glenntwincam
northeast ohio
Se7en
caterham 7 road sport with zebec svt.. built 2006
I have always used wix 51348xp engine is zetec svt
computer for 2002 thru 2004 Ford 4cy fuel injected SVT
glenntwincam replied to HUTCH's topic in General Sevens Discussion
we have cat s3 built in 06 with focus svt engine oem ecu. it use std cat key w/o chip . under scuttle zip tied is ford pats module with chip taped to it. module is black plastic rectangle with ring on it for install on steering column . cat harness was "married" to ford harness by RMSCI .. salvage engine came with ecu and matching keys -
our car built 2006 with zetec svt motor has yellow valve cover.. this was just a powder coat option from engine supplier RMSC.. zetec contour has vct on exhaust cam .. zetec svt has vct on intake cam ..
new/old caterham dealer - rockymountaincaterham.com
straying to far from recommended oil viscosity can affect the operation of VVT solenoid. in some engines it will set a fault code.
sounds like you need a new tire store
Caterham SV--Directional Signal Flasher Module?
glenntwincam replied to Taber10's topic in General Tech
just checked our car . turn signal & hazard flasher use same "relay". it's second one from top on our fuse panel. also a bit larger than the other 4 relays. -
just checked our car -2006 cat with svt. I added a extra strip of foam weather strip to nose to raise hood slightly above solenoid about 1/16 " clearance. I think it's better to raise hood than put any pressure on top of " very expensive , hard to get " solenoid.
USA Caterham Import and Distribution
glenntwincam replied to BruceBe's topic in General Sevens Discussion
+1 for bruce also..recently ordered rear wing. 2 emails , 1 phone call and I had the parts. very quick & easy -
Lotus 7 wins F Production at Runoffs today
glenntwincam replied to Kitcat's topic in General Sevens Discussion
this may be old news, eric prill has a great in-car video with front & rear facing cameras on you tube of the f/p race at this years run offs -
temp sensor on top of stat housing sends info to ecu , sensor for gauge is located on bottom left of same housing is for gauge.
this switch controls rad fan only. i replaced mine with vw part 823 959 481F/92. you're correct about 92/87 it's temp when fan turns on/off. switch is used on older water cooled vw's .check threads , my car has rad with plastic tanks.
try Sailrite Inc. they have black dot snaps , tools ect.
glenntwincam replied to Croc's topic in Cars For Sale
I know I'm late to the party , 2000 & 2001 caterham's that are for sale in San Francisco area have std zetec engines not SVT version , (wrong valve cover & intake manifold) also there is no IMRC control . SVT Focus was built 2002 thru 2004 . yellow valve cover was a powder coat option from RMSCI . factory color is silver.
