Yes, no problem on my end. However the mold is heavy so UPS freight could be steep. I'll weigh the mold next week and give you its dimensions. Or I see if I have a wing I pulled off the mold to send you to make a temp mold. I'll check after the weekend, it's at my car shop.
  • 4 weeks later...
The only contribution I have is that superglue and baking soda is commonly used to repair CF helicopter rotors and airplane propellers. This may offer a shortcut to repairs / down time.
Sent from my iPhone using Tapatalk Pro
  • 7 months later...
Is there any consensus on how many nylon bolts to use? I just received mine today and wonder if there is a critical mass to secure the rear arch without there being too much resistance to breakaway? Eg: Two at front/rear end, one or two at the top and holes open in-between.
Hi Paul, I think I've used about 6 or so total. two on the leading edge Two on the trailing edge and two at the top. Space them out and see if the wing seems firmly attached and snugged up to the sideskin. I've ripped wings off now 3 different times, the same one twice on yellow and the carbon one on Orange. I've repaired the yellow wing twice and the carbon one once with no damage to the sideskins and they take a licken and keep on ticking. If you use one less or a couple more I don't think it would make much difference either way. Tom
Edited by yellowss7
