Tbox56
Everything posted by Tbox56
I will be leaving on Thursday for Austin TX to a NASA weekend at Circuit Of The Americas. Are there any other Seven's from here signed up to go? Tom
This is a car I am marketing for the owner. It appears to be a very nice clean example of a Birkin S3. Below is a list of features this car has. 2003 Birkin S3. 6987 miles • Dunnell built engine • Twin throttle bodies • Individual coil on each spark plug • Haltec sport 1000 programmable engine managing system • Kasei K1 race wheels (5) with new Nitto road tires (4) spare tire ok for emergency use • Detachable steering wheel- a big asset for getting in and out • Polycarbonate wind deflectors • Extended exhaust, exiting at the rear of the car • Five point G Force race harness plus three point regular inertia seat belts • Black paint condition 8 on a scale of 1-10 Extra item included • Tall roll bar with race harness and go-pro mounts • Tonneau cover • Car dust cover • Set of 4 hard front disc pads. • Please contact me with any questions or more information. Tom 970-376-5188
Here is a picture of a dipstick tube made from a soft thin wall aluminum using the standard dip stick. This is on a 2.5 L Duratec, at the top you can see it going in between number 3 and number 4 extension tube on the throttle bodies. You can then access the dipstick from the top of the engine. With the compound curves you will need to corkscrew your dipstick to get it to bend multiple directions. Tom
Birkin S3 Brake Light Pressure Switch
Tbox56 replied to 7mroadster's topic in General Sevens Discussion
Under the rear diff is correct for the IRS cars. The live axle cars it is located on the axle side of the rear bulkhead, in the fitting where the steel brake line changes to rubber going to the axle. Tom -
I believe that would require a full steel plate to protect the nose! Tom
Yes it would be and will be finished Grey with yellow and carbon fiber. Maybe a personal delivery to NJMP.
Not for the classic size cars. I have another order in production I could probably add to, should I get you one? Usually I get them 75mm taller than standard. Keep in mind if you have a full hood it won't work with the tall roll bar, the Birkini probably will with longer rear tie down straps. Tom
Good job, I built that car for the original owner, let me know if you have any questions after you receive it. Tom Birkin Direct-USA 970-376-5188
We have them in stock and can build you one or send you a "kit". Tom
The old Car Builder magazine has been re-branded and is in print form (and online) again. The new name is Reincarnation https://www.rcnmag.com/ the tag line is Continuation, Replica and Low Volume Automobiles. Sounds like us. The cost is free for both print and online. Tom
Article I thought people here might like. Tom http://trafficmagazine.co.za/birkin-cs3xs/ Getting to Know the Birkin CS3XS Clubman—and the People Who Build It - Traffic Magazine Looking for a sweet Lotus Seven replica? We visited Birkin's Durban factory, and sampled the super-fun CS3XS Clubman. TRAFFICMAGAZINE.CO.ZA
It would be an older style, they are not in stock but can be ordered. $207.50 Tom
They should be 1 for front brakes 1 for rear brakes and 1 for clutch. I would guess that the person that built your car made the middle one the rear brakes. the bias bar should be set heavy to the front therefore you are not noticing that you have no rear brakes. Tom
We can help you with many of the items on your list. 1. Front turn signals not visible from side HAVE ONES THAT ARE 2. Back up light not bright enough HAVE LED TAIL LIGHTS THAT ARE BRIGHT 3. No defroster (has no heater) HAVE ELECTRIC HEATED WINDSCREENS 4. No washer fluid sprayers HAVE WASHER KITS 5. No secondary strap on external fuel pump 6. No brake fluid pressure indicator light FLUID LEVEL LIGHTS ARE IN THE STOCK WIRING LOOM 7. Exposed exhaust system 8. Wiring too close to steering column 9. No safety etching on windshield 10. No bumpers DON'T HAVE ANY BUT NOT THAT TOUGH TO DO 11. No cup holders (just kidding) WE HAVE THESE BUT THEY ONLY FIT THE 64OZ BIG GULP AND REPLACE THE PASSENGER SEAT Contact me if you would like help with these items Good luck, Tom 970-376-5188
New Member, Have an Itch to Scratch, Advice?
Tbox56 replied to JohnnyPhysix's topic in General Sevens Discussion
Give me a call and I will be happy to work through a realistic budget to get you started. Tom Brikin Direct-USA 970-376-5188 -
A big thanks to Mike and Tom for all of the work they put into organizing this wonderful event. It was great to see all of the east coast people again this year and a couple of new faces as well. Got back home yesterday evening after a total of 4,139 miles. Tom
There is a dash layout on page 8 https://www.dropbox.com/s/fmsw44bxx05ls5f/OWNERSMANUAL.pdf?dl=0 Tom
There is a dip relay that switches between high and low when a momentary contact button is pushed. Here is a wiring diagram https://www.dropbox.com/sh/1w1t9trl845nxsn/AACc0b0af1yp9mmr1jBP4-EUa/headlights.pdf?dl=0 Tom
Less than 3 weeks to go. Looking forward to seeing everyone again. Tom
Tom or Mike, Who should I contact about camping at the track, fully self contained no hookups needed? Tom
Signed up and looking forward to seeing everyone again. Tom
Fortunately the snow is at the ski areas where it should be. Tom
