CBuff Posted November 6, 2024 Posted November 6, 2024 You should also make sure to open the heater valve under dash to let coolant / air clear that system
JohnCh Posted November 6, 2024 Posted November 6, 2024 34 minutes ago, CBuff said: Can you poach your heater switch for the wipers to pass the inspection. Not sure on the amp ratings on each switch but it would be a similar 3 position switch. Are the heater fan and wiper switches physically the same? They are both off-on-on, but the wiper wiring also has to account for the wiper park mechanism when switched off. I think it may have an extra pin or have the pins wired differently. Hopefully someone can confirm or tell me I am wrong as per the norm.
hyper7 Posted November 6, 2024 Author Posted November 6, 2024 The heater switch has less pins and in different spots.
hyper7 Posted November 6, 2024 Author Posted November 6, 2024 16 hours ago, CBuff said: You should also make sure to open the heater valve under dash to let coolant / air clear that system pulled is "open" correct? if so, i'll try that out and make sure its good.
CBuff Posted November 6, 2024 Posted November 6, 2024 (edited) Pulled is open. maybe the switch idea was a dumb one. Edited November 6, 2024 by CBuff 1
MV8 Posted November 7, 2024 Posted November 7, 2024 What is the issue? Temp gauge not working? I don't know what the blue line is from the previous post. I guess shows cold but actually hot?
hyper7 Posted November 7, 2024 Author Posted November 7, 2024 It moves up from the bottom of the gauge to the blue "cold" section, but never goes higher. My obd reader reports the temp at 200+. I'll run it again with the heater open and see if it does anything different today.
hyper7 Posted November 7, 2024 Author Posted November 7, 2024 Amazing what happens when you plug the submarine connector back in Apparently it got disconnected somewhere along the line.
jordway Posted November 8, 2024 Posted November 8, 2024 Yep. Same thing happened to me recently. Easy enough fix. But, it came loose yet again on a long spirited drive over the weekend. I intend to heat shrink it this time.
hyper7 Posted November 15, 2024 Author Posted November 15, 2024 Road legal! See my other thread for details on registration in Ohio... 4
hyper7 Posted December 30, 2024 Author Posted December 30, 2024 Present to myself is on - not too bad once I deciphered what they were saying in the instructions. I really hated getting in and out with the full hood, so I opted for the easy-in zippers for the half hood. 1
williamwashere Posted January 5, 2025 Posted January 5, 2025 Awesome build!! Love the colors. Which half-hood did you go with?
hyper7 Posted January 5, 2025 Author Posted January 5, 2025 Went with the soft bits one - I liked the idea of the easy in/out zippers..I had a hell of a time getting in and out the only time I drove it with the full hood on
