Side Mirrors Without Doors?
Road Ready
Here are a couple of photos of our track mirrors. They utilize the standard Caterham mirror assembly, and slide into the windscreen door hinges. Mirrors are positively secured with a clamp. 6061-T6 aluminum, powder-coated black, with stainless hardware. $325+shipping.
-Bruce
I struggled with the best way to do this as when I took off the doors, the mirrors were also removed. And most permanent mirror mounts would interfere with the door opening.
I like Bruce's idea, which solved the problem in a similar fashion as to what I did.
I used the factory wind deflectors which are like $60-80? a pair. Mounted a pair of S.P.A Carbon Fiber mirrors to them. If I ran the doors, I took off the deflectors of course. The positive is I like the deflectors for the small amount of wind deflection they offered, plus I now had mirrors.
I am sure you could mount almost any mirror to the deflectors. I like the carbon fiber look and I think the smaller GT style racing mirrors are a better fit for style and proportion. And my opinion, that this mounting method also looks less bulky.
http://www.britishspeed.com/gallery3/var/resizes/Caterham-Build-SV-S3-170/033.JPG?m=1329535000
http://www.britishspeed.com/gallery3/var/resizes/Caterham-Build-SV-S3-170/034.JPG?m=1329535002
Randy,
Nice solution. How sturdy of a mount does that make it? Any vibration at speed? My wind wings rattle at certain speeds, it seems like the added pressure of the mirrors at speed might mitigate that.
I bought these motorcycle mirrors from Cycle Gear. They are designed to mount to horizontal motorcycle handlebars, but if you turn the mirrors on the ball joints they were perfectly for mounting to a vertical surface. My Birkin already had threaded female receptacles, but I think you could use the windshield mounting holes if your Seven doesn't. The size of these mirrors is really good, and they don't get the vibration blur my old mirrors had.
Randy,
Exactly. The extra mass seemed to help and I never was bothered by vibration. I had worse vibration in my Elise side mirrors.
Randy - you've just solved an issue I've had since I lowered the floors on my Caterham. I have always had the spa mirrors mounted directly to the windshield uprights (Chris @ Sevens & Elans adaptors) but with the lowered floors they are directly at eye level. They act like the big A-pillars with airbags on todays cars blocking your sight. Mounting to the deflectors is a great idea. Thanks!
For track days I remove the windshield and switch out just the spa mirrors to the posts already mounted on my short kick-up wind deflector.
Off Road: My (Beachman Racing built) track-only Cat has the same mirror mounted off-center to the right at the front of my cage. Due to it's convex nature, it offers a panoramic view of all that is behind. Also have a driver's side, side-view mirror mounted to the cage, and the combo is excellent.
