craig chima
Everything posted by craig chima
  1. Doing some shop cleaning and found a nice set of original uprights as would have been fitted to original Lotus 7's and early Caterhams. As you can see in the pix the uprights have the original stub axles installed but I also have a new pair of billet stub axles and will include those as well. ($125.00 for all including shipping anywhere in the continental US). Craig Chima, CC Motorsports (330) 807-0738 or chima97@aol.com
  2. Pan/pump, etc are sold. Thanks to all who inquired. Craig
  3. I'm in the process of converting a customer motor to dry sump and have a large capacity, modified 6 quart oil pan (later model lip seal) and related parts to sell. If you are doing any kind of racing, auto crossing, or just "enthusiastically" driving your 7 and don't have a dry sump system, an extra capacity baffled pan is a must-have. It is a "kick-out" style pan but the rear is still unmodified in order to fit a starter. Pan has baffles and includes the pickup tube/screen, dipstick, and oil pump. As can be seen in the pix, the oil pump has an adapter so that you can run a remote filter assembly and/or cooler if you like. $250 for all. Craig Chima, CC Motorsports, (330) 807-0738 or chima97@aol.com
  4. Manifolds sold. Carbs still available.
  5. Have a beautiful set of steel S2 pre-crossflow intake manifolds. Powdercoated in silver. $250/pr Also have one nearly complete and freshly sonic cleaned and rebuilt 40 DCOE 18, and one partially complete 40DCOE that needs more parts and assembly. Both carbs have 32mm chokes, F16 emulsion tubes and 125mains and 155 airs. The complete carb has new bearings, seals, throttle shaft, butterflies and is missing the following: (ONE screw top for one of the pump jets, TWO screw tops for the ball valves, Both push-in style auxiliary venturis. This carb is shown in the 2nd, 3rd, and 4th pictures. The disassembled carb (last picture) probably has 50% of the parts needed to complete as can be seen in one of the pictures but is ready for assembly. $300 for both carbs and parts or $500 for everything listed above. Craig Chima, CC Motorsports, Akron, OH (330) 807-0742 or chima97@aol.com
  6. Updating my original post as follows: In addition to the parts mentioned above, a brand new thick-wall distance piece goes with the CWP set as does a new pinion seal. Another thought worth mentioning is that those "in the know" will recognize that the distance piece pictured is the original early style, meaning that the diff was likely assembled at the factory and then never touched until I disassembled it.
  7. Have an original 3.9 EnFo CWP gear set for sale. Not cheap reproduction stuff and gears are near-perfect condition. Includes both bearings, races, distance piece, flange and nut. $200 for all plus shipping from Akron, OH. Craig Chima, CC Motorsports. (330) 807-0742 or chima97@aol.com
  8. I need to sell one of my two Lotus 7 race cars and BOTH cars have near-identical components as follows: Fresh all-steel, dry-sumped 1500cc Pre-Crossflow motors making in excess of 160bhp with 45DCOE Webers, custom intake manifolds, headers and exhausts with merge collectors, roller-rockers, billet cams, custom TDC oil pumps, custom lightweight flywheels/7.25" clutch assemblies and best-of-the-best components throughout. The motors would cost over $20K to duplicate. Both also have FRESH Spridget-based dog ring transmissions with Hewland internals, lightweight driveshafts, fully-adjustable brake bias pedal assemblies, adjustable front and rear anti-roll bars, limited slip differentials, fresh fuel cells, billet axles, aluminum radiators, MSD ignitions, etc, etc, etc. Differences between the two cars as follows: Vintage-only car: This is the red/silver car that I built in 2010 and have raced roughly 20 times since then and has proved to be the fastest vintage-prepared Lotus 7 in the country (208's at VIR or W-G, 58's at LRP, 2:29's at RA, 1:36's at M-O, and 1:54's at Pitt-Race). This car has fully-adjustable aluminum bodied QA1 shocks all around, and a BMC based rear axle assembly with 3.9 Tranax LSD differential, rear drum brakes, one set of VTO wheels with Avon ACB10's and weighs right at about 1000# without driver. Legal with all vintage groups and still immaculate. SCCA car. This car won the 2020 SCCA Runoffs in FP and can be raced "as-is" as a front running SCCA car or would be an easy conversion to vintage. The car underwent a ground up restoration of the chassis (powdercoated) including all new aluminum panels during the winter of 2021/22 and has only 4 race weekends on it since that time. Primary differences between this car and the above "vintage-only" car are a substantially stronger chassis and SCCA compliant roll cage where the weight W/O driver and required ballast is +/- 1200 #. This car also has a custom English Ford based rear axle housing with full-floating axles, rear disc brakes and allows for adjustable rear camber (zero to 3 degrees negative). It also has 3 way adjustable remote-reservoir Penske shocks and THREE full sets of wheels with fresh tires plus tons of suspension and other spares (complete set front and rear fenders, diffs, axles, uprights, etc). It would also be an easy conversion to vintage specs (different front fenders and likely converting the rear disc brakes back to drums). Both cars are pristine, and will be delivered 100% race ready to the new owner and the price is the same $48,000.00 for either car. Please contact me for additional details, information, or pictures. Craig Chima, CC Motorsports, (330) 807-0742 or chima97@aol.com
  9. If your search doesn't turn up anything useable, I do lots of rear housings (Ford, BMC, TR, etc) for both street and race cars. Ford housings are easily the strongest (and heaviest) but will still distort when welding brackets onto them but I have jigs for all types and can straighten after fab work is done if needed. I just need location of pickup points and the height off the housing for centerline of bolt holes. PM or email if you need assistance. Craig Chima, CC motorsports, Akron, OH
