papak Posted July 28, 2021 Share Posted July 28, 2021 Does anyone have a source for precut 3M rear fender film? Link to comment Share on other sites More sharing options...
11Budlite Posted July 28, 2021 Share Posted July 28, 2021 4 hours ago, papak said: Does anyone have a source for precut 3M rear fender film? This is where I got mine: https://premierpaintguard.com/ Link to comment Share on other sites More sharing options...
papak Posted July 28, 2021 Author Share Posted July 28, 2021 I checked their website. Any idea what the difference is between “large” and “L-shaped”? Link to comment Share on other sites More sharing options...
JohnCh Posted July 28, 2021 Share Posted July 28, 2021 My guess is that the L-shaped covers the area above and outboard of the carbon/stainless mudguard, whereas Large covers that complete area. I plan to leave the carbon mudguard in the box and use the bigger piece. -John Link to comment Share on other sites More sharing options...
papak Posted July 29, 2021 Author Share Posted July 29, 2021 How wide is the film at the top? My wide body Birkin is similar dimensionally to an S3 but the rear fenders may be a bit wider. I only see the 3M film advertised in 6” widths. I really don’t like seams. Link to comment Share on other sites More sharing options...
11Budlite Posted July 29, 2021 Share Posted July 29, 2021 If you don't get an answer sooner, I can measure mine this afternoon when I get home from work. Link to comment Share on other sites More sharing options...
Pokey Posted July 29, 2021 Share Posted July 29, 2021 About 10.5" wide. I purchased the large size and then cut into two pieces, one for the carbon guard and the other for the gel coat around the guard. Link to comment Share on other sites More sharing options...
11Budlite Posted July 30, 2021 Share Posted July 30, 2021 22 hours ago, Pokey said: About 10.5" wide. I purchased the large size and then cut into two pieces, one for the carbon guard and the other for the gel coat around the guard. I can confirm what Greg said at 10.5" wide, and can add that the longest side length is 22.5" if that helps. Link to comment Share on other sites More sharing options...
papak Posted August 1, 2021 Author Share Posted August 1, 2021 Thanks! I'll order a set. Link to comment Share on other sites More sharing options...
NeoBear Posted August 5, 2021 Share Posted August 5, 2021 On 8/1/2021 at 10:27 AM, papak said: Thanks! I'll order a set. Hey Papak, Id be interested in what you purchased I think we both have the same chassis type so id like to copy you straight up. are you planning to install it yourself? If there is one thing I feel was worth every penny it is the 3m clear bra I had on the last car. Link to comment Share on other sites More sharing options...
