Austin David
  1. Here's a pre-engine photo which shows the older-style "2 brown wires", and also my RHS ground point by the battery. Also this shows I think the first time I had the airbox installed (I'm on #3 now)
  2. One other build oddity: my rear brake hardline didn't align with a hole in the aluminium support. It sort of matches the Ikea manual, which shows the hardline penetration, a lightening hole, then the washer passthrough. On my car there was a hardline NOT aligned with a hole, then the lightening hole. So I had to drill out a new passhthrough fitting. It was fun, as there's basically zero space. To do it again I'd find a right angle adapter.
  3. More photos: the valve arrangement for the heater. My switch/pull is on the LHS, I am planning to route it under the airbox, behind the battery, and doubled over for the valve. It seems to fit correctly and with a tolerable bend radius. The 5/8 tube pictured was acquired locally. I may later replace it with the (much nicer) Caterham tubes, once I sort out what-goes-where.
  4. ha, my bad. Here's a photo of my missing plumbing. The kit came with 4 very nice, branded 5/8" tubes. Relatively short. No J for the submarine (5/8) and no 3/4 material at all. There was some bulk 1/2 and 5/16-- the 1/2 was used to protect the rear brake hose, the 5/16 is perfect for the clutch hose, the rest for the smaller line on the overflow tank. From talking with Josh (therefore indirectly with Caterham) it might be that they intend to splice some of this together, and mostly use the two Ls for the modines. I'm not 100% sold, in that the modines are a full 1/8" larger...
  5. I've got a good week to get there, but I was planning to basically do the opposite of how I got it up there: floor jack under the front to remove the jackstand. I think you're asking where the jacking points are, since your crossmember is occupied? Maybe an extra jackstand on one side rail, under the wishbone, then jack the other side to get that center out of the way. On the rear, I'm currently supported on the frame. Once the front corners are supported I can lift the rear from the dedion center, or just lift at the tube to relieve the stands on each corner. Nice floor. Do you have to protect it from jackstands or heavy things? (my racedeck gets crushed/deformed if I have small enough point loads)
  6. "being creepy" is literally his job. But seriously, uninstall any FB/IG or "Meta"-owned apps.
  7. Back to the build: Other blogs go into the exhaust fit-up. If the alternator is ON, go ahead and remove it. Side note, pretty sure I will have completely assembled this car (at least) twice by the time I'm done. With the alt out, fit 4-3-2 VERY LOOSELY, then carefully snake #1 in. 4-3-2 will go to the bottom corner and that's enough room (with the alternator out of the way) to get #1 in place. The collector wasn't hard for me to fit, BUT the springs were super annoying. I ended up using a set of very long needle-nose pliers to fully compress the springs. I also had to stretch the loops a little so they would seat fully on the hooks; the radius of the loop (as shipped) was WAY smaller than the hooks, which ate up too much space, which prevented me from seating them. Fully compressed + widened loops did the trick. I conveniently have an O2 sensor wrench. If you don't, be sure to fit the O2 sensor to the collector/cat BEFORE fitting the cat to the primaries. There's not enough room to tighten it with a spanner, while mounted to the car.
  8. Could be. This is the closest I've been to a 7 built in the 21s century so I don't have a good basis for comparison. The dash (under it) clearly has both RHS and LHS steering mounts, and the pedal boxes are symmetric on both sides, so I assume that's just designed in. I don't know why the ground strap is on the RHS, that doesn't make sense to me at all. Mixed-up hoses is weird but could just be a picking issue. I am more confused by the scattered 5/8 and 3/4 stuff, with no obvious plan to adapt. Unless there ARE adapters and I didn't get any? Josh indicated there is a change in design and I might be kinda halfway between the old + new? I spent some time with boiling water fitting 5/8 hose on the 3/4 tee. I won't be doing that twice, and definitely won't be trying to snug any 5/8 on the 4 ports for the engine. For now I think I'll just raid every local parts store for their adapters to make it work. If it irritates me enough I think I could have semi-custom silicone hoses made for like $250 (WAG). I'd love to see that, thanks. These look (to my SUPER INEXPERIENCED eye) like "stock" Caterham seats, just a different color. The bottom lifts out of the frame and is leather wrapped around and glued to a molded base. They're very light. I THINK I could cut through the glue and repair it, but I want some miles in them before I start doing anything destructive. The back is zip-tied to the frame, as opposed to hog rings -- no glue in evidence, so it looks like a better candidate for a heater insert.
  9. I have definitely seen ice on the ground in Blowing Rock in April. That's actually my reasoning for not using R compound tyres... BRP is pretty awesome tho. I'll definitely reach out when I'm headed up there next. I think you've got a good case for 3.75 seasons tho with all that extra crap. They're not easy to find, but fleece-lined pants make a huge difference too.
