Is there anyone in the Austin Texas area, or anyone that knows anyone in the austin texas area, that could be of some help looking at a ford x-flow engined car?
Long story...but the puchase of the Birkin has encountered a snag with the 1600 x-flow/webers/tuning/internals/ ignition..., :willy:
Apparently the car is running rough and the owner needs to get it right before it transfers into our hands..Or at least figure out the problem so we know what we are looking at.
we are up here in Akron Ohio... and can,t diagnose the problem from 1361 miles away..:rolleyes:
any help or suggested mechanics (formula ford gurus?) are appreciated.
Good Luck! I tried for a year to find one I could afford. Gave up and now going to put a Suzuki 1300cc Swift engine and Samurai trans in. I'll pm you , Russ
If it was in our shop,,,we would solve the unknown problem ourselves..we do our own work.
But this is a matter of the present owner who isnt very mechanically savy trying to solve it. It's not coming out of our pocket...
Yet..:skep:
SW25,
I thought the importer for Birkin is in Texas, I you give me a little while I'll get his name and #
Steve
Longer story would go deeper...we need someone in or close to Austin Texas.....
Texasmotorworks cannot help with this problem.
yet..
Offer to buy the car but put $2k - 4k of the price into escrow. Get the car to your shop and fix it and then come to terms with the seller on how much goes to you and how much to him. Get it all in writing (with a notary signature) and in addtion to any parts required include $s per hour for your labor that he would have had to spend anyway.
That way you will know the work is done right and if it requires a total overhaul, you will be mostly covered.
OR, just negotiate the price down and take it as is if he is not willing to do an escrow.
If i thought this was an option i would persue it.. but it's probably one of those last options.
truth might be i couldnt possibly afford myself and my own hourly rate... :D
meanwhile back at the ranch...i have wrote a few of the contacts so far, hoping to get a positive reply.
Friend of mine, Craig Taylor, of Taylor Race Engineering, is in Plano, about 3 hours north of Austin. Depending on his workload and your incentive, he might be persuaded. (He's a past FFord champion, has a passing knowledge of X-flows) HA
www.taylor-race.com
tell him Ian in Montreal sent you
I have a friend in Austin but I am afraid he would be of no help with that situation. Dick Brink would be the one I would have thought of. He is the one from Texas Motorworks already mentioned. If I think of someone else I will let you know. Loren
I am going to be in Waco from the 27th to the 30th picking up a miata, if the guy would be willing to bring the car to Waco I could look at it, or maybe I could drive down to Austin on that Fri or Sat, but you would have to be really nice to me.
If it is only an ignition or weber issue I am sure it could be fixed quickly. If it is an engine/valve train problem, then at least I could diagnose it for you. PM me to let me know.
Seth- If you will be coming through the Dallas Area, I would love to buy you lunch or dinner so I can pick your brain for a bit.
(Sorry for the off topic post )
How come you dont just by it the way it is and worry about the issues of getting it running later?
If the price is right then just take it. You can always fix everything short of the engine having some sort of MAJOR issue. Even a minor issue like a spun rod bearing or something is still relitively fixable. Just ahve him adjust his price to cover your exspence to have it fixed.
I would assume that the seller has a trailer? Could he possibly have it taken to a shop (or two) and have an estimate. You could even suggest that you would offer to cover that cost of independant estimates. At least then your only out that cost if the deal falls through. Just have them check to make sure the enigine is solid and that you have a fixable unit. Any desent shop can do that in less than an hour, with a good compression check, or possibly pulling off the oil pan, check for metal in the oil and filter and such.
Tim
If it was only that easy!:iagree:
But the car has been already paid for as a complete running car.
I had to pay for the car first, to get the broker and owner to understand i was serious about the purchase.
Then the owner went into action,,and found a problem that should have been known from the start.
I am heavily considering taking it "as is" for a lesser price than that which has been already paid. I am sure we could get it up and running very well ourselves. your right this would be a good option...IF i could.
But the owner who is working through a broker doesnt want to do take less because he will loose money on the whole deal..and he doesnt want to spend more money getting it fixed either...i could recieve the car without an engine, but only for a price that doesnt nearly make up the diffrence. As well the owner doesnt want to spend the money to trailer it to someone who has already offered to help as well..because of the price of gas to trailer it.
So as i understand it..unless the owner changes his mind,,i have to recieve the car as a running vehicle without money being spent to do so..or risk spending more than what was already made a deal for..
:crazy:
Additionally, i already have 2 full restoration projects underway and Mary would blow a head gasket if she knew i was recieveing YET another project. :ack: i am working on this as well, happily she is not your typical sportscar widow and wants this car as well..but running as promised...((got her emerald earings for christmas...shhh :D)) i'm such a suck up
It may be a very simple fix,,we are not afraid of doing the neccisary work, we are very used to complete rebuilds from junk. Luckily a fellow list member here is willing to look at the car and hopefully can provide a few answers on the problem and condition, but i cant make the owner accept the help either..i can only offer the solution.
trust me..i am trying EVERYTHING i can to resolve this and put the car in our shop.
from what we have seen, and the history,,it's a near perfect car otherwise.
Hi Southwind25,
I have been following your thread of the purchase of your car and find it to be strange that the seller is not willing to reduce the price or get the car in running order or transport it to someone who can due the job for you and him. I think the seller or the broker is just jerking your chain (gas is not that expensive if you understand what I am saying) and just wants your money. Have you talked directly with the owner and not the broker if not you should as this just seems a little funny especially if you have already paid for the car. If I were you I would just have the car shipped to you and then get it fixed and take the seller to court to get your money back for the repair especially if the seller stated in writing that the car is in good condition at the time you agreed to buy it. Sometimes it just takes getting mad and telling the seller that you want a complete refund or you will see him or her in court.
Robert, some times you just have to pay for what is unfair. You could likely just add a Zetec for less than $1500. I just purchased a truck in Fl. a few weeks ago to tow my -7 and it sure wasn't as listed. As I had prepaid also, it was my truck. Now over $2k later it is close to fitting my needs. I also just picked up an aluminum trailer to haul it with. I had not planed on any of this support equipment at the purchase of the car. I could loan you the trailer and gun, you and mary could go pick it up. I would need the trailer back by the 1 week in Jan. to take my car south.
My wife just bought me a new head-job---------------and cams for X-mas. I'll tell her next year!
