Apparently the Brit magazine EVO will feature an article on Caterhams for winter driving in Issue 168 (not available on US newsstands for a couple of months, probably). The blurb says,
____
Seven in the snow
You can put winter tyres on just about anything now, Caterhams included. Henry Catchpole deliberately heads for some snowy European mountains…
)photo from EVO attached....)
____
Should be interesting..... up here, we've got more than three feet of snow on the level right now, and the snowbanks between cleared sidewalks and cleared streets are taller than an SUV.
While winter tires might help a Seven, such a car stands to be squashed at every T-intersection, because visibility is so poor for (and from) any car that is not at least 4 1/2 feet tall.
I hate to ask a stupid question but how does the heater in the Seven work in Alaska ? It may not make any difference if, as you say, you'll get squashed at the first intersection. Personally, I think Sevens are better in Florida, where I am, and Hummers are better in Alaska.
The sump of my Birkin is so low that the car will be high centered, making the snow tyres futile, I would think.
m
That was my attempt to cross Breckenridge Mountain Road (southern Sierra Nevada) in April 2010. Was not too bad until the snow got about 3-4 inches deep with the snow drift in the background. It took some pushing and cursing of my wife to get us out of it. With chains we probably could have done it but the Toyo T1R are just not cut out to be snow tires :rolleyes:
But no collision risk, I suppose we were the only ones crazy enough to drive this road at the time. Temperature was above freezing, no heater needed.
http://lh6.ggpht.com/_242PlvPtVpE/S8KJ8DjL65I/AAAAAAAABgg/0QOEOSx4nUI/s720/P1010825.JPG
Edited by slomove
I had Toyo R888 305's on the back of Frankn7, and couldn't get enough traction to climb the 1" lip to enter my garage due to a little bit of ice.
Klasik-69,
The Seven heater works pretty well, even wit the top down. The warm air flows upward, keeping your hands warm on the wheel (your upper body needs some other way to keep warm, however).
Here's what we use in Alaska to pull the Hummers out of the ditches:
With the Iditarod starting this weekend, you should be able to sub runners for wheels, hook up a team of huskies, and blend right in on the trail. Just stand up in the trunk and leave the hood off to add to the illusion. No need to worry about Hummers (though the Unimog is pretty cool).
Re the EVO clip -- too dicey for me, on public roads with oncoming traffic. But he does do a nice job in keeping the Seven out of the ditches.
I certainly would not risk my own car under conditions like these (perhaps, when I was younger.....).
  • 4 weeks later...
Day 3 of the One Lap, after driving through 7 tornados in Iowa.
3:15 am Evanston Wyoming Hwy 80. 23 degrees.
Towing the coffin. :)
Are we having fun yet?
The competition feared us.... LOL
Edited by 7evin
A 7-ish car (unsure of the type?) in some snow:
http://i321.photobucket.com/albums/nn384/BBL-Sean/forum_photos/bbs_7558518_2DE891FD48434B480445B8E80299769B.jpg
Must be Japan or NZ -- or he is taking a blind curve on the wrong side of the road.....
