so i have begum watching this place daily but im still a lil lost on the lingo.
what are the following:
frappr
blat
any other lingo you guys use please post up for the newbie :)
Thanks in advance.
A 'blat' is a drive in a seven.
The word derives (I believe) from the noise the engine makes - well, some engines at least - when revved hard. Blat, blat. blat...
Unless someone knows different...
Frappr is a free site/service that allows you to put your location on a map with virtual "push pins". Mazda set one up for the forum members. It's great in that allows you to find other owners/enthusiasts in your area.
The density of Sevens in the VA/MD as well the CA areas is impressive, and certainly contributes to the activity/cameraderie of that region. Obviously, some of the regions are more geographically spread out it's more difficult to get folks together.
But try, friends, try!
Another Seven-ism: My friend Bob in Colorado refers to his passenger as the "victim."
Tom Meacham
Alaskossie
Also seen the passenger referred to as the Rev Limiter.
And in case you browse any of the UK forums, SWMBO is a common one = She Who Must Be Obeyed
:D
Another new term... when people say "heavy", they mean anything over 1400 lbs. :lol:
And "under-powered" means anything with more than 5lbs/HP.
Sordid: seamy: morally degraded
oops sorry.... :jester:
tr.v. sort·ed, sort·ing, sorts... To reduce to order from a confused state
7s definition - Sorted: Properly set up and configured for peak performance.
I also use sorted to mean "all the bugs worked out". As in...every Se7en that I've ever met required some level of sorting out...mine was mostly with the cooling hoses.
My favorite when asking a question about a noise or problem
and the answer is TADTS = They All Do That Sir
And a Passenger can also aptly be called Ballast.
I'm with R1 Seven on the term "blat". Just doesnt sound like a very flattering description of what for me was an eye-opening experience the first time I took a ride in a Seven. Besides it's a British term (nothing against the British; one of my best friends is Brit; love to bug him over his pronunciation of aluminum).
Personally, when I get my Ultralite on the road it wont ever "go for a blat".
