Everything posted by papak
What is the lowest profile scissor jack? I'd like to pick up a used one for longer trips.
Aren't they treated as motorcycles for licensing?
I went this morning and was the only 7 until a Superperformance showed up late. Some nice iron! One guy even had plates for his Lotus 23. It was my first true blat since completing the car. Its worth getting up that early to avoid the traffic and enjoy the unencumbered ride up PCH. Now I'll start branching out more.
Are you doing this with the engine installed in the car? If so, you would probably want the factory tool, a rectangular steel plate about 20"x4". It is drilled to accept two large bolts (nominally 1/2x4") that fit between the webs on the pulley. The other end has a ½" square hole for a breaker bar. This would hold the pulley and relieve the pressure on the alignment bolt on the nose of the engine while you apply torque to the crank bolt. I have one if you need to borrow it. If the engine is out of the car and the bell housing is removed, Go to a VW parts shop and purchase a flywheel holder. Shouldn't be more than $10. This will bolt to a bell housing attach point and it's teeth will lock the rotation of the flywheel. It's not a perfect fit but it works. As an old FV racer, I had one in the bottom of the drawer.
If I connect a laptop, we can monitor TPS in real time as well as injector pulse width, lambda and anything else there is a sensor for. The problem we have is that road performance under load is not showing any TPS signal. What differences did you encounter with the P&G?
I'm throwing this one out to the brain trust. I have a Typhoon ECU on a 2.3l Duratec with Jenvey throttle bodies and a Colvern 17 TPS. When we calibrate the TPS with the engine off, it is perfect (It should be as it is new). When we record an engine run for later analysis, the recorded TPS data shows 0. Performance wise, there is a clear problem coordinating throttle position while running. I have heard that the Colvern TPS is known to have several failure modes. I have verified the wiring continuity. There is no unusual heat source affecting it. No adjacent wiring to cause interference. Is there a better alternative TPS? The Standard TH 265 could work with some modification. Any ideas?
The Ford part number is D4ZZ-7600A.
I seem to recall getting one for my 2.3l from Rock Auto pretty cheap.
Always available. Just drop me a line here. It should be back on the road in a week or so.
It's ¾"-18. You can get an adapter from Earls or Summit that allows you to use a ¼ NPT sender. In my case, I use this for the coolant temp sender for the electric coolant pump controller.
The exhaust on my Birkin has the O2 sensor mounted midway between the 2 into 1 merge and the muffler flange. I used the orange sealant on all mating surfaces except the slip joints. I plan on wrapping those shortly. The basic programming in the Typhoon ECU adds a longer pulse width under acceleration and feathers it off after you have reached a steady throttle setting. Hence, if you are running rich enough at cruise, you will always run richer under acceleration. Tom Carlin said to try to run a lambda level of .94/.95. Better a bit rich than lean. Get it running as would like with the closed loop disengaged and then activate it. the closed loop has a range of authority of 20% or so. Don't forget to calibrate the sensor first.
He did ask me to start it but I figured it was just to confirm that everything was in working order. The fellow was polite and professional and got me out of there in less than 30 minutes.
The BAR inspection is primarily a visit to the smog referee. They will review (and make a copy of) all of the paperwork that preceded this visit. The inspector will need to see the Sequence Certificate that you receive from Sacramento. They will issue and install a permanent sticker that denotes your smog exemption. They are also looking, in a general sense, at the totality of the completed project. I imagine that they might raise a question if the fenders were falling off or something on that order. In reality, the referee is a faculty member at an automotive vocational school. The fellow who handled my visit was pleasant and professional. He asked for all of the completed, signed forms as well as the receipt for the engine and had me remove the hood to visually confirm that it was as described. The car never came off the trailer. I was out of there in 30 minutes.
Any Formula Ford guys in the area? Pretty similar.
Had the B&L inspection done at Jeniwil in South Central LA. Nice guys, $70 cash and done in 20 minutes. Went through the BAR today with no problem. I get the tags next Wednesday!
