I'd like to raise the rear view mirror that is mounted with my Brookland's screens. I've seen an extender for this on other cars. Is that an off-the-shelf part that I can buy, or do I just make one?
Try aerostriaght.com. Give them a phone call rather than trying to find what you need. I found the owner very helpful.
  On 5/8/2021 at 3:50 PM, FE07 said:
You could certainly try to fabricate one yourself however SPA makes one for it:
https://www.pegasusautoracing.com/productselection.asp?Product=5171-STEM
Jim
Expand
Be careful for using Pegasus for this part.  The photo shows a 5 inch tall Spa post.  It actually arrives 2 inches high which is ok if thats what you want.  I had to return it as it was the same low height I already had.  Pegasus did not have the taller post available.  Spa would not sell the part separately.  Their website makes you buy the whole mirror kit.   I ended up at aerostraight.com like @papak
