Ideal for a Seven.  Might have to check if a wide body will fit.  Four locking compartments, all keyed alike. Tilts, which get be adjusted by changing the straps in the front.  All aluminum except the coupler and axles.  Surge brakes on all four wheels.  Empty, weighs 830 pounds on the tires and the nose is liftable, so I would guess it is just under 1,000 pounds.  It is set up for wheel bonnets over the front tires.  $2,500 if I put it on Craigslist.  $2,200 on the forum, or $2,000 for the buyer of the Birkin.  Will not sell until the car sells, as I might need it and buyer of the Birkin has right of first refusal. Trailer.thumb.JPG.ebccd794372dd81fbc901ee776a86200.JPG1325752068_ontrailer9-22-19.thumb.JPG.bc16207c291fccaa8f00c6bfb866912e.JPG
7 hours ago, IamScotticus said:
can we have a mfg and model #?
I do not know.  It's registered as a "Shop Built".  But Texas light trailer registrations are pretty meaningless.  You pay a little $, get your plate and they don't issue a title.
Car_Guy,
It looks like the width dimensions on that trailer might be too narrow for your XL? The rear end width on an XL is 76" wide. I ended up having to buy a brand-new 14' Aluma ( Aluma 7814 sa tilt trailer) to haul around the Stalker AXR (66" wide) I am in the processes of completing. Sadly, they are now about $7-8k due to the price of aluminum skyrocketing. Actually, just found a heck of a deal in FL and Iowa on what would be OK for your XL. The bed is only 77.5" wide so you would have .75" clearance on each side for your rear wheels.
Edited by Anaximander
I do not think any of the wide versions would fit.
The runners (inside the body work) are:
L - 12 feet
W - 67 inches
Inner track of the runners - 38.5 inches, so each runner is about 14 inches wide.
  • 9 months later...
The trailer is now available without waiting for a buyer for the Birkin.  I'll give i a week here, then try Craigslist.
