wdb Posted November 12, 2024 Author Posted November 12, 2024 It's now official, FINALLY. My Caterham is back on the road! Gosh I missed this car. After "First Oil Pressure" I finished buttoning things up sufficiently to take the car out for a few short shakedown runs. There were some issues uncovered, one of which was that the oil pump was not tightened down sufficiently to prevent an oil leak at the gasket (as it turned out). The Allen head bolts holding it are very hard to get at and I did my best, but I ended up having to conjure up a custom tool to tighten them properly. That fixed the leak and also elicited an enormous sigh of relief from me, because taking the pump out again would have meant a metric buttload of disassembly; it was literally the first part I put back on when I began reassembling the car. Shakedowns done, findings noted and corrected, it was time for a proper drive. It was 45F with a sharp breeze but I just had to. Woo-eee! I kept thinking maybe I should turn around and head home, but the road continued to beckon. Finally I made the turn and headed back. I was high from the drive for a good hour after getting back home and putting it away. What fun these are. 2 1
IamScotticus Posted November 13, 2024 Posted November 13, 2024 (edited) your journey may be yellow, but it isn't little Im about to find out if I need your DS engine mount Edited November 13, 2024 by IamScotticus 1
Vinman1 Posted November 13, 2024 Posted November 13, 2024 The feel of the road in a Seven is unmatched! Every time I drive mine, the Webbers want to wail, and the corners want to be carved up! 2
JohnCh Posted November 13, 2024 Posted November 13, 2024 That's great to hear @wdb! Is there any other work you plan to do over the winter or are you now sitting back and counting down the days to blatting weather?
IamScotticus Posted November 13, 2024 Posted November 13, 2024 (edited) Can we have some new roadside pics in all your splendid yellowness? Edited November 13, 2024 by IamScotticus
wdb Posted November 14, 2024 Author Posted November 14, 2024 22 hours ago, JohnCh said: That's great to hear @wdb! Is there any other work you plan to do over the winter or are you now sitting back and counting down the days to blatting weather? Thanks! I'd still like to get a few drives in before the snow flies. It's supposed to be in the low 60's early next week, and that's good enough for me. Also a local restoration shop, Ragtops & Roadsters, has a "before we put 'em away' run in a couple of weeks, which would be a fitting end to the season being as that is where I punched the hole in the sump last year. As for other work: I'd like to do something in the way of a skid plate I am looking at fire suppression systems Tires! Real sporty ones this time LF shock is leaking which has me thinking about height adjustable coilovers Brakes should be gone through LSD? Something having to do with seats etc., etc., etc... In the short term I want to get the Elan in a better state. I have RD's CV joint axle kit standing by, and the rear shocks are completely blown on the car so I will be doing something about that too. That car has luxuries such as a top and a heater so it may be a better candidate for opportunistic jaunts over the cold months. Not to mention that my whole reason for buying it was to fully experience a Lotus Elan firsthand, which I have not truly been able to do yet. 14 hours ago, IamScotticus said: Can we have some new roadside pics in all your splendid yellowness? Sure! I'll try to get some shots over the next week or two. It still looks exactly the same, unless you count the discoloration of the RF tire from me cleaning the mess last fall when it leaked most of its engine oil onto the floor of the garage. Under the hood it looks a bit different though. I have a youtube channel for the car and have been meaning to post an update, so keep an eye out there too. (It's not a monetized channel, just me yammering freely and incessantly into the void.) 1
IamScotticus Posted November 14, 2024 Posted November 14, 2024 (edited) Have a link for those seats? I may be looking into those. video 12:05..If you look at the basket frame behind the ali, there may be a bung welded in for the spare tyre bracket. The car may have been paneled over the bung with the intent to cut the hole after skinning. It's a small hole so pre cutting it is bad idea. I have an extra tyre bracket for 3.75 PCD if interested. AND lets see that dry sump system! Edited November 14, 2024 by IamScotticus
JohnCh Posted November 14, 2024 Posted November 14, 2024 5 hours ago, wdb said: As for other work: I'd like to do something in the way of a skid plate I am looking at fire suppression systems Tires! Real sporty ones this time LF shock is leaking which has me thinking about height adjustable coilovers Brakes should be gone through LSD? Something having to do with seats etc., etc., etc... This will keep you busy In my opinion, the LSD is well worth it. Adding one to the Westfield years ago was transformative. The car became so much easier to steer with the throttle and really ratcheted up the fun-to-drive factor. As for the Elan, yes get that in a better state and drive it! It's a great complement to the Seven, although my rust fears prevent me from driving it in the wet despite the vastly superior weather protection of the FHC design.
MoBoost Posted November 16, 2024 Posted November 16, 2024 Thank you for posting these videos, particularly the latest showing the dry sump system. I’m still running a stock pan (with baffles) on my Twin Cam. My car is RHD and has heat which would make the plumbing for a dry sump different. You did an exemplary job of fitting all the hardware in!
wdb Posted January 20, 2025 Author Posted January 20, 2025 On 11/14/2024 at 3:24 PM, IamScotticus said: Have a link for those seats? I may be looking into those. video 12:05..If you look at the basket frame behind the ali, there may be a bung welded in for the spare tyre bracket. The car may have been paneled over the bung with the intent to cut the hole after skinning. It's a small hole so pre cutting it is bad idea. I have an extra tyre bracket for 3.75 PCD if interested. AND lets see that dry sump system! Wow, I just left everyone hanging. I guess the siren call of the Elan was too strong. That is turning into a real rabbit hole. I have zero information on the seats. I've never seen any like them in any other Caterham. There's also a fiberglass race shell that is even more cramped than these seats. I doubt I'll ever use it, so if you have any interest let me know. I never did look for a spare tire bung. My tendency would be to cut the tire loop off altogether if I'm honest. As for the dry sump, there are more pictures earlier in this thread, plus there's a video on youtube showing everything pretty thoroughly. I'm happy to post specific stuff if you let me know what you are focusing on. On 11/14/2024 at 3:45 PM, JohnCh said: This will keep you busy In my opinion, the LSD is well worth it. Adding one to the Westfield years ago was transformative. The car became so much easier to steer with the throttle and really ratcheted up the fun-to-drive factor. As for the Elan, yes get that in a better state and drive it! It's a great complement to the Seven, although my rust fears prevent me from driving it in the wet despite the vastly superior weather protection of the FHC design. Here's a funny story -- I may have accidentally bought a LSD for the Elan. A few years ago when I first got the 7 I was scouring eBay for stuff and came across what was being advertised as a "Cortina limited-slip differential". I bought it, thinking I could put it in the 7, assuming that everything in the 7 was Ford. Ooops. Well, now I have a car with a Ford rear, and the LSD might fit! I'm going to take it with me when I visit Don Butler for the strut tube replacement work. On 11/15/2024 at 7:28 PM, MoBoost said: Thank you for posting these videos, particularly the latest showing the dry sump system. I’m still running a stock pan (with baffles) on my Twin Cam. My car is RHD and has heat which would make the plumbing for a dry sump different. You did an exemplary job of fitting all the hardware in! If you are planning a conversion I may have some stuff you can use. I'll put together a list and take some pictures. I assume your oil tank will be on the LH side somewhere, which would leave room on the RH side for the catch can I bought but can't use. I have some other bits too that might work for you. 1
wdb Posted April 5, 2025 Author Posted April 5, 2025 I had the Se7en out for a wee romp about two weeks ago. The weather was finally good enough and the roads clean enough in combination. It's so strange how this car affects me after I've been out of it for a while. It feels familiar but the thrill is elevated nearly to the same level as that first-ever drive. What a refreshing thing this Se7en is. One of the fun parts of having a little car (or two!) and a 4-post lift is that the little car is "width challenged" relative to the ramp spacing. The Se7en isn't too bad because I can lean over and watch the front tire roll on. The Elan however does not allow me to do the same, plus the track is narrower than the Caterham. I have about 2" to spare on each side. So I came up with a solution. I purchased an inexpensive 2-axis laser level and aligned it's vertical output with the center of the lift. Now when I drive up I can line the green light up with the center of the car and just drive on. Saves a ton of back/forth fiddling. Here's the laser in its final resting place, bolted to my toolbox. 2 1
wdb Posted June 9, 2025 Author Posted June 9, 2025 (edited) I braved the changeable weather yesterday and went to an all-English car show in nearby Hellertown PA, put on by the Keystone British Car Club. They tossed the 7 in with the "Lotus" group, which also included this. I must admit that it doesn't look quite as awkward in person as it does in pictures. The little bumblebee garnered a moderate amount of attention. People seemed to particularly like gawking at the engine. At the last gathering I attended, the horns decided to start working independently of any outward impetus, and continued blaring until they fried the relay (as I later discovered). It was mildly embarrassing to say the least. So I finally gave up on trying to make the horn button behave and installed a momentary toggle switch next to the steering wheel, where I can reach out my index finger and give it a tug. I think it looks appropriate. Edited June 9, 2025 by wdb 2
wdb Posted August 27, 2025 Author Posted August 27, 2025 I finally finished a job I was not happy about having to do, namely taking apart some of the dry sump plumbing to fix small but nagging leaks. I used a liquid thread sealant product instead of my usual teflon tape, and it failed to to do the job. It was also a bear to clean out of the threads. NOT recommended. Anyway it's done. On a shakedown romp to test the refreshed connections I heard sounds in the rear that gave me the impression something was loose. So I climbed underneath with a handful of wrenches, and found this. At first I thought the bolt had broken but it had not. There was a small washer on the outside, under the bolt head, and the suspension arm just walked itself right over it. As the pictures show it was on the brink of coming all the way off, which would have been -- exciting. I put large washers on both sides so that it can't happen again. Boy oh boy do I need to refresh the rubber bits under this car. 2 1
