justinmarshall Posted July 24, 2020 Share Posted July 24, 2020 The Seven that I recently purchased has some UV damage to the dash. The buttons & switches are going from black to a dull grey and the carbon fiber itself is getting somewhat foggy. Was going to use some armor all on the switches but what about the dash? I found a product by Dr Beasley but have no experience with carbon fiber. Thanks in advance. https://www.amazon.com/Dr-Beasleys-P28T12-Carbon-Glaze/dp/B00BWFRDKC Link to comment Share on other sites More sharing options...
Croc Posted July 25, 2020 Share Posted July 25, 2020 The carbon fiber does go cloudy if it gets wet and water gets into the weave. You can put armor all on it but its only temporary in its effect. Mer bumper polish is also suggested by guys on the Lotus 7 Club UK forum - hard to find here but I have a bottle from one of my trips there. I have not used the product you linked to but its an option. For switches - they all go faded like that eventually I am sad to say. They came off old 1970s Triumphs. I tried armor all/bumper polish/tire black all on the switches but it was only temporary. Replacement is the only sure fix - which fortunately is easy and fairly inexpensive. Caterham parts website has them all for purchase online - lights for example https://caterhamparts.co.uk/switches/224-switch-lights-1981-onwards.html?search_query=switches&results=60 Use the term "switches" and they will all come up along with the toggle type of switch if you need those. Fairly simple replacement too although its awkward hanging underneath the dash upside down - best done with a friend. Slide wires off terminals, push old switch forward out of dash, friend pushes new switch into dash, reconnect terminals....next switch. If Caterham are out of stock then Car Builder Solutions will have them - example here https://www.carbuilder.com/us/iva-rocker-switch-front-fog Search term at CBS is best with "switch" - all the correct looking options should then come up. Similar pricing. Both websites send to you pretty quickly despite being UK based. Link to comment Share on other sites More sharing options...
justinmarshall Posted July 25, 2020 Author Share Posted July 25, 2020 +10 Karma for you Croc. Thanks for the information Link to comment Share on other sites More sharing options...
Sean Posted July 25, 2020 Share Posted July 25, 2020 Long ago on the Blatchat of old, I learned of a British furniture polish called Aristowax non-silicone Wood Silk being used to good effect on carbon fiber parts. Works for me, though like anything else for this purpose, it has to be re-applied frequently. Not readily available in the U.S. typically, but I found it on eBay as well as the occasional online specialty store. Best of luck. Link to comment Share on other sites More sharing options...
JohnCh Posted July 25, 2020 Share Posted July 25, 2020 Thanks for the tip Sean! Just ordered a can from Amazon and will try it on my seats when it arrives. After 15 years, the Mogs are looking a little tired. -John Link to comment Share on other sites More sharing options...
justinmarshall Posted July 25, 2020 Author Share Posted July 25, 2020 Thanks a bunch Sean Link to comment Share on other sites More sharing options...
Jesse D Posted July 28, 2020 Share Posted July 28, 2020 What you are seeing is either scratching or most likely UV damage to the epoxy that is the surface layer of your carbon part. You can temporarily brighten it with polish and if wax or sealant was regularly applied from the beginning you can prevent it, but once it's there you can't sand/buff it back. The black color just attracts UV heat and thus damage. Some manufacturers put a clear coat on top of the epoxy, especially for exterior parts, and that you might be able to sand and refinish. Most carbon bits on a boat end up being painted and more and more are painted from the beginning, as the deterioration in a carbon part like a mast is very real and can end up structural. I don't think a carbon dash is in any way structural:-) Link to comment Share on other sites More sharing options...
JohnCh Posted August 6, 2020 Share Posted August 6, 2020 The Aristowax showed up Saturday. It does add a visible shine to the carbon fiber, and although I doubt it will last long, particularly on the seats, it is very easy to apply: spray on, wipe off, have a beer. And I like beer, so I'm fine with repeating that process often. -John Link to comment Share on other sites More sharing options...
Brightonuk Posted August 9, 2020 Share Posted August 9, 2020 Sanded mine with 1200 then lacquered it using Spray Max 2K Clear Glamour Here are a few before and after shots Pre Spray 1 Pre Spray 2 Post Spray 1 Post Spray 2 Came out acceptable I could/should have spent more time rubbing down and polishing the finish Link to comment Share on other sites More sharing options...
