73TwinCamSpecial Posted 23 hours ago Posted 23 hours ago Hi - I'm the new owner of the recent Seven S4 auction on BAT. The car is on it's way to me from Philadelphia and I'm starting to gather information on what I'll need to make it roadworthy. As purchased the car does not have an engine or transmission. From my experience with a 1500cc Cortina GT and now a Twin-Cam Europa I am looking at a Ford based engine to put in the car. A Twin-Cam would be nice but I just got my newly rebuilt Twin-Cam engine for the Europa back and don't think I can afford another one just now. I'm leaning toward a Cortina 1600 crossflow GT engine. I think this is what the car originally had in it. I would also consider a non-crossflow 1500 Cortina GT engine. In researching what would be the easiest engine/transmission combination to install, it looks like the Kent crossflow with a Corsair 2000E 4-speed might be a good choice. I understand the Corsair transmission was also used in the Twin-Cam Sevens. I've also read of a "Cortina close-ratio 4-speed" and a Ford Type 9 5-speed. I'd like to get a better understanding of what transmissions are recommended if I decide to use a Kent/crossflow engine in the car. The following are a few of my questions/concerns - 1. Assuming a Kent engine, what transmissions will bolt directly to the existing (stock) transmission mounts? 2. I'm guessing bellhousings for the Kent - Ford transmissions are nothing special for this application? 3. Are there any specific model/type/designation for the Ford transmissions I mentioned above? 4. Other than the "close ratio" designation, is there anything specific about a Seven S4 transmission? 5. A friend has offered me an Elan transmission. Would that work in a Seven S4? I know these are all pretty basic questions and I've tried to search for answers but so far have not been successful. I certainly appreciate any information anyone can provide me. I'm sure this will not be my last request for help. Thanks Larry Mullen
7Westfield Posted 22 hours ago Posted 22 hours ago (edited) All this is based on my Westfield 7 conversion---it's a pretty good S2 copy with a xflow First if you want to do a lot of highway driving, a 5 speed is a def plus the only thing T9s came in this country in was the Merkur xr4ti but they are the wrong input shaft for a crossflow without tinkering they are too long you can easily shorten them (I did) or buy a short one and install or get a spacer plate that moves the box back about 1" also, 1st gear is lower than needed, but not horrible alternate sets are available ($) the mount is several inches back from the 4sp location in mine the plate welded in the frame was long enough that I just drilled new holes, but had to cut away part of the front end cuz the T9 is fatty brute had to use the 4sp rubber mount, as T9 type was too wide for tunnel If using a cable clutch, you may have issues with clearance for the arm...no way to fit it in mine, so I went concentric hydraulic Burton has a nice bellhousing 4sp + T9 are different Merkur item won't work try to keep the starter on the right side so it's cooler The shift lever came in exactly the same place as the 4sp, straight under the dash bar Propshaft will be tricky I got mine from England, but with tariffs and so forth.........the problem is finding the yokes for both ends the Merkur used a guibo at the front end, and it's too big for the tunnel needs a regular ujoint type there are several sizes of flange for the rear--need to measure the 4sp I took out is a T3 I presume just a Cortina unit need any pics or dimensions? PM me your email Charlie Edited 22 hours ago by 7Westfield
Ian7 Posted 6 hours ago Posted 6 hours ago If the budget allows, consider a custom Quaife unit. You can pick the ratios you want (most street boxes out of 'normal' cars have uselessly short first gears), and the input shaft length and spline. And if inclined (as I did), get straight cut gears for the aural fun :-)
SENC Posted 5 hours ago Posted 5 hours ago Congratulations! Yes, get your friend's Elan gearbox (assuming it isn't the 5-speed +2 variant). In general, a 116e or 2821e gearbox will work with any of the Kent engines (pre crossflow, crossflow, twink). Your bellhousing choice will have implications for clutch size and clutch fork/release bearing selections (some of the bellhousings need internal relief to fit larger clutches, as on the Elan, and some require spacers to correctly position the release bearing). Tony Weale's book will be helpful to you, and I also recommend the old Dave Bean English Ford Racers catalog, if you can find one. I'll try to grab some photos of the gearbox and clutch sections this weekend, as I recall that catalog describes several of the variants. If you get the Elan gearbox, you will need to find a remote and shift lever for it (the Elan didn't use a remote - Cortinas did). I haven't looked in a while, but seem to recall them popping up on ebay from time-to-time. There were some Elans with CR boxes, but not many - so you'll have to check on what your friend has. Most were semi-close ratio. But, depending on your differential gearing and your intended use for the car, semi-close may fit your needs. If you can find close ratio gear sets, a semi-close box can be changed to close ratio with a relatively simple rebuild, but I don't see CR gear sets (or boxes) come up for sale very often. Note that there were variations of mainshafts throughout the 116e/2821e life - meaning there were also variations in the baulk rings and gear sets. @joe7 knows these gearboxes as well as anyone here, he may chime in with additional thoughts or to correct mine.
IamScotticus Posted 1 hour ago Posted 1 hour ago If it hasn't already been said, you should have the Tony Weale book and the Caterham reprint of the Lotus 7 owners manual (pink softcover). these two books are essential.
SENC Posted 6 minutes ago Posted 6 minutes ago I misremembered... it was the regular Dave Bean catalog that had the gearbox and clutch info. Adding pictures of relevant pages in the event that is helpful. I also think there is an S4 manual in the resources section of this site.
