twnpipe
Everything posted by twnpipe
  1. Mondo, Trailer is 13 ft x 67 inches, I will not be selling it separately. Fits inside standard garage.
  2. SOLD SOLD No Smog required. Located in San Luis Obispo, Ca. for sale is a sorted car, many revisions since this car was the Grassroots Magazine CMC build. 6 Speed, fresh 0 hr.1.8 professionally built Miata engine. Full instruments, include GPS speedo, boost, fuel pressure, boost and exhaust temperature. AEM full engine management which allows infinite control of fuel and air thru your laptop. Roll cage, fire system and race fuel cell. Street registered in Calfornia. APR full carbon fibre wing, panasport wheels. Car was built originally by Grassroots Magazine, ( i have article) then sold to racer in Sacramento after which I purchased it disassembled. Revised the drivetrain to 1.8 and 6 speed with limited slip and also front suspension. Car has street and track windshields and comes with both GRM front seats and race legal seatbelts for driver. Pricing car at $ 15,500 Also have custom light weight single axle enclosed trailer that was built to hold car. It is truck height for low drag and fuel mileage. Ramps, tie downs, vented with back shad and hammock setup inside. $ 2000 for trailer.
  3. Fun video's. What engine's for the 7's? I have a miata turbo in mine and they said they would find a home for me in Vintage racing. Gentleman racing it is. Getting back out shortly on the West coast.
  4. Trailer the car, you don't want to burn up your track tires on the street and you don't have room to carry them and its not relaxing to drive a 7 on the highway. I haven't tried an M3 but would like to for comparison. a 7 is a four wheel motorcycle with the pluses and minuses, I've done both. SB100 was not hard in Ca. where are you located? I'm running a turbo Miata in a Kitcar, very easy on tires, Miata parts are cheap the engine was built for durability with 300 hp.
  5. Mine are different than yours. I will send over some pictures and measurements. Do post your pictures, where did that radiator come from ? never seen a curved one. We should have a CMC registry somewhere of all the versions.
  6. I will be upgrading my CMC arms. Send me a picture of what yours look like to compare. I wasn't planning to do it right away but could be convinced. My car was one of the first and I understand they don't all look the same. It was the Grassroots magazine build. Ingmar
  7. Congratulations on what must be extremely well driven cars. The miata's can be built up to lots of HP but the S2000's start with 240 hp! Good pit crews are essential and even professionals crews miss something all the time. Well done.
  8. What happened to me this past weekend again - ongoing for 2 many track days. The keyed ignition switch had a dead spot which showed up only at certain times on the track, it momentarily turned off the ignition then back on. This switch was replaced last year just in case that was happening. Just a gentle nudge on key turned off car. Duct tape solution for that day, Where you running next? we should meet up. I need to build a quiet muffler for Seca, I have been running Buttonwillow and Streets.
  9. Project weeks on the car. Just redid the front air splitter to give more downforce and move the air over the lower A arm. I found an APR carbon fibre wing locally that was used and very well priced. I plan to mount it vertically ahead of the back roll bar at the spreader vertical to give downforce not only over the rear wheels. I've got the pipe to go vertical and then put a plate on top to use the wings existing mounting plate. The plan to attach to roll cage is to use flat plate on either side of new pipe and weld and bolt to rollcage.
  10. If the weather is not predicted rain I'm going to Speed Ventures at Buttonwillow on the 27th and then Feb. 16-17 with Alfa Romeo Racing school at Streets of Willow. Had a great time with Aaron at VARA school this past weekend, we both solved some problems on our cars. At Buttonwillow an Atom is signed up so that will be fun to see. Let me know if anyone else can make it.
  11. Buttonwillow Trackday - 11.18.2012 on Vimeo Aaron is in the orange car with the R-1 engine, my yellow has the miata turbo, both CMC chassis. We got to do follow the leader for a bit on track. Great to share time, we had never met prior to this day. My son Garrett did the filming and editing.
  12. signed up and booked a garage, just in case of inclimate weather . mca has first dibs on other space, let us know if you are coming. Ingmar
  13. I plan on going, waiting on weather report before commiting, Locost with R-1 is signed up already. Buttonwillow is a great track with lots of runoff for those "moments"
  14. Very nicely done. I thought maybe it was aluminum first off. The straps really make it work. Nice bottom pan also. It would be great to have some storage on the car. I also don't carry spare but I only do day trips . Your windshield appears to be curved? and What size tires are you using, those look large in photo?
  15. http://sfbay.craigslist.org/sby/pts/3307376647.html 245/40/15 CR 500 one day use for $ 900, so it says. no affil etc.
  16. Sorry was just dreaming of 20 days , my Nitto's didn't do 20 that many, but I also used them on the street.
  17. My crank sensor was reading badly and it turned out to be a ground that I had soldered and therefore brittle and fell apart on inspection. I've learned crank and cam sensors on Miata (mine) go bad due to heat and start with high rev failure. Also check your gap on sensor.
  18. I have only 3.5 inches road clearance with my 15" 23 inches tall tires currently which are the Miata/Honda 4x100 bolt pattern When I loose my last common sense I will order the 15 x 10 949racing Miata wheels Why use either bias or radial ? I'm thinking A6 Hoosiers if they'll last 20 track days. very good information from autocross forum. http://www.rahulnair.net/blog/2010/0...te-experience/
  19. Great posts, thanks for all the information on your wheels and tires. Let me know when you are headed out again. I am getting back to track days and solving some wiring problems. I was at Buttonwillow Saturday and Horse Thief the prior week. Ingmar
  20. My tires lasted for the track day Saturday so I have time to look at Hoosiers also. Some of the autocross guys buy slicks used. on ebay big price difference on shipping to the west where I am so need to find west coast source. Whats rain ? 150 days without a drop locally - Central Coast California.
  21. The panasports I have now are very wide on their offset and at some point I have to redo the rear fenders. Has anyone tried 15 x10 wheels ? Is this better on the track or too much weight. ? If have to build wider maybe best to go all the way. The car had 225/40/15 Avon when i got the car but the bead on one tire was busted. I can't find Avons. Picture is my 195 street tires. thanks
  22. Toyo's and Nitto's I've had Nitto NT01 205/50/15 mounted on 15x8 Panasports and happy with them. Now deciding on a dedicated track day/autocross tire as these will be worn out half way thru a track day Saturday. The Buttonwillow tire shop stocks Nitto Proxis with a new RR tire in 205 also available are 225/50's. Current NT01's are 22.5 tall, RR are 23 1re 23 and 23.9, don't know weights. I have 300 hp in my CMC miata turbo and want to make the most use of it. Too much tire? I turn down the engine and run 195's on the street. thanks
  23. I'm going, first time back at the track in a many months.
  24. Is your pyrometer used just for surface temp? I was thinking of trying my HF cheapy but if it is core temperature that is needed it will not work. For an autocross i tried 18/20 and then dropped to 16/18 and the car would not turn at all even with an increase of track temp. of 10 -20 degrees as it was midday. thanks
