I checked their website. Any idea what the difference is between “large” and “L-shaped”?
My guess is that the L-shaped covers the area above and outboard of the carbon/stainless mudguard, whereas Large covers that complete area.  I plan to leave the carbon mudguard in the box and use the bigger piece.
How wide is the film at the top? My wide body Birkin is similar dimensionally to an S3 but the rear fenders may be a bit wider. I only see the 3M film advertised in 6” widths. I really don’t like seams.
If you don't get an answer sooner, I can measure mine this afternoon when I get home from work.
About 10.5" wide.  I purchased the large size and then cut into two pieces, one for the carbon guard and the other for the gel coat around the guard.
I can confirm what Greg said at 10.5" wide, and can add that the longest side length is 22.5" if that helps.
On 8/1/2021 at 10:27 AM, papak said:
Thanks! I'll order a set.
Hey Papak,  Id be interested in what you purchased I think we both have the same chassis type so id like to copy you straight up. are you planning to install it yourself?
If there is one thing I feel was worth every penny it is the 3m clear bra I had on the last car.