  10. What did you order? If you live basically not-in-FL you want heaters. I've used heated gear on motorcycles, and it is EXCELLENT, but also pretty short-lived. I never really found anything that worked for more than 1-2 seasons, and plugging in (and unplugging) is pretty annoying. I installed heaters in an old MX5 a couple winters ago and it is amazing. Not a single solution, but along with better gear, tonneau cover, and floor heat, it's pretty cozy year-round.
  11. I'm getting REALLY curious whether I got a weird chassis because I ordered slightly weird (360S apparently not common)? Or because it was built during the pandemic which kinda made everything weird, including, like, "let's just frankenstein this together". More insanity: the plumbing is different from the book, which took some back-n-forth with Josh and Caterham to sort out. Even better, I don't actually have all the parts to make the new plumbing. Also my chassis earth/ground point is on the RHS, not the LHS? Fortunately I was shipped what I assume are cables to accommodate either orientation? Oh and I apparently have older-style "two brown wires" for the battery loom and not the documented / newer style of "red B/S under the tunnel." And I'm also missing the parts to finish that off, but those were easily acquired locally. Here's what I got which fit correctly on the first try, as documented or recorded in other blogs/builds: - lower heater hose. Perfect fit. VERY nice hose. - upper heater hose. Will need to be trimmed. This is a VERY thick EPDM hose, has caused problems elsewhere. The shape is right though, I'll figure it out - Bulk 5/16 hose for water rail return -> overflow tank. Fits exactly like in the book and the fittings match the hose. Even after I sacrificed some of it to protect the clutch hose. Electrical: - Long black cable to connect to the RHS chassis earth; routed above the tunnel with the other clips. As others have noted, a few well-placed washers and some cleaning of paint. - Added a long red starter cable, will connect batt + to starter. My two browns go on the starter, per 2015 manual. - cooling (heater bypass) pluming is new. I'm still figuring out parts. I'll follow up when I get it sorted out -- the actual routing is mostly what's in the v2 Ikea manual, if you make no assumptions about actual materials supplied. Here's the challenge: the engine points (the two modine ports, the water rail, and the thermostat port) are all 3/4". The tee provided is 3/4". The heater, valves, submarine, and expansion tank are all 5/8". With a lot of patience and lubrication and dirty talk the 5/8 can fit on those 3/4 barbs, but not vice-versa. I'm not super excited about this. The routing is approximately: 3/4 rail -> 5/8 submarine -> 5/8 submarine -> 5/8 heater valve 5/8 heater valve -> 5/8 heater core (upper) 5/8 heater core (lower) -> 5/8 heater valve 5/8 heater valve -> 3/4 oil filter modine 3/4 oil filter modine -> 3/4 tee 3/4 tee -> 3/4 termostat 3/4 tee -> 5/8 expansion tank. One side of the submarine is a sharp u-bend; an LS heater bypass fits REALLY well. However, my loom wires for the temp sensor are way, way too short. I don't think I could have made them work correctly even if I did have the "hockey stick" hose. Which I did not. I made up two cables to clip onto the heater and sub, with spades to mate properly with the wires on the engine loom. Sub will lurk under the water rail without otherwise interfering. The two modines need 3/4 with a short right angle, and ideally a longish section of 5/8. I think Caterham's updated guidance involves splicing up some shorter tubes, and I assume making the 5/8 fit over all the 3/4 engine-side fittings. If that's truly the case, I figure a 5/8 tee might be a better idea? My heater valve hole was actually drilled in the LHS where it sort of belongs. Would be above my left knee. The cable appears long enough to work correctly from there, with the valve in the standard orientation. I was able to double it over between the battery and heater, under the airbox and over the brake/clutch overflow lines. It looks like I can correctly open/close with pull/push. I've shot the cable full of teflon, as it's getting close to the min bend radius. Other news: I eyeballed my seats. I got "signature" interior (another one of those checkbox-departures from the norm) but I think the seats are normal street / stock seats. The bottom is molded and glued, but the top is more reasonably held together with zip ties. I think I will be able to slip some heaters in there, at least for lower back. Better than nothing! I'm also likely to fit a Stiebel horn; without a dry sump tank up front I have a lot of room for it.
  12. Sorry, I meant transmission. My diff was also dry, but trans was shipped wet. The "earth mod" extra was just a bit of black wire with a ring terminal one one end and the correct pin and seal on the other. Without that it would still be a very easy mod, but would involve cutting the speedo side ground wire and tieing that to the chassis.
