CBuff Posted November 6 Share Posted November 6 You should also make sure to open the heater valve under dash to let coolant / air clear that system Link to comment Share on other sites More sharing options...
JohnCh Posted November 6 Share Posted November 6 34 minutes ago, CBuff said: Can you poach your heater switch for the wipers to pass the inspection. Not sure on the amp ratings on each switch but it would be a similar 3 position switch. Are the heater fan and wiper switches physically the same? They are both off-on-on, but the wiper wiring also has to account for the wiper park mechanism when switched off. I think it may have an extra pin or have the pins wired differently. Hopefully someone can confirm or tell me I am wrong as per the norm. Link to comment Share on other sites More sharing options...
hyper7 Posted November 6 Author Share Posted November 6 The heater switch has less pins and in different spots. Link to comment Share on other sites More sharing options...
hyper7 Posted November 6 Author Share Posted November 6 16 hours ago, CBuff said: You should also make sure to open the heater valve under dash to let coolant / air clear that system pulled is "open" correct? if so, i'll try that out and make sure its good. Link to comment Share on other sites More sharing options...
CBuff Posted November 6 Share Posted November 6 (edited) Pulled is open. maybe the switch idea was a dumb one. Edited November 6 by CBuff 1 Link to comment Share on other sites More sharing options...
MV8 Posted November 7 Share Posted November 7 What is the issue? Temp gauge not working? I don't know what the blue line is from the previous post. I guess shows cold but actually hot? Link to comment Share on other sites More sharing options...
hyper7 Posted November 7 Author Share Posted November 7 It moves up from the bottom of the gauge to the blue "cold" section, but never goes higher. My obd reader reports the temp at 200+. I'll run it again with the heater open and see if it does anything different today. Link to comment Share on other sites More sharing options...
hyper7 Posted November 7 Author Share Posted November 7 Amazing what happens when you plug the submarine connector back in Apparently it got disconnected somewhere along the line. Link to comment Share on other sites More sharing options...
hyper7 Posted November 7 Author Share Posted November 7 1 1 Link to comment Share on other sites More sharing options...
jordway Posted November 8 Share Posted November 8 Yep. Same thing happened to me recently. Easy enough fix. But, it came loose yet again on a long spirited drive over the weekend. I intend to heat shrink it this time. Link to comment Share on other sites More sharing options...
hyper7 Posted November 15 Author Share Posted November 15 Road legal! See my other thread for details on registration in Ohio... 4 Link to comment Share on other sites More sharing options...
