Donnie Posted November 17, 2024 Posted November 17, 2024 (edited) Have pair of very nice beige leather Caterham seats that are too large for my Seven. Will trade for smaller black pair. Max width is 17". Seats are now for sale. $500 Edited November 28, 2024 by Donnie
MV8 Posted November 20, 2024 Posted November 20, 2024 Traditional seats (two squabs and a back rest panel) offer the most room but no head rest or adjustability. There are like boat seats with a wood or chip board base, high density foam (at least 5#, 2 inch bottom, one inch back) and marine vinyl wrapped and stapled on the hidden side with velcro strips like an airliner seat cushion. A local upholstery shop could handle that.
IamScotticus Posted November 21, 2024 Posted November 21, 2024 Failing all else, https://www.cobraseats.com/seats.html?pid=20&cid=2
anduril3019 Posted November 21, 2024 Posted November 21, 2024 I've always wondered if Porsche 914 or Lotus Europa seats would work. They both have a one-piece shell with head-rest, and are relatively narrow and compact overall. Just a thought.
Donnie Posted November 26, 2024 Author Posted November 26, 2024 Have decided to go the traditional route and build my own bench seats. Caterham seats are now for sale outright. Will post some photos shortly. Any interest out there? 1
wdb Posted November 26, 2024 Posted November 26, 2024 Yes there is interest but. Why are Caterham seats too wide for your car?
Donnie Posted November 27, 2024 Author Posted November 27, 2024 (edited) Too large for my replica 7 Edited November 27, 2024 by Donnie
MV8 Posted November 27, 2024 Posted November 27, 2024 Here is an example of what a good upholstery shop can do: 1 1
Donnie Posted November 27, 2024 Author Posted November 27, 2024 Very nice but bench seats are in order.
JohnCh Posted November 27, 2024 Posted November 27, 2024 @Donnie, I suspect you may have SV seats which are a little wider than the S3 seats. It might be helpful to post some width measurements and hopefully someone with those seats in either an S3 or SV can confirm which you are selling.
Donnie Posted November 27, 2024 Author Posted November 27, 2024 @JohnCh Good point. The seats are 17" wide mm. Thanks
Donnie Posted November 27, 2024 Author Posted November 27, 2024 (edited) The only flaw is a small cut on the lower inside edge of one seat. Approx. 1/2 inch Edited November 27, 2024 by Donnie Add pic
MV8 Posted November 28, 2024 Posted November 28, 2024 23 hours ago, Donnie said: Very nice but bench seats are in order. It looks like buckets but it is actually a one-piece bench. Just an idea on how creative it can be. Original type CAT bench upholstery kit is also available. There is a link on this site somewhere if interested. Then your local shop just needs to make the backing and cut the foam.
IamScotticus Posted November 30, 2024 Posted November 30, 2024 (edited) I get it. The minimal approach suits the car, and often the driver. I too am inclined to run the old squabs as well. The old BDR seats, while a nice upgrade in the 80s, seem rather overstuffed and ride high. As well as the extra 44 lbs they add. The problem with building squabs for others, squabs that fit within the frame tubes, is the high chance of a non-fit due to chassis variations. If cutting a squab base to fit on top of the tubes, they can be more universal, but one gives up an inch vertically and a method for movement prevention will be necessary. Velcro to the rescue! There are some advanced foam options available that can be layered to build an excellent squab. Squabs are so much easier to remove than bolted buckets when there is work to be done in the cockpit. For those of stature less than 6', the squabs can be a challenge, in a long cockpit and with the pedals set back. For them, and I am one, they will find the adjustable bucket to be the shortest path to a drivable 7. The head rests are included, and they make a 7 more tolerable for longer drives. I think I can build a bench set thicker to space me forward enough. Edited November 30, 2024 by IamScotticus
MV8 Posted November 30, 2024 Posted November 30, 2024 Tim, here is one way to independent adjust ability with a bench. 1
Donnie Posted November 30, 2024 Author Posted November 30, 2024 I have built the seats. Shopping foe foam and vinyl today. Thanks for all the input.
IamScotticus Posted November 30, 2024 Posted November 30, 2024 My squab back wood panel has warped with age, and tension from shrinking vinyl. Needs replacing, which I could probably do myself. I just hope the foam isn't glued to the board. Does anyone know?
7Westfield Posted November 30, 2024 Posted November 30, 2024 35 minutes ago, IamScotticus said: My squab back wood panel has warped with age, and tension from shrinking vinyl. Needs replacing, which I could probably do myself. I just hope the foam isn't glued to the board. Does anyone know? The foam is probably pretty tired, anyway, so who cares.... I'm thinking of doing mine, looking for some stiffer foam than original
