CarBuzz Article: $160k Italian Speedster Is Unlike Any Caterham 7 You’ve Seen Before
But it’s not a real car.
And it does not add lightness! If that’s 1200 pounds I need to add some chimps to my family tree.
The article says it weighs a bit over 1200 lbs, about the same as a Miata MX 5. The Miata weighs over 2300 lbs. Not even close to the same.
