:auto:
some are still missing
http://www.usa7s.com/aspnetForum/images/emoticons/boxologist.gif
I was thinking of you when I said "most" :D
So where would one find the icons to put in the messages. I have only see the icons that appear at the end of the subject line or I must not be looking in the correct place.
Click the Go Advanced button, you can't miss them. :cheers:
I hit "Go Advanced" and I still see the same 14 smilies we've been using for a while now. Am I doing something wrong?
hmmm... anybody else not seeing the new smilies?
In the lower left corner of the box with the smilies there is link titled More. Click it and you will get a new window with lots more smilies, :driving: :conehead: :hat:
Skip
Hey, what's this one doing here?:Chevy_anim: Some of us have Fords under the bonnet! :rant: :jester:
heh, not sure how that slipped in there. Frankn7 must have snuck behind my back. Seriously, thought I excluded that one.
Keep it. Just find an equivalent for Ford, Honda, et al. :D
BTW what does this one mean? :svengo:
Still looking for it......the link for more icons......using the advance mode and just see the 14 at the bottom only......I must be doing something wrong again.....
Martin, the 14 at the bottom are for the title of the post, not smilies in the thread. The ones we use in the thread should be to the right of the box where your type.
Do you see them there?
Martin, try this:
Click to User CP in upper left hand corner
Click on Edit Options abut half way down the left hand navigation
Scroll down to the bottom of the page to the last drop box located in the Miscellaneous Options section.
What is this set to? If it is set to Basic Editor, then this is the problem. Change it to Enhanced Interface and all will be revealed.
:hurray: :party: :cool:
WOW.....Work now.....I am one of those folks that dose not change things with the computer when I have no idea as to what it will do. :seeya:
