San Augustine Posted Monday at 07:39 PM Posted Monday at 07:39 PM @11Budlite you are correct sir! rather pricey https://www.am-speed.de/en/product_info.php?info=p3142_accel-ignition-super-coil-45000v-140001.html @7Westfield radiator is Coventry Radiator & Presswork CO LTD Also marked Stanpart dimensions 16 1/8 wide 13 high 1
7Westfield Posted Monday at 08:38 PM Posted Monday at 08:38 PM (edited) Stanpart was a clue will take measuring one, but could be an adaptation from an early Spitfire Edited Monday at 08:47 PM by 7Westfield
pethier Posted 20 hours ago Posted 20 hours ago (edited) On 11/15/2026 at 1:05 PM, San Augustine said: @73TwinCamSpecial I have chassis s4 3123 GTS which is a RHD car imported to the states in 1974. special time capsule back on the road. I suppose everybody else already knows this, but that front suspension and swaybar setup looks just like my old Europa. I bought bolts for the upper control arms from the Caterpillar dealer because nobody else local had bolts long enough. Edited 20 hours ago by pethier
