What starter for Birkin or Caterham with early 2000cc Zetec and Ford T9 5-speed?
I want to replace the starters in my 2 Sevens, but don't know what to ask for at the parts counter.  The two starters look interchangeable.
Do I need to ask for some sort of Merkur starter?
We need to know what zetec you have.
Likely a contour one that's vct or similar and it's going to be different than a Ford focus one.
I went through this issue when I did my clutch. The car came with a clutch from a focus as a spare but it didn't work with the existing flywheel and after swapping flywheel it didn't work with the existing starter so I had to do a full conversion at that point.
Edited by Vovchandr
I don't know the origin of the parts in my green Birkin, but the engine certainly looks like a 2000cc non-CVT Zetec like the one in my Caterham.
The non-CVT Zetec engine in my Caterham is from a 1996 Contour.  This is the junkyard engine bought to temporarily replace the "Steve" engine. Steve built HIS Birkin from a new kit and sourced the non-CVT Zetec engine from a 1996 Contour.
The T9 transmissions and the alloy bellhousings in both my Birkin and my Caterham look identical.
None of the engines I speak about here are CVT.
I will make some measurements and take some photos and get back to this thread.
By mistake, I bought from a private a Zetec CVT from a 1999 Contour.  That engine is is still at Ron's shop and has nothing whatever to do with either of my Sevens.
