve added a lot more fuel than what the stock Caterham R500 map recommended. We both have the same SBD fuel map now (not lean anymore), but still burning plugs after flat out track days. I guess we need to upgrade to 100 octane and redo / refine the map again. Nice winter project!
Thanks Mike Simon also detonates and burns plugs (exact same engine) but his real issue is different. He keeps a picture of me on his dashboard and he is still trying to beat my TBolt time. His engine had to give up to give him an excuse. He is pulling his engine apart as we speak trying to figure out root cause. Oil / lubrication on #1 Conrod bearing is an hypothesis. Sorry Simon, I’m sure sure your ears are burning.
Greetings everyone Long time no talk. Lots going on in MI since I moved here.. a few developers are building a new race track 30 mins away north of Ann Arbor, MI, in Howell, MI, with garages etc. Motorsport Gateway. Check it out! https://www.motorsportsgateway.com/ . Opening should be Spring of 2023. Might be an FIA grade 3 or 2 track with tons of runoffs etc. Really look forward to seeing this project come alive. On a very separate topic.. as some of you know, I have a new blue printed R500 spec engine that is a complete fury but I keep melting the tip of grade 7 and even grade 8 spark plugs indicating auto ignition it seems (not good). The engine compression ratio should be right around 12.5:1 .. but perhaps slightly north of this given a few other head and block mods (squish gap etc, but not more than 12.75:1).. hence very limit for 93 octane street / pump gas I assume. Just wondering, if we had to buy race fuel, what would you recommend? 98 or 100 octane? if so, unleaded standard or unleaded oxygenated? what's the difference? Would you recommend separate octane additives to regular 93 octane pump gas? if so, what brand or product would you recommend? Thank you all
New Birkin representative for eastern USA
SK400 replied to Tbox56's topic in General Sevens Discussion
Cade - very good meeting you earlier today in Detroit / Farmington Hills . What a coincidence and surprise. Look forward to building a great community of "Sevens" in the area. Don't say it too loud but let's show those big V8's what small 4 (or for some 6's) can really do. See you around on a track... and soon I hope. Seb -
Yep - Got the westermann wingstay. saved 1.4 kg of weight from original wingstays.
Really good to see that the gang had fun as usual. Missed you guys this year.... will try next year!
2021 Annual USA7s Event with NJMP Drivers Club - September 19/20
SK400 replied to Croc's topic in National Events
No pictures yet? How was Sunday? -
Guys. Good luck this weekend with the event. Will miss you dearly. Will try next year. Have fun!! -
Thanks guys. Might be a bit far for me and still waiting for a trailer that I ordered in .. January. Looking to try Grattan or Gingerman or maybe mid Ohio this fall.
Thanks for the wishes and the tips guys! Croc - clearly miss the East coast gang but will see each other again. I’m sure of it. Still have to show Simon who is the real slim shady. Dave, MoBoost, would be terrific to connect over the next few weeks as convenient. Let’s PM one another. Looks like South Lyon and Canton are not too far from one another. mid September? Wouk also love to hit one of the tracks this fall. Let me know if interested. talk soon! seb
Well, as some of you know, I recently moved from CT to MI, Ann Arbor. I had all of my cars transported 3 weeks ago and finally went for a first short drive with my caterham yesterday zipping around some of the country roads around here. Clearly a lot of car enthusiasts around with many thumbs up etc… was great to feel the wind in the hair, finally declaring and officialising the move to MI with this short drive. i plan to hit a track or two perhap in September if time allows. I ll keep you posted. Reaching out to any other caterham enthusiast in the Ann Arbor region, if any! Talk soon Seb
The parts have be sold. Thank you
I have a brand new set, never installed, CSR style carbon front cycle wings and rear fenders for sale. Please PM me if interested. thank you.
Honestly and if for track only, the Avon full slicks with Kevlar belt construction are …. unreal. I have them on my new image wheels and dropped another 1.5 secs at thunderbolt from my a24 and I’m far from the tire limits. Roger Kraus will know exactly what tires these are. They fit our 13” front and back caterham wheels perfectly. They are also 9 to 10 lbs each … only.
For what it is worth, the A24 ZZR tires are absolutely outstanding, some of the best DOT approved / race compound tires on a Caterham. I think I took 1.5 secs off Lightning changing between the A64 and A24. They do wear quite a bit faster though.. especially when scrapping through the bowl !! A stock R400 on A64 at limerock will run in the low 59s. With A24s, managed 57.8s..
Quasi new 15” wheels and CR 500 tires for sale
SK400 replied to SK400's topic in Parts For Sale / Wanted
The quasi new wheels have been sold and will go to a good home. -
Two potential issues from what we've gleaned from other members going through this experience as we speak... 1) there is apparently a special map for more modern caterhams that have an external fuel pump module somewhere in the rear. For those catehams, apparently you don't need the green injectors, the blue will suffice. 2) there might be a wiring harness difference between your more modern caterham and older ones. Number of active pins etc. Looks like you don't have the right map on your ECU.. either because of the fuel module feature (sending way too much gas that it needs to) or the wrong map for the wiring harness you have. Blake, Simon, and others I'm sure can opine..