  10. As I continue to downsize my shop I've decided to sell the 4 post lift that I've used for the past 15 years or so. When I bought it, I was specifically looking for a lift that didn't take up a ton of room in my shop but was also big enough and heavy duty enough to be suitable for a small sports car. The footprint of the 4 posts is 128" long x 94" wide and the actual platform is 124" long x 78" wide. The capacity of the lift is 2500# and the platform is cable operated and is run by a 110V electric motor which can be seen in the pix. Everything works as it should and it is still in excellent condition and has never let me down. It's a great lift if you simply need extra storage, or for getting a car up in the air in order to work on it. The price is $1300 which is a little less than 50% of what I paid for it. Located in Akron, OH and I'm happy to help disassemble (probably a 2 hour job -- it's going to remain in place until it's sold). When I picked it up, I used a small open 12' x 6' single axle trailer and that's all someone would need in order to transport it. Craig Chima (330) 807-0742 phone or text or chima97@aol.com
  11. Shocks have been sold separately. Project price now $4100.
  12. I have this Lotus 7 project car for sale and it would make a great vintage race car/track day car/or even potentially a street restoration project. I was intending on building this chassis up into a S2 vintage race car for a customer but he recently purchased an Elan and has backed out of the project. The chassis came from Chris at Sevens & Elans and is super straight, clean, and rust free except for some mild surface rust where the paint has peeled from the chassis tubes. I am certain that it is an early Lotus 7 chassis based on several key "tells" on the frame but unfortunately at this point there is no way of verifying that. The tin chassis tag was removed and the short frame section where the front of the pedal stanchion bolts to was cut out at some point before me ending up with the project. This section of the frame is where the original Lotus frame # would have been stamped and I can't imagine why it would have been cut out unless someone wanted it for another car in order to claim it was an original Lotus 7. It would also be a simple task to replace this section and I am willing to do this for the new owner if they so desire. But, I digress and here are other relevant details of the parts that accompany the project In addition to being a clean, straight and rust free chassis, there have been some nice reinforcements made to the transmission tunnel and rear transmission mount as can be seen in one of the pix. And while there are some imperfections in the aluminum skin, in my estimation if someone was careful in removing it when doing the frame, the skins could be easily cleaned up and re-used. There is also a nice aluminum bonnet (hood) and intake scoop included but no fiberglass. Most of the front suspension bits are also included and are as follows: Upper and lower a-arms, sway bar, proper early uprights with the bolt on caliper brackets, brake calipers, spindles, hubs, a rebuilt RHD steering rack and also the fender stays. I will also provide wheel bearings, trunions, bushings in order to complete the front suspension. Shocks: There is a nice set of QA1 adjustable aluminum bodied coilovers and 185# springs for the front and steel Spax adjustable coilovers and springs for the rear. Aluminum brake/clutch pedal stanchion including the original clutch and brake pedals. There is no gas pedal but that is an easy thing to fabricate Steering shaft with nice 3 spoke leather Racetech steering wheel, plus a proper early aluminum steering wheel hub attached to a ratty old steering wheel. BMC 3 into 1 header and exhaust. I have $4375 invested in everything above and at this point would just like to get my money back out of it. I will also consider selling off the parts listed above individually so if you are interested in anything mentioned please shoot me an email or PM and if some of the parts end up being sold, the price of the project will be adjusted downwards accordingly. Located in Akron, OH and it could also potentially be put on a pallet and shipped with the parts placed inside the chassis if someone desired. Or, if someone is interested in going vintage racing and having me build them a top-notch vintage race car this would be an ideal starting point and I am certainly open to discussions in that regard. Craig Chima, CC Motorsports, (330) 807-0742 or chima97@aol.com
  13. Doing some shop cleaning and have the following stuff all related to English Ford rear axles and rear end parts for sale: 3.77 Quaife limited slip unit completely set up in Magnesium housing. Ring and Pinion are in great shape, backlash is to spec and absolutely ready to install. I used this in my SCCA car a couple of times but it is not a ratio that I will likely use again but is perfect for street use (i.e. lower revs) or track use with low aspect ratio tire. $1750.00 4.11 CWP assembly. Very nice crown wheel and pinion gear set. $150 Rear Axles and bits for late Lotus 7's or solid axle Caterhams: Lots of stuff here. 4 axles, all which have been magnifluxed, with outer bearing, steel collar, and housing end cap in place. Axles also come with cryo treated rear rotors fitted (easily removable if not needed) in case someone was interested in doing a rear disc brake conversion. Also have 2 bolt on rear caliper brackets, pumpkin seals, and boxes of new bearings, seals, o-rings, etc as seen in the pix. $500 for all (pretty much a lifetime supply!) or will separate as requested. All of the above is all track tested and was used on National Championship winning Lotus 7 but I have since converted to a rear axle setup which allows for up to 3 degrees negative camber and so it is extra to my needs. Contact me at (330) 807-0742 or chima97@aol.com. I have lots more pix of all of the above parts and am happy to send or discuss as requested. Craig Chima, CC Motorsports, Akron, OH
