ken o Posted May 27, 2008 Posted May 27, 2008 Well, I had Brian put an S2K Ultralite together for me. I went out today to pick it up and drove it home. Major problem, I am having trouble working the pedals. I got this as a fun/track car. With the pedal situation I don’t feel comfortable in the car. So I have decided not to keep it. If you are looking for a great deal this could be it. I will post picture later or email for them. Details: 2008 WCM S2k Yellow with silver fenders Motor had 48,000 miles for a 2002 S2000 New Hankook 225s, 17” I added padding and carpet to the interior. Brian/WCM will be the seller and will issue a new title. Car is in Allen, TX. Asking $25,000 Email if interested korgeron at gmail dot com Thanks Ken http://www.autoxforum.com/gallery/albums/userpics/normal_IMG_1232%20%28Small%29.JPG http://www.autoxforum.com/gallery/albums/userpics/normal_IMG_1236%20%28Small%29.JPG http://www.autoxforum.com/gallery/albums/userpics/normal_IMG_1227%20%28Small%29.JPG http://www.autoxforum.com/gallery/albums/userpics/IMG_1222%20%28Small%29.JPG
slngsht Posted May 27, 2008 Posted May 27, 2008 oh man, that sucks. have you tried driving with no shoes (or driving with driving shoes)?
ken o Posted May 27, 2008 Author Posted May 27, 2008 I have tried driving shoes. No shoes = no track.
Birkin42 Posted May 27, 2008 Posted May 27, 2008 Can the pedals be adjusted or modified to give you spacing you are looking for?
ken o Posted May 27, 2008 Author Posted May 27, 2008 Brian trimmed a small amount off of the right side of the brake pedal. I thought about having a toe removed but decided against it. BTW: Is this pricing fair? Where should I list the car?
Al N. Posted May 27, 2008 Posted May 27, 2008 I think fabbing a new pedal assembly might be a less drastic move, unless of course, you want to sell it regardless.
slngsht Posted May 27, 2008 Posted May 27, 2008 Brian trimmed a small amount off of the right side of the brake pedal. I thought about having a toe removed but decided against it. BTW: Is this pricing fair? Where should I list the car? Yes, you're in the right section. It would help if you post up some pics of the car. What size shoes do you wear?
powderbrake Posted May 27, 2008 Posted May 27, 2008 From your replies it appears that you have tried all the common fixes. Sorry that it got to the purchase point before the difficulties arose. The Ultralight has more pedal room than any seven I have ever sat in. Perhaps a seven is just not feasible for you. You loss will be someone else's gain, as the price seems very reasonable.
ken o Posted May 27, 2008 Author Posted May 27, 2008 Thanks guys. I will post pictures tonight. I have sz 11, wide!
JohnCh Posted May 27, 2008 Posted May 27, 2008 How much space do you need to free up in order to work the pedals safely? Is it possible to find some of it by extending the panel to the right of the accelerator pedal or is there already zero clearance in that area between the inner panel and the bellhousing? -John
powderbrake Posted May 27, 2008 Posted May 27, 2008 How much space do you need to free up in order to work the pedals safely? Is it possible to find some of it by extending the panel to the right of the accelerator pedal or is there already zero clearance in that area between the inner panel and the bellhousing? -John There are a couple inches between the footwell wall and the transmision.
JohnCh Posted May 27, 2008 Posted May 27, 2008 There are a couple inches between the footwell wall and the transmision. In that case, unless there are other reasons to sell the car, then I would investigate extending the inner panel. Looking at this picture of the foot box (shamelessly stolen from banjo29’s build site), it seems reasonably easy to cut out a section of the inner panel and fit a small aluminum box that extends the area to the right of the accelerator. Just shape the extension out of aluminum sheet from Home Depot, add some silicone to seal it, and rivet it in place. http://www.marshsite.com/116-7.jpg -John
Mandurath Posted May 30, 2008 Posted May 30, 2008 There is a locost i believe where the builder used a stainless salad bowl on the inner footwell to give him another couple inches. Wide feet. The room is there, just have to play with it, sometimes "out of the footwell" thinking.
WestTexasS2K Posted May 30, 2008 Posted May 30, 2008 There just isnt anymore room to widen the footwell. The 6 speed tranny is big. The panel on the right side of the footwell rubs on the wall in my car. Not even a MM left to move it over.
Boxologist Posted May 30, 2008 Posted May 30, 2008 if u can't go further inboard, can teh pedals be shifted further outward? move teh clutch pedal mm off the outter panel, then slide the brake pedal in that direction.
powderbrake Posted May 31, 2008 Posted May 31, 2008 There just isnt anymore room to widen the footwell. The 6 speed tranny is big. The panel on the right side of the footwell rubs on the wall in my car. Not even a MM left to move it over. Kevin is correct, I was mistaken when I said there was room to widen it. I thought the panel was on the inside of the frame rails, and it's on the outside, so it's about a half to 3/4 inch from the tranny. :banghead: Great color too, but then I am a bit biased. It's still a real bargain.
Mandurath Posted May 31, 2008 Posted May 31, 2008 Of course this is a pretty big modification, but what about a gurney bubble for the feet, I do not think it would look bad. Would be less effort than another complete car imo.
rv-4mike Posted June 1, 2008 Posted June 1, 2008 Cant move the Wilwood pedal assembly outboard. The steering column just barely clears the brake pedal. Can be seen in the pic posted of Banjo's car.
WestTexasS2K Posted June 1, 2008 Posted June 1, 2008 looking at the picture of the pedal it would appear that the pedals could go to the left about 12 inch. I had to notch my brake pedal about 1/4 of an inch to clear the steering shaft. Looking at the picture the pedal looks to have some room. Just a thought if it you are intrested in trying to run the car.
MHKflyer52 Posted June 1, 2008 Posted June 1, 2008 looking at the picture of the pedal it would appear that the pedals could go to the left about 1/2 inch. I had to notch my brake pedal about 1/4 of an inch to clear the steering shaft. Looking at the picture the pedal looks to have some room. Just a thought if it you are intrested in trying to run the car. I was also thinking that you might want to make some new peddle arms that would move the clutch and brake to the left more. The prake peddle could then be positioned on the left of the steering shaft and the clutch could go a lot closer to the outside frame tube and you would not have to change the peddle mount assembely and its location. Fairly easy and not all that expensive to due.
