Ian7 Posted April 8, 2010 Posted April 8, 2010 I have a standard(?) electric Caterham gauge, says "Caerbont Automotive Ltd" on the back of it. Block has a pressure transducer sender screwed into the oil gallery with a single wire into the car loom. Curiously, the gauge has four wires going to three spade connectors on it! One matches color of wire to sender, others are a mystery. Any ideas? (its not the back-lighting, that's separate and obvious). Car wiring has had many errors and dead-ends, so maybe these are redundant? Main question - if needle swings wildly and erratically when running, would you suspect gauge or sender first?
bball7754 Posted April 8, 2010 Posted April 8, 2010 Ian - The Caterham supplied oil pressure sender is known for it's unreliability. I'd vote for the sender. I replaced mine on my Xflow, and it almost immediately began the same erratic behavior. Changing to a mechanical gauge has been on my to-do list for a few years now (I don't always move too fast). I basically don't pay much attention to my pressure gauge, on the assumption that it's wrong. Not the smartest thing to do - but some would say the same thing about owning a Seven. Steve
scannon Posted April 8, 2010 Posted April 8, 2010 The oil pressure gauge on my Caterham started reading about half of normal last year. I put in a temporary mechanical gauge which showed even higher oil pressure than the Caerbont gauge did when it was new. I put the Caerbont gauge back in and just double the reading any time I look at it. Is there a mechanical gauge out there that matches the original Caerbont gauge?
TheDingo8MyBaby Posted April 8, 2010 Posted April 8, 2010 Your best bet is just to go to a mechanical gauge. The OEM caterham ones are known to be faulty. Here's an earlier discussion: http://www.usa7s.com/vb/showthread.php?t=3913
Croc Posted April 8, 2010 Posted April 8, 2010 (edited) Vote for the gauge being the problem. The standard gauge is pretty unreliable. Before I took it out it was acting like a windscreen wiper. The mechanical gauge has been great - nice stable readings - gives plenty of confidence. Plenty of choice out there to put in the standard sized hole. The closest I found to matching the original gauge style was Mocal or Racetech. Neither are a perfect match because of the missing Caterham logo. Edited April 8, 2010 by Croc
MHKflyer52 Posted April 8, 2010 Posted April 8, 2010 I have been following your post and you might want to contact one of these businesses as they can most likely convert your gauge for you at a reasonable cost. http://www.speedometerplus.com/ http://www.nhspeedometer.com/ Just a suggestion and no affiliation with them but they both do good work. Here is a link to even more places that might be helpful. http://www.vintagepartsource.com/instrument_repair.htm Hope this helps.
shiva Posted April 9, 2010 Posted April 9, 2010 I have the same gauge on my car. Start looking at the wiring to be sure there is no mis-contract on any of the spade and wire. With the bulb hole in top looking at the back of the gauge Center is ground Left is signal Right is +12v Here is the installation diagram that says which wire is which. http://www.caigauge.com/_wp_generated/wp5d115bab.png
Ian7 Posted April 9, 2010 Author Posted April 9, 2010 thx Shiva. I see we are neighbors, how can I not know you, where abouts in Montreal? Ian in Lachine
shiva Posted April 12, 2010 Posted April 12, 2010 True... I didn't see that was you that posted the question. If you want to test you gauge. We could swap my gauge and see what's wrong with yours. Or even the sender if needed. I you want, email me in private and I'll send you my contact info. Jp