  14. The nickel plated bar is sold. Caterham 3/4" wide track bar still available.
  15. Have two front anti roll bars that are extra to my needs. Both are 3/4" diameter and work great to limit body roll when compared to stock bars. The black painted one is stock wide track Caterham (just over 38" end to end), and the nickel plated one is standard Lotus 7/early Caterham (about 35.5"). I don't have the threaded inserts for the Caterham bar but they are easy to get (or you can remove from your existing bar) and the nickel plated bar was modified so that you can use a "1/2" through bolt" from the back of a stock upper arm, through both washers and bushes and into the bar. $50 each plus shipping from Akron, OH. Craig Chima, CC Motorsports, chima97@aol.com or (330) 807-0742
  16. Shocks sold. Thanks to those who inquired. Craig
  17. I have a set of four very lightly used AVO externally adjustable shocks for use on original Lotus 7 or solid axle Caterham. They are for stock diameter springs (1 7/8 - 2") and have adjustable spring perches for ride height adjustment. Fronts are 12" compressed and 17" extended and the rear bayonet shocks are 13.5" compressed and 18.5" extended length. $250 for all four. Craig Chima, CC Motorsports, Akron, OH. (330) 807-0742 or chima97@aol.com
  18. Have an original electric fan and horn that were removed from an original Lotus 7 when I converted the car to vintage race car spec. Fan intended to go in front of radiator on the stock mounting bracket. Both work as intended. $50 for both INCLUDING SHIPPING to Continental US so pretty much a giveaway price to anyone who can use them. Please email chima97@aol.com or call (330) 807-0742 if interested. Thanks, Craig
  19. I have made some revisions to my SCCA Lotus 7 over the winter and as such, am selling the front a-arms that were on the car when it won the 2020 SCCA Runoffs. These will bolt on any Lotus/Caterham chassis and the width is similar to a Caterham "wide track" front suspension (the bottom a-arm is adjustable from 14.75" to 16" wide and top arm can be adjusted accordingly). A-arms are chromoly and the lengths done to give optimal camber curve and are fully adjustable for camber and caster and will accept a stock Caterham style upright. $500 for the set of four (the rod ends would cost you over 1/2 this asking price). A chassis mount will need to be done to accommodate the front/upper a-arm but I can assist with this as well if needed (see pix of how it attaches on my car). Call or email for details. Craig Chima, CC Motorsports, (330) 807-0742 or chima97@aol.com
  20. Yes, it is sold and the list of others who wanted the car is now probably at least 10. But it went to a good home and Lotus enthusiast in Colorado.
  21. Well, as Henry suggested, it didn't last long. Have a verbal commitment to purchase with deposit being sent, and one more person on the "waiting list" so pretty sure it is spoken for. Craig
  22. I have reluctantly decided to sell my 1965 Lotus 7 project (SB1961) and am posting detailed information here. I would very much like for this car to go to a dedicated 7 enthusiast since I will not be able to finish it myself (recent spinal fusion of L1 to L5 which will preclude me from doing major restoration and mechanical work in the future). As such, the project is being listed only on this website and also the simplesevens website. Details of the project along with a single picture below will give you an idea of the current status but in a nutshell this is a straight, sound chassis with probably 99% of the parts needed to complete the restoration included, plus major mechanical components (1340 cc Kent pre-crossflow motor) and Close Ratio transmission both recently professionally rebuilt. Lots of additional pictures can be seen on the simplesevens website or I would be happy to email or text as requested. If finished properly, this is easily a $40,000 car and in my estimation the only major expense left is painting the car. The rest is disassembly, cleanup of chassis, and reassembly (sweat equity). Asking $17,500 and I am open to close and reasonable offers to the right enthusiast. Car is in Akron, OH. Craig Chima (330) 807-0742 or chima97@aol.com