Checkpoint doesn't do the B&L inspection. I've worked through the list on the West Side of LA. Most of them only want a chance to adjust your headlights for $100. I may have found a shop in South Central. I'll post late Thursday on the outcome.
I continue to get the impression that there is a great amount of variability in how this process is handled, at every level. It seems that the Cobra forums have a better handle on where the best agency locations are. As for DMV, either the Thousand Oaks or Torrance offices are the most informed. I have made out well so far with Culver City but only because I was well prepared, patient and quietly persistent. The first visit still took 3 ½ hours. On the other hand, they only calculated my registration based on the price of the Birkin kit, not any of the other components or labor. They also gave me a temporary tag. Go figure.
Thanks for the tip on Check Point. I'll give them a call tomorrow. A careful reading of the various state documents online states that the manufacturers VIN, if attached permanently (mine is stamped on a tab that is welded to the chassis) will suffice. On the other hand, the car must be taken to CHP for a "VIN verification". In actuality, they are checking that the chassis, engine and transmission aren't on any theft database. They also have the right to assign a VIN, at their discretion, and attach it to the chassis. My appointment with them is on Thursday. If I can line up the brake and lamp inspection for later that day, I only have the smog referee (Bureau of Automotive repair left. As a footnote, the T-9 transmission doesn't have a serial number embossed on it. The number was on a brass tag that was attached to one of the bolts holding down the top cover. These are usually discarded in the course of rebuilding according to John Esposito of Quantum Mechanics (Oxford, CT). They are the major supplier of T-9s in the US. John gets his cores 8-10 at a time, strapped to a pallet from a disassembler in the UK. Most arrive without tags. I'll let you know what CHP thinks of that later this week.
Can anyone recommend a "reasonable" B &L inspection shop in West LA? I am scarred enough after dealing with DMV and would like to avoid any unwarranted hassles. The inside is that I am #75 for 2017! TIA
I just installed a low profile cam cover on my 2.3 so I now have a standard (COP) cam cover available. This is perfect if you are converting a 2.0 to COP ignition. The contour of the hood on a Birkin accommodates the 2.0l but the 2.3l needs the (pricey) lower profile cam cover (slightly taller motor). I am including a new cam position sensor as well as the gaskets (currently installed in the cover). Low profile oil filler cap as well. $50 plus shipping.
Thanks. Still getting the hang of (or not) of uploading images.
http://www.usa7s.net/vb/attachment.php?attachmentid=12187&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=12188&stc=1 I have a new, unused ITG air filter for sale. It's a JC50-65 purchased from Coastal Fabrication for $128.50 a few months ago. This is the square shouldered model and now that I have mounted the nose, I have a clearance issue. I will need to use the rounded version to avoid cutting the bonnet. Backing plates (blank and pre-drilled) are available separately from Coastal $100 plus shipping. I am in West LA if you want to arrange pickup.
I did the same thing but on the Birkin, the motor mounts were designed for the 2.0l engine. The 2.3l sits about ½" higher in the chassis. The high point of the front part of the cover touches the nose and the riser on the oil filler would have to be shaved off and relocated to the low side at a minimum. Upon looking at it again today, I think I would do better to get the lower profile cam cover from Tom Carlin ($485). The cover offered by Raceline won't accommodate the individual coils. If I go this route, I'll try to modify the old cover as a separate project and post the results.
I have finally resolved my wiring issues and everything works correctly on the Birkin. I installed the scuttle and nose today and realized that the oil filler neck on my Duratec 2.3 protrudes above the hood by nearly half an inch. GRRRR! Has anyone had any success in repositioning the filler neck to the lower side? I presume that the cam cover material is FRP? Can this be successfully epoxied? The alternative is either the cam cover Tom Carlin sells ($485), the Raceline one (similar price plus shipping from the U.K.) or the Caterham one. Are the Mazda covers even on both sides? Has anyone done this mod? TIA
Reloading a fresh base map solved the blown fuse issue. Go figure. Now back to tuning.
