2005 Caterham 7 SV Roadsport
Purchased new and fully assembled from Jeff Sloan at British Auto Specialist in Fort Worth, TX (Caterham dealer) in August 2007. This chassis was shipped in early 2005, and was purchased by Jeff from the Nearn family as part of a group of 12 cars right before they sold Caterham Cars to Ansar Ali and his compatriots. It has an Arch frame. Original specification:
Black full paint
Red leather seats, tunnel top
Red interior panels
New SVT Zetec motor with Raceline sump
Lightened flywheel
T-9 5 speed transmission
Kent camshafts
ZF limited slip differential/3.92 final drive
Triple pass aluminum racing radiator
AP racing brake upgrade
British Auto Specialist sump skid plate
4 point racing harnesses
FIA roll bar w/petty strut
Momo quick release steering wheel
Adjustable spring perches
Interior insulation kit
Jet hot ceramic coated exhaust
Heater shut off valve
Full weather gear (heated windscreen, hood, side doors with armrests)
Hood bag
Carbon fiber dash, stone guards, sill protectors
Aero fuel filler cap
Full tonneau cover
Perspex wind deflectors w/bag
Spare wheel and tire
Luggage rack
Indoor car cover
Modifications made since purchase:
Custom engine tune by Ed Senf/Balanced Performance
Adjustable exhaust cam gear
180 degree thermostat
Replaced distributor, spark plug wires with direct coil packs
Upgraded exhaust mounts, added center exhaust mount
CFM Motorsports aluminum DSI manifold lever
Spa catch tank routed in line from PCV valve back to intake
Philips X-Treme Power headlamp bulbs
Mid Atlantic Caterham Serpentine belt reorientation kit
Stack auxiliary gauges (mechanical oil pressure, electric stepper fuel and water temp)
Samco silicone front radiator hoses
Odyssey PC680 battery, billet aluminum hold down, trickle charger
Cold air intake and plexiglass radiator air deflector (relocated battery, no bonnet cut)
3M Clearshield on rear wings and stone guards
Ceramic black Super 7 nosecone badge
Accessories/Spares:
Diablosport Predator ECU programmer w/data logging, fault code reader
Soft Bits for Sevens tunnel bag
Walker St. Clair outdoor half car cover
Removable passenger side cone catcher (mounts under body)
CFM racing oil pump
original distributor and mounting bracket
wiper blades
owners manual
assembly manual
I have also upgraded various small bits and pieces of the car, such as a better quality fuel neck hose, as I saw the need. The car has been autocrossed regularly, and maintained obsessively. Fluids are Mobil 1 5W30 engine oil, Redline MT90 in the transmission, and Redline 75W90 with friction modifier for the differential. I have a complete service history, as well as receipts for all purchases. The odometer reads 15,897 miles as of this post, and is correct. 5 Toyo R1R tires with approx 6/32 remaining tread keep it attached to the ground (well, 4 of them do. The 5th one just kind of hangs around in back). Blemishes are as follows: a paint chip about the size of a pinkie fingernail on the bonnet (due to a paint defect at time of manufacture), minor spider webs on the front wings at the fasteners, and 2 small dings right below the Caterham emblem on the rear valence. The car has always been garaged and covered, and gets wiped down after every use. It has a Georgia "assembled vehicle" title. If one searches my posts on USA7s and the California Caterham Club, much of the car’s development and history can be seen.
$35,950 obo.
Edited by athens7
Wow, all the good cars are coming out for sale. I have always thought the color combination of this one was great. Lots of spec in an SV for a really exceptionally good price.
What is your next car project Brad?
Most of my small file engine pics are already on various threads here, and won't duplicate to a second thread. Post #8 here: http://www.usa7s.com/vb/showthread.php?t=5144
has some pictures of the engine, CAI, and radiator shroud. I have large file size pictures available.
This picture shows the coil on plug ignition that replaced the stock distributor/plug wires.
Edited by athens7
Fabulous car, obsessively maintained/upgraded by a se7en nut with the wherewithal to indulge his addiction. Result, an amazing bargain for some lucky buyer-IMHO.
I resent the implication (that I have wherewithal) :D As to the nut thing, "it's a fair cop".
I no longer have a company car, so I'm thinking about replacing my 7 and the Acura RSX-S that I now use for a daily driver with one car that I can both drive daily and track/autocross, perhaps a Boss 302 Mustang (it's a heavy girl, though). I took the 7 out this weekend, and it's still the most engaging, entertaining car I have ever owned. It makes my convictions about selling very flimsy...
A few more questions.
You say the engine is new. Is this a crate engine, rebuild, etc?
Do you have hp and torque numbers?
How many miles on the engine?
Is the tranny a close or wide ratio?
What clutch are you running?
Thanks.
Thanks.
The motor was purchased by Caterham USA as part of a group from a Ford dealer in Denver. I have the receipt. I would call it a "crate" engine.
According to my last dyno chart, about 160 hp & 150 lbs-ft of torque at the wheels. What that translates to at the crank depends on who you ask.
Miles on the engine is the same as miles on the car, as the engine was new (currently 15,900).
The transmission is the Ford T-9 with standard ratios. 3.92 LSD rear and .82:1 5th gear overdrive.
Clutch is as installed by Caterham/British Auto Specialist. It is hydraulic with an annular slave cylinder. Flywheel is lightened option from Caterham (9-1/2 lb.?)
Brad,
I can honestly say this Seven was one that made me fall in love with the breed. I autocross a Miata in CSP and have always enjoyed watching this beautiful example in action. Now if only I could scrape together the money...
  • 3 weeks later...
An update, for those who are interested. I have a commitment to purchase the car, backed by a deposit, from a nice fellow who is tied up with work for a couple of weeks. If the sale doesn't finalize by the 25th, I will notify the people who have expressed interest in the car since I took the deposit. Thanks to all for their interest. I have driven the car a little, to keep the fluids stirred, and I wonder if I am being a complete idiot by selling it.
