Everything posted by JohnCh
I agree with Skip. Two of the things I really like about 911s are the wonderful turn-in and their eagerness to be steered with the throttle. A se7en makes the 911s front end feel heavy and they are throttle-steering machines. Go for it! -John
It’s hard to tell from the small photo if this will work, but what if you attach the bottom to the Raceline lower mount and then replace the upper mount with a longer turnbuckle assembly? If you need something curved to clear the alternator, then how about something like this? -John
Lots of options here. I am using the 3” Land Rover style lights with the Genesis 48 LED replacement for the 1157 bulb. The stock 1157 isn't particularly bright, but the Genesis is great with very good off-axis output. -John
270mm, which is about 10-5/8". -John
DB6, good to see you back! And good to see you are still banned regardless of your user name. -John
How often should you change the air in tires?
JohnCh replied to Mondo's topic in General Sevens Discussion
It may sound like overkill, but I’ve been using 100% organic air from the Sahara desert for the last couple of years. Not only is it much drier than the air here in the PNW but it has natural damping qualities that enable the tires to run at lower pressure. It's a little pricey due to the shipping charges, but the handling improvement is noticeable. My tires are also lasting longer, so I'm saving some money there. I’m happy to contact the importer and arrange a group buy if there is sufficient interest. -John -
Mazda, in case you are wondering what to do after your se7en is finished... http://www.autoblog.com/2010/06/30/vintage-mini-gets-3-500-horsepower-engine-swap-for-goodwood/ http://www.blogcdn.com/www.autoblog.com/media/2010/06/web-mini-cummins.jpg
Also check out space saver travel bags. They enable you to pack a lot more clothing in a small space and they are water proof. -John
It’s one piece of lexan with two bends (middle and bottom) that can be seen in these photos. I made the final mockup out of MDF and then handed that off to the plastics shop who cut and bent it to match. http://john15.web.officelive.com/Documents/trans%20tunnel%20015.jpg http://john15.web.officelive.com/Documents/windwing.jpg -John
I think I used 1/4" but I'll have to measure tonight when I get home. They are shockingly strong though The driver's side unit took a tire carcass hit at 70mph that destroyed the rear wing, but left the deflector unfazed. If the deflector hadn't been there, I might not be here to write this... -John
The mounting points for proper shoulder harnesses should be in the chassis as well. I think in that era Westfield gave people the option of installing three point harnesses to meet local registration regulations. -John
I used a spare set of male sidescreen hinges spaced the same as the female counterpart on the windscreen pillars. Makes it very easy to swap between sidescreens and windwings: lift one out, drop in the other. -John
Crossflow-powered Westfield for sale at WireWheel.com. Looks like a pretty standard car from the Yarwood era with ridiculously low mileage (how can someone drive a se7en only 2000 miles in 10 years?) They are asking $17.9k. No affiliation. http://www.wirewheel.com/2000-Westfield-Lotus-7-SEI.html -John
Great info Dave. I experimented a lot with winglets on my car and discovered that to maximize effectiveness they need to be long, extending below the door cutout, be fairly wide, and sit at a pretty steep angle. The shape below is what I finally settled on after making a number of mockups out of reinforced cardboard. Not the most attractive add-on, but they split the difference between running with and without sidescreens, and unlike sidescreens, they don’t trap cockpit heat at low speeds. Work pretty well in the rain too. http://john15.web.officelive.com/Documents/windwing%20front.jpg -John
Calvin, the Jenvey TB throttle body has the same critical dimensions as a DCOE/DHLA, so it is a straight drop in for your current setup. Dean, I believe you're thinking of the conversion to a Twin Cam Stromberg head. Calvin's car already has the Weber/Dellorto head, so no machining necessary. -John
Isn't the intake manifold cast into the head on a Lotus Twin Cam? If so, the Weber replacement throttle bodies are as direct-to-head as you're going to get -John
Jenvey makes direct replacements for DCOEs, so that shouldn't be an issue. They also have measured drawings on the site so you can confirm any potential change before ordering. As for people beating you up on the last thread, it seems that they convinced you that your original plan might not have been the optimal path -- think how much money this site just saved you! :jester: What are your goals for the conversion and the engine? Are you planning on touching the internals? A properly set up fuel injection system will improve drivability and fuel mileage, but on its own it won't make much difference in peak power compared to a well set up pair of Webers or Dellorotos. To me the big advantage of going to FI from a performance perspective is that you can run hotter cams yet maintain the same drivability at lower rpms that you would have with milder units. -John
I think Morgan was referring to moral law, not criminal law -John
TWM isn't cheap. If you are looking for something off the shelf, have you considered the Twincam conversion kit from QED? It sounds pretty comprehensive with a DTA ECU, distributor block-off plate, crank trigger setup, and wiring harness. Not sure whose throttle bodies they use, but probably Jenvey which is pretty popular in the UK. At today's conversion rate it's less than $3k. -John
The post-Monterey route is locked and hotel reservations have been made for the three confirmed drivers! If you have been toying with joining us for any portion of the drive, but haven’t contacted me directly about it, then please do so right away so I can give you the hotel details. There is very limited space at some of these places so you need to jump on your reservations now. -John
I think you are chasing a red herring here. Yes, the drag on a se7en is terrible, but even if the total drag was on par with a contemporary car, the lack of hp will still put you at a disadvantage at high speeds. Take two hypothetical cars with identical drag and power to weight ratios, but one car is 2.5 times heavier with 2.5 times the power. Car A weighs 3750 lb with driver and has 600hp, car B weighs 1500 lb with driver and has 240hp. Doing the math, both carry 6.25 lb/hp. Now assume both cars require 100hp to cruise at 100 mph. That means car A has 500hp available for acceleration from that speed, and car B has just 140 hp. Running the numbers for available power to weight from that speed, car A has a still impressive 7.5 lb/hp, but car B now has a far more pedestrian 10.7 lb/hp. Bottom line, if you want to have the fastest car down the straight, you either need a car with a lot of hp, or you need to run at track days where those cars don't show up -John
Do you trust your 7 for a week long trip? (reliability)
JohnCh replied to Bster13's topic in General Sevens Discussion
When I bought my car, I drove it 850 miles by myself in a little over a day to get it home. My wife & I did 4000 miles in two weeks on USA2005 – half of that mileage was done travelling to/from the tour (630 miles was the longest day), so no other cars were along for support. I did about 1400 miles on PNW2007, 300 miles of which were done without any support cars along, and I am planning to cover about 2500miles this summer going to Monterey and then taking the long way back with a few other cars. So yes, I guess I trust it for driving longer distances I carry an assortment of hand tools, a motorcycle tire repair kit, duct tape, a cell phone, and a AAA Plus card. -John -
You mean they have forums for things other than cars? I guess I need to get out more often... Westfield Sports Car Club California Caterham Club Flyin Miata's Westfield Miata forum Rennlist Pelican 6-speed Online (just for the regional forum) Grassroots Motorsports Garage Journal Aside from the first two on the list, and of course USA7s, I mostly lurk. -John
Or a reunion from Monterey this summer Once I get back from that trip, I'll have a better idea how my back holds up to longer drives. I'm pretty sure I can still do an occasional 350-400 per day in the Westfield, but the 600+ days are probably no longer an option. BTW I'm sure we can convince Ed to come along as well... -John
Gert, I may be interested as well, but probably only for a week given the extra time it will take me to get there and back. -John
