FE07 Posted July 24, 2024 Posted July 24, 2024 You don’t need sewn in ends on the harnesses or clip in ends like Cbuff. If you buy them without ends you can simply add bolt in end plates to attach them anywhere. It’s tight on the sides of the seat. No problem with shoulder harnesses. You do need to carefully check lengths of the harnesses.
Vovchandr Posted July 25, 2024 Author Posted July 25, 2024 1 hour ago, FE07 said: You don’t need sewn in ends on the harnesses or clip in ends like Cbuff. If you buy them without ends you can simply add bolt in end plates to attach them anywhere. It’s tight on the sides of the seat. No problem with shoulder harnesses. You do need to carefully check lengths of the harnesses. Ok I'm now confused. I have the bolt in end played now on my existing harnesses. You're saying I can add them to other harnesses somehow?
CBuff Posted July 25, 2024 Posted July 25, 2024 My harness's are all “wrap” in. Not sewn in. So I can change the attachment from bolt in or snap in by just changing the hardware 1
FE07 Posted July 25, 2024 Posted July 25, 2024 Just like the second youtube video shows. That's how you can add in a bolt in option and adjust it to fit.
Vovchandr Posted July 25, 2024 Author Posted July 25, 2024 49 minutes ago, FE07 said: Just like the second youtube video shows. That's how you can add in a bolt in option and adjust it to fit. Very interesting. I think that's similar to how i did my Miata belts tying them to roll cage So far TRS is front runner at this moment for just easy bolt in solution
Marek Posted July 26, 2024 Posted July 26, 2024 Demon Tweeks has a wide selection of non-yellow harnesses. This is where I picked up the current Sabelts in my Seven.
Vovchandr Posted July 26, 2024 Author Posted July 26, 2024 8 hours ago, Marek said: Demon Tweeks has a wide selection of non-yellow harnesses. This is where I picked up the current Sabelts in my Seven. Thank you. I see many TRS on there too. None with right base plates. I learned yesterday that almost every manufacturer can modify a model to your fit if you don't see it offered in a model with right baseplates or lengths etc. Currently waiting on a quote for a TRS with right base plates, colors and lengths.