  13. Josh recommended building the rear end before mounting the engine. I am guessing this is based on a bunch of experience and probably ~ 1w build times. IF you're gonna do that, I would recommend draining the transmission first. The engine/trans are too long to get into position before mating to the propshaft, which means they'll still be kinda porpoised in place, if aiming down a little. Which means you'll lose some fluid, unless you're WAY faster than a couple first-timers in SC. if you have to top it up anyway, you may as well drain it to save fluid (or at least save your floor and a half-dozen rags), then just refill it later. For someone in less a hurry I don't know that there's a huge advantage to this sequence, vs. mounting the engine first. Certainly by doing the engine first, you leave the plug in until it's all horizontal. Otherwise it went OK. Per the 420 blog I did line the tunnel with cardboard, and I'm glad I did. I would have left off the starter next time, it doesn't get a lot of room clearing the brake master. I used two ratchet straps to help keep the motor aligned (one for keeping the trans up, one for controlling twist). I probably didn't really need either one, in retrospect. More important than those is the leveler, which kept the motor horizontal. Also this is absolutely a 2-person job, and even better with a 3rd -- someone on the hoist, someone on the propshaft, and a runner / guide making sure nothing's getting poked. The trans mount is actually fairly easy to get to from the top, provided the bolts are downward-facing (IVA spec, but counter to the 2.1 instructions). The nuts are still higher than the mount itself, so they don't create any new obstruction. A long T-handle / ball end 6mm is plenty of room to secure all 4 while tightening from the bottom. I have no idea how I would have done this bottom-up, unless I'd mounted the bracket before the transmission. Bolts+washers first, then install the motor, then (while trans is supported on a jack) install the bracket. The whole process took about 2-2.5 hours with two unpracticed hands.
  14. Speed sensor: both manuals (2015 and Ikea 2.0) aren't good. There's a random black plastic bolt + nut in an unmarked bag; the sensor goes through this bolt, then into the rear bracket as pictured. A better set of photos: https://caterham420detailedbuildblog.co.uk/2020/01/25/speed-sensor https://310build.com/speedo-rear-finish/ The "earth mod" wire was in with rear suspension stuff; the plastic bolt/nut was in a sealed pack with a few other assorted things. Instructions are simple enough, once you find them. I did not drill & rivet a new tie bracket, I had plenty of room to line stuff up with existing ties, and still leave slack for suspension travel.
  15. Super helpful, thank you! "obscure" (or equivalent) part numbers in a notebook is a great idea. I've started a running list, added "15mm thin wrench" for brake pads. I also, always, carry a multitool. That set of pliers has come in handy before (as has the can opener; for some reason all AirBNBs seem to have only broken can openers).
  16. Again, more catchup. Before I started, Josh recommended this slightly out-of-order sequence: front suspension, Handbrake cable (keep lever loose for now) Propshaft Diff (biiiig job) Propshaft bolts Rollover bar bolts (also can be difficult: start em all loose and use pin punches to get holes to line up Dedion tube, Rear suspension Rear uprights and calipers <-- I am here Rear ARB Speedo sensor then engine/trans, and interior. based on past experience, the radiator will be darned near last. It's fragile and poking out the front, begging to get kneed or worse. Wings after, for the same reason. To do it again, I'd probably do the front suspension later in the build, just because it makes the workspace smaller (the front wing brackets poke out pretty far).
  17. Sounds like something I just need to play with for a bit before I make a bunch of changes. Like the intake / ITBs
  18. Catching up on some one-off issues as I progress in the build: the rear brake pipe wasn't aligned with the hole in the aluminium brace under the boot. The Ikea manual shows 3 holes: one grommeted for the fuel line, one open, and a 3rd for the brake pipe. All on the RHS close to the shock tower. On my car there was no 3rd (inboard) hole. The center / unused hole was exactly the right size, but about 3" away from where I needed it. I had to make a 3/8" pass-through for the brake hose to meet the rear hard line. In another thread I noted the question about "S" vs. "R" mount locations for the radius arm. My kit has the sport suspension, I use the lower "R" location. Apparently "S" is slightly more comfortable and may also leave some roll steer.
  19. I've got the rear ARB. How bad does it roll, and how much roll steer are we talking? This is a street car...
  20. well, I hope it's a little bit reliable... My kit came with a sort-of-lame scissor jack, but I'm sure it's more for the profile than the weight or aesthetic value. I imagine this (and a comically small lug wrench) were part of the spare tire kit.
  21. Hi all! I'm sorta keeping track during my build, of which tools are more critical than others. Is there a running list of the "must have" (and maybe a larger "nice to have") list of parts to drag around while touring? 5-6-8-10 allen keys, 10-21mm sockets or wrenches, 3/4" sockets... The oddball tool-of-the-day is a narrow 11mm wrench for the rear end links. Wondering if such a list exists?
  22. Josh @ RMC confirmed I should be using the "R" setup. One of those checkboxes was "sport" suspension, so here's another exception to the Ikea installation guide.
  23. Thanks! I moved them down to "R". This old post seems to indicate some roll steer in the "S" setting, which I very much find annoying and definitely would not want in my 7. If I get curious I may move them up to see what it's like; seems easy enough with wheels off.
  24. I'm fitting the radius arms on my 360S and noticed the higher "S" position vs lower "R". I couldn't sort out the difference on my own. Cruising some other forums it seems like the generally preferred option, road or not, is "lower" (R position). Does anyone have direct experience? Or does everyone pretty much just leave them in the "R" position?
  25. Thank you for jynxing my build Fortunately Josh seems to be on the ball, if not at least ultra responsive. Touch wood, I have mostly just had to root through every box 5x to find stuff...
