The prices of the Chaprons definitely put them in the exotic class. I was at an SCCA race in the early 80s and one of them was being used as the pace car. I managed to get a ride along on the track.
If it's that clean, it's an exotic. If it has the usual rust and wiring problems.....
Where does this rank? :ack:
Its just a normal European tour coach on the Mercedes Benz test track in Germany. If you drive it at 140kmh (convert it mph someone) then it will happily cruise the banking like that safely. So if you are weird and I am exotic then this bus photo is normal. :p
That makes imperfect sense....I think. :willy_nilly:
