Healeyracer Posted December 9, 2025 Posted December 9, 2025 Hi, I thought I saw someone post the files to have the pieces cut out to make motor mounts for the 711 block. But I am not finding them now. If anyone has them or can point me in that direction I would appreciate it. I have an RM7 which as I understand it is basically a knockoff of a Catherham in the 90's. I purchased it with no drive train, and have acquired a Lotus twincam to install, and am looking for the mounts. Thanks Mike
anduril3019 Posted December 9, 2025 Posted December 9, 2025 I've used this at Send Cut Send, it's not dimensioned but I was happy with the fit. The bolt holes are 11/32 for 5/16 bolts. I'd print one on paper and cut it out to test fit before you commit to steel. Illustrator file and pdf. Motor Mount Side Plate.ai Motor Mount Side Plate.pdf 1
MV8 Posted December 9, 2025 Posted December 9, 2025 (edited) RM Classics had two models that were essentially the same. The RM7 was the basic version while the RM8 had a bigger passenger compartment, better trimmings in leather, wider wheels, and adjustable suspension. Neither is so close a knock off that these parts would interchange and place the engine where it needs to be. The mounts I've seen are nothing like a Caterham, which typically have jaguar XKE mounts. Don't forget to set the driveshaft ujoint angles before fabbing between engine plates and mount plates. Post pics after everything is in place if you'd like suggestions on mount bracket design. Edited December 9, 2025 by MV8 1
anduril3019 Posted December 9, 2025 Posted December 9, 2025 The mounting bosses on the left side of the 711M block are about 3/8" thicker than other ford blocks, but they are often milled down to match earlier blocks if an engine is being replaced. Just make sure you double check if using other mounts or engines for reference. 1
Healeyracer Posted December 10, 2025 Author Posted December 10, 2025 Thanks for all of the input. Here is a pic of the chassis attachment points. The friend i bought the twincam from thinks he has some motor mounts for a formula ford I can have. Obviously not a direct fit, but a starting point. Am I correct in believing this style chassis would use the hockey puck style rubber isolator on this mount? If so does anyone know the car that part comes from so I can order a pair?
anduril3019 Posted December 10, 2025 Posted December 10, 2025 From the pic it looks like the mounting points are close and the standard Lotus or Caterham type mounts would work. I'd mock it up to be sure. MV8 mentioned the XKE mounts, you can find them at most Jag/British parts suppliers: https://bpnorthwest.com/jaguar/mount-engine-jaguar-to-1971/?srsltid=AfmBOoqDKjDGDW_xK-NKfiNC1KEGSeQ9LjDxc2DI0gqZhte16fSMHKLQ Not sure if the FF mounts will help or not, but they may be a starting point. 1
MV8 Posted December 10, 2025 Posted December 10, 2025 (edited) It would simplify to use CAT mounts(to alter if needed) and the CAT/Jag mount but you could use anything. Also ebay and rock auto. 1961-1971 Jaguar XKE. https://www.rockauto.com/en/moreinfo.php?pk=1133930&cc=1290013&pt=5552&jsn=475&_nck=klTi1TtmdOi52wpk5ccv%2B%2BnJlM9bmmbsac2xq9GUecz8xf3CEFaD0IAavNS6epX19Z0zvr8WqGoO2cXlR%2B9%2BQxds90zqWWz1l9JHpnPPoejwT7pgPu7IjH346%2Fhk7vZOyd0aO40tGImVrZXIE%2FQolPQHkNpFqTperG2kf0701ZX2keeATvFRd20Q18DqXqAjuqk76hAKnpP3ppwCpcIg%2B9OJghIsUc9qnonKHX7e9gEPyq33umlRmOsETpTJSdUtKc8Eprbm%2FdRSVb70qos6yRFhGIQSovUCwgeskx%2FiL2yZH0VPsOkm%2FQ%3D%3D https://www.ebay.com/itm/285165493458?_skw=c18556+mount&epid=188979464&itmmeta=01KC3VSDXNDTZD5FMKZ9FSHV2K&hash=item4265301cd2:g:DCkAAeSw85ZoZVAM&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1cMU36cMw18ZNs1hi%2FsrTjBBJAJ%2FBBzbafEoZmTt1KWdUIowTIksd8uFQ3PPkKvmCGH%2BF36Wy3ifU06%2B7fmn10%2BMKgYNVvhu68sY8eNeZgc%2FABX2XeDfi%2FRuVS0x2Ta%2FyC%2BNZ6CwfnzSlrfgoXmRho%2FwMaaCrqjJHB9V2qEwsoL0BmYXmLjRzCZ%2BF3Ts%2B%2BFaQat1jSm%2BFS3ydXC04p%2BfAYXhYoKEvcP2mjnpG%2B5aXueO29vPoc53rHvuM8S67pTbu6IoPa8IBZxLYnN3WEQ%2FfkVCSDErDn6ZOsgAtjA7wDiog%3D%3D|tkp%3ABk9SR_re5fvgZg Edited December 10, 2025 by MV8 1
7Westfield Posted December 10, 2025 Posted December 10, 2025 (edited) My old Westfield uses a Mk1 Cortina mount attached to the motor, and a pedestal to connect that to the chassis prowling thru the Burton site may also give you some ideas https://www.burtonpower.com/vibra-technics-hd-engine-mount-cortina-mk1-including-lotus-vibfor180m.html Edited December 10, 2025 by 7Westfield 1
MV8 Posted December 10, 2025 Posted December 10, 2025 Here is a cross flow in a RM8. The typical CAT mount and arm is barely visible. 1
IamScotticus Posted December 10, 2025 Posted December 10, 2025 (edited) Look, man. These cars are hand fit. Get your drive line set up, engine and everything attached sitting on blocks, rear axle and wheels at loaded ride height, trans mount, whatever, and mock up engine mounts last with PVC pipe and base board. Take the PVC to your welder and fab them. Edited December 10, 2025 by IamScotticus 1
Healeyracer Posted Tuesday at 07:43 PM Author Posted Tuesday at 07:43 PM if anyone was curious, this is what i came up with. 1
MV8 Posted Tuesday at 08:09 PM Posted Tuesday at 08:09 PM Looks sturdy. You might want to add a couple small holes in the side of those cups to let any liquids that might collect to run out.
Healeyracer Posted Tuesday at 09:14 PM Author Posted Tuesday at 09:14 PM 1 hour ago, MV8 said: Looks sturdy. You might want to add a couple small holes in the side of those cups to let any liquids that might collect to run out. Thanks, small drain holes are part of the plan. Lots of clean up work left to do on them as well.
wdb Posted Wednesday at 02:36 PM Posted Wednesday at 02:36 PM That looks like it sits further back in the chassis than my Caterham. Did you do your test fit with the gearbox attached? Here's a picture of the twink in my Caterham for reference.
Healeyracer Posted Wednesday at 04:38 PM Author Posted Wednesday at 04:38 PM WDB Yes, I had the transmission attached. I had to make the decision to use the annular throw out bearing to set it further back, so that I had clearance. The shifter will still need a little bit of turn back to be in reasonable reach, but it's not bad. This is an RM chassis. I have been told it is based of a 90's Caterham, but not certain. That is a nice looking car! 1 hour ago, wdb said: That looks like it sits further back in the chassis than my Caterham. Did you do your test fit with the gearbox attached? Here's a picture of the twink in my Caterham for reference. 1
JohnCh Posted 3 hours ago Posted 3 hours ago Agreed. I have two twin cams sitting in the garage and both oil pumps look like that.
